ncranchero 12 Posted May 18, 2019 My ‘18 didn’t have a glass in the left slider when I got it 🤨 Merging into traffic just using the mirror was just uncomfortable, especially after my ‘14 was equipped with the glass. I had a local glass company install one a week or so ago. Much better, much safer. The Ford/Carlite glass was $195, installation $45. Worth every cent! 1 desert_connect reacted to this Share this post Link to post Share on other sites
desert_connect 31 Posted May 19, 2019 Very nice window upgrade. Your post got me inspired to look online for sliding door windows and came across Van Windows Direct out of Victorville CA. They have solid windows and then I stumbled onto their 1/2 sliding window for either L or R side sliding door, 380$ each. Kinda spendy but less than the used wagon doors I found in Yuma at 600$ each. Were you around when they installed your window? I was just curious if you or anyone else knew how difficult it was to remove the plastic cover. From looking at your pictures (thanks) you posted it looks like it is glued in with a butyl tape or caulking. Share this post Link to post Share on other sites
Fifty150 313 Posted May 19, 2019 5 hours ago, ncranchero said: The Ford/Carlite glass was $195, installation $45. Worth every cent! Agreed. Such a luxury to be able to look over your shoulder, and actually see. Share this post Link to post Share on other sites
zalienz 32 Posted May 19, 2019 14 hours ago, desert_connect said: Were you around when they installed your window? I was just curious if you or anyone else knew how difficult it was to remove the plastic cover. From looking at your pictures (thanks) you posted it looks like it is glued in with a butyl tape or caulking. The solid panel and all fixed glass is glued to the vehicle using urethane adhesive. To remove them, it involves taping off the surrounding area with gaffers tape, and then using a windshield cutout wire tool or a power tool with a metal blade, depending on the application. With the wire tool it's usually a 2 person job, with 2 T-handles and sharp wire that slowly saws its way through the dry urethane adhesive. Once the panel is removed, most of the remaining adhesive is removed with a razor blade and then cleaned with rubbing alcohol. Installing the glass then involves a power caulking tool, some primer depending on the adhesive, and laying a bead of adhesive around the perimeter of either the glass or the body. Then carefully laying the glass into place and taping it to hold it into position. Drying time varies with different adhesives. This is the same process for windshields and fixed quarter glass. Share this post Link to post Share on other sites
desert_connect 31 Posted May 19, 2019 9 minutes ago, zalienz said: The solid panel and all fixed glass is glued to the vehicle using urethane adhesive. To remove them, it involves taping off the surrounding area with gaffers tape, and then using a windshield cutout wire tool or a power tool with a metal blade, depending on the application. With the wire tool it's usually a 2 person job, with 2 T-handles and sharp wire that slowly saws its way through the dry urethane adhesive. Once the panel is removed, most of the remaining adhesive is removed with a razor blade and then cleaned with rubbing alcohol. Installing the glass then involves a power caulking tool, some primer depending on the adhesive, and laying a bead of adhesive around the perimeter of either the glass or the body. Then carefully laying the glass into place and taping it to hold it into position. Drying time varies with different adhesives. This is the same process for windshields and fixed quarter glass. Thanks, zalienz. Nice to know what I am facing. I kinda figured that it might be an adhesive caulking. I've replaced several windshields and windows in the 70s using the butyl rope cord and a primer but never adhesive caulking only. For removal I used a tool that was a knife on the end of an offset handle with a T handle pull cable but being too short it would not work for this application. Everything has changed in 40 years! Share this post Link to post Share on other sites
herb 14 Posted May 20, 2019 I have to admit that is very nice , luckily for me i never had any issues with merging / parking , lane changing ext.. and i never rely on mirrors i always look , the drivers side window is big enough to allow it but i have heard more than a few with these vans say they do have issues with that stuff so a window is a good option. Share this post Link to post Share on other sites
jrm223 66 Posted May 20, 2019 I've never had any trouble seeing things in my "small" mirrors (same as pictured above), although I would like to upgrade to the "large" ones. No windows at all behind the front seats and mine is an XL, so no cameras, sensors, doodads, thingamajiggers & whatchamacallits, lol. But, I've also previously had F150's & an F350 that had camper shells, so I couldn't really see through the back on those, either. But it's good that you were able to get what you need for relatively cheap, at least! Looks like a clean install, too. Share this post Link to post Share on other sites
Double Nickels 41 Posted May 20, 2019 An oscillating tool would probably work well for cutting out the panel. Share this post Link to post Share on other sites
mrtn 231 Posted May 20, 2019 On 5/19/2019 at 1:20 AM, ncranchero said: Merging into traffic just using the mirror was just uncomfortable, especially after my ‘14 was equipped with the glass. Share this post Link to post Share on other sites
desert_connect 31 Posted June 6, 2019 For anyone interested.......I purchased and installed a passenger sliding door window with an opening window. I will post more on my build thread, 2017 TC XLT simple camper. 1 KevinRollin reacted to this Share this post Link to post Share on other sites
jrm223 66 Posted June 6, 2019 Is that a taxi window or something? Aftermarket? I haven't seen any TC windows like that before, lol. Share this post Link to post Share on other sites
Fifty150 313 Posted June 6, 2019 Very unique window. Looks good. Share this post Link to post Share on other sites
desert_connect 31 Posted June 6, 2019 1 hour ago, jrm223 said: Is that a taxi window or something? Aftermarket? I haven't seen any TC windows like that before, lol. It is an aftermarket "AMA" window sold through Van Windows Direct. 1 jrm223 reacted to this Share this post Link to post Share on other sites
davidparker 31 Posted June 7, 2019 @desert_connect that rocks! I will look at your build thread for more info. Nicely done! Share this post Link to post Share on other sites
mdarren 4 Posted August 6, 2019 On 6/7/2019 at 12:12 AM, desert_connect said: For anyone interested.......I purchased and installed a passenger sliding door window with an opening window. I will post more on my build thread, 2017 TC XLT simple camper. Nice upgrade. I dig the opening window! Share this post Link to post Share on other sites
MLB 8 Posted January 29 On 5/18/2019 at 6:20 PM, ncranchero said: My ‘18 didn’t have a glass in the left slider when I got it 🤨 Merging into traffic just using the mirror was just uncomfortable, especially after my ‘14 was equipped with the glass. I had a local glass company install one a week or so ago. Much better, much safer. The Ford/Carlite glass was $195, installation $45. Worth every cent! Safelite wanted $500+ installed. Bought one to do myself. 1 jrm223 reacted to this Share this post Link to post Share on other sites
jrm223 66 Posted January 29 16 hours ago, MLB said: Safelite wanted $500+ installed. Bought one to do myself. Whoa! I paid them around $380-390 w/ tax to replace my '15 XL windshield a couple years ago - and they had to drive an hour from their nearest location out to me here in rural Texas, lol. I didn't feel like taking half a day off from work to go to them. Share this post Link to post Share on other sites
Fifty150 313 Posted January 30 7 hours ago, jrm223 said: Whoa! I paid them around $380-390 w/ tax to replace my '15 XL windshield a couple years ago - and they had to drive an hour from their nearest location out to me here in rural Texas, lol. I didn't feel like taking half a day off from work to go to them. Safelite does not have fixed pricing. Every location charges different prices for the same thing. It depends on where you are at. Just like everything else, some areas are just more expensive. In my area, independent shops charge less than Safelite, for parts and labor. But they are not paying for franchise fees. Share this post Link to post Share on other sites
