TCjeff
What to look for in a used 2016
So what pitfalls should I look for in a 2016 TC XLT wagon LWB with about 50,000 miles?
It looks like it doesn't have roof rails. Is that easy to get after market? I found a solution on rhino rack but was wondering if I was missing other options. Nothing too heavy up there, maybe a surfboard or two.
Thanks!
A Trailer Hitch would be nice, but it is easy to add afterwards.
Take a look at the transmission threads, its the weakest link in the drivetrain.  If it was my vehicle, I would drain and fill the transmission fluid to be safe.  Other than that you should be ok.
The original roof rails are too expensive to add afterwards, but there are several aftermarket solutions.  It really depends on what your wanting them for.  Thule has a lot of different carriers that fit their rails.  you may want to check them out.
Agree with @G B L , a trailer hitch is a nice addition.
Most effective, lowest cost, and ugliest solution is a commercial ladder rack.
Get a used vehicle without a roof rack, and you won't have to worry about how much weight the previous owner loaded on the roof.
i would look for the vehicle without the hitch.  Because who knows what the last owner towed.  Without the hitch, it never towed, and that's less wear on the transmission to worry about.
Have the dealer tune it up, flush the tranny, and perform all service work before you take delivery.  At 50,000+ miles, ask about an extended warranty and have that includes into your out the door price.
Agree with others comment about the transmission.  I have the roof rails which are nice for mounting the crossbars on.  I even bought a set of crossbars from a forum member.  However I've never used them.  Mine has the trailer hitch from the factory which is nice but Ive not done much hauling with it.  My thoughts are a trailer is preferable to the roof rack as the roof rack adds noise and hurts gas mileage.  A small lightly loaded tailer will hurt gas mileage and be quieter than stuff on the roof.  From what I know the rails are hard to mount.  So far everything Ive needed to cary has fit inside.  I do have a project which will involve 12 foot lumber but will probably put it on my trailer.
Ive had my 2016 for a little over a year and only have 13,000 miles on it.  It is supposed to be for haling stuff and taking longer drives.  For a while it was my daily driver.
Approaching 30k on my 2016.I too am concerned about the trans..it has performed as advertised. I also checked trans out put drive shaft seals as i heard some leak. Mine were both dry:thumbsup:
Bingo , i would also be extremely wary of a vehicle with a hitch .  While hitches may be convenient the cost of a trailer are often not ,  if i knew i was towing i would of went with another vehicle entirely.
Although I am privileged with the luxury of having a larger vehicle for heavier loads and heavier towing.  Not everyone has a truck at their disposal.  And not everyone is able to rent a truck @ $19.95 a day when they do have a something heavier to tow.  Kind of hard to imagine having enough money to buy a boat, enough money to maintain a boat, enough money to put fuel in a boat; but not having the $20 to rent a U-Haul van for the day so that you can tow the boat.  A real genius will try to tow a trailer with horses behind a Transit Connect.  Same story.  They have all the money for those horses, but can't afford a U-Haul truck rental.
Same way I can't see how anyone could overload a Transit Connect, when logic and common sense should prevent that from happening.  Bricks, concrete, wood.......how much can you fit before you notice that your rear end is slow low that the rear tires are pressing into the wheel well?  At what point do you realize that the front end is not suppose to point up in the air because your rear end is too low?  How much weight does it take to blow the tires?
I can only imagine the poor horses suffering in that horse trailer, towed by a Transit Connect, and the trailer flips & rolls.
Makes me want to use violence.
Now calm down , get a hold of yourself for God's sakes , snap out of it .  While extreme violence is perfectly normal & highly recommended when someone is guilty of abusing animals we have no proof that some idiot actually flipped and rolled a trailer full of horses with a TC at this time .
Further investigation is needed .
Violence is the universal language.  Over the course of human history, when encountering other people who do not speak the same language, violence has always been able to bridge the chasm.
It's often inflicted upon request.  But my personal life, and what girls want me to do to them, is not up for discussion in this forum.
I think this thread has been overloaded .....
It's official.  Someone will be mad.  Thread is off topic.
