desert_connect Posted October 5, 2017 Share Posted October 5, 2017 Here are pictures of my simple camper conversion. I needed a bed for two, a sofa, a table, a place for a cooler, it had to be easy to install and remove. I built this during a week and then we went on a 3 week camping trip spending every night in it. Overall, it works well for us. 3300 miles on the trip and averaged 29.0 mpg. I have since removed the top half of the folding seat back, it is more comfortable w/o. The eye bolt thing on the rear door holds the door open a couple of inches for ventilation while at the same time being able to lock the door. The third cushion fits nicely behind the seat back. The unit is held in place with 2 turn buckles, 1 in rear shown in pics and the other is at the L mid tie down point. I can remove this in a few minutes by myself and have an empty van again. money_bagski and Marquizzo 1 1 Quote Link to comment Share on other sites More sharing options...
windguy Posted October 5, 2017 Share Posted October 5, 2017 Great job - I like the design and craftsmanship. Thanks for sharing the pics. Is that a light mounted on the top in the back? How about the black thing in the front behind the driver's seat? Looks like a clamped on lamp perhaps. Quote Link to comment Share on other sites More sharing options...
desert_connect Posted October 5, 2017 Author Share Posted October 5, 2017 21 minutes ago, windguy said: Great job - I like the design and craftsmanship. Thanks for sharing the pics. Is that a light mounted on the top in the back? How about the black thing in the front behind the driver's seat? Looks like a clamped on lamp perhaps. Thanks, windguy! The black clamp on thing is a cheapy 12v fan. Correct, in the rear I mounted a small LED light fixture I bought from Amazon. A great little light for 10$ and I hooked up to live power. I removed the oem cargo light. LED light link: https://www.amazon.com/gp/product/B015U5LCNS/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
G B L Posted October 5, 2017 Share Posted October 5, 2017 Great Job and Pictures Quote Link to comment Share on other sites More sharing options...
Willygee Posted October 5, 2017 Share Posted October 5, 2017 Luvin it...thanks for posting!! Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 6, 2017 Share Posted October 6, 2017 With all of this camping, has anyone installed a light bar? Quote Link to comment Share on other sites More sharing options...
Colby C Posted October 6, 2017 Share Posted October 6, 2017 lookin sharp. Quote Link to comment Share on other sites More sharing options...
windguy Posted October 8, 2017 Share Posted October 8, 2017 On 10/4/2017 at 9:20 PM, desert_connect said: Thanks, windguy! The black clamp on thing is a cheapy 12v fan. Correct, in the rear I mounted a small LED light fixture I bought from Amazon. A great little light for 10$ and I hooked up to live power. I removed the oem cargo light. LED light link: https://www.amazon.com/gp/product/B015U5LCNS/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 The fan is a great idea. Thanks for the light link. It's nice that the light has a built in switch. How did you remove the OEM cargo light? Mine is LED upgrade cargo light, but it's blocked by racking so it's not doing much good plus I can't stand it being on when I don't want it on and not being able to switch it on unless I close and open a door. I always leave my driver's side slider open in the garage. Where did you wire the light to? Quote Link to comment Share on other sites More sharing options...
desert_connect Posted October 8, 2017 Author Share Posted October 8, 2017 Thanks all. windguy; I don't remember exactly how the oem light popped out but it did so easily. I searched for awhile to find a light that was small and had a switch, not too bright, not pure white (blue) or yellow and this was it. It has a natural white color and an opaque lens so it won't leave a person blind with spots. I grounded it to one mounting screw, then ran a single wire thru the channel above the doors/light, down the rear pillar and connected it to the 12v outlet plug hot wire behind the R rear panel. So far, it seems to be live all the time. I installed the light on the drivers side of center because that worked out better for us sitting on the sofa. I may add another one somewhere towards the front. Quote Link to comment Share on other sites More sharing options...
windguy Posted October 8, 2017 Share Posted October 8, 2017 @desert_connect - thanks for the added info. I've scoped out that same tap point as I'm considering adding a power point on the driver's side rear area, which is more accessible for me. And to add some type of lighting as well. I really like that light. Nice choice! It would be cool if it had a magnetic mount so you can easily stick it anywhere with a hole for the wire. Quote Link to comment Share on other sites More sharing options...
desert_connect Posted October 9, 2017 Author Share Posted October 9, 2017 1 hour ago, windguy said: @desert_connect - thanks for the added info. I've scoped out that same tap point as I'm considering adding a power point on the driver's side rear area, which is more accessible for me. And to add some type of lighting as well. I really like that light. Nice choice! It would be cool if it had a magnetic mount so you can easily stick it anywhere with a hole for the wire. Good idea! I don't see any reason why a person couldn't just add magnets to that light at the two screw mounting holes in the base using two small machine screws. They have cabinetry magnets at Lowe's and HD with a hole in the center for a screw. This would however lift the light fixture up the thickness of the magnet. Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted October 10, 2017 Share Posted October 10, 2017 Impressive build, I wish I could have finished mine in a week Quote Link to comment Share on other sites More sharing options...
desert_connect Posted November 19, 2017 Author Share Posted November 19, 2017 For anyone using the Curt trailer wiring and wanting it permanently mounted outside this little Curt bracket works great. I did have to make a bracket to mount it on the hitch since there isn't a good place on the bumper. Quote Link to comment Share on other sites More sharing options...
desert_connect Posted November 19, 2017 Author Share Posted November 19, 2017 I raised my rear license plate and added a Euro style front plate! windguy 1 Quote Link to comment Share on other sites More sharing options...
windguy Posted November 19, 2017 Share Posted November 19, 2017 I like that. I also raised my rear plate after I got the van by drilling another set of holes in the plate to shift it upwards. Posted that in a thread. Your mounting looks cleaner than mine without the extra holes in the plate. The mounting is definitely not designed for US sized plates. AZ has a good looking plate. Van looks great in that first pic with the nice desert backdrop, except for the fencing part. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted November 19, 2017 Share Posted November 19, 2017 2 hours ago, desert_connect said: I raised my rear license plate and added a Euro style front plate! I put a Euro plate on the front of mine too - Looks like it was designed for it, doesn't it? (It actually was) Don Quote Link to comment Share on other sites More sharing options...
Beta Don Posted November 19, 2017 Share Posted November 19, 2017 I put the chrome (stainless actually) dress up kit on the grille too Don Quote Link to comment Share on other sites More sharing options...
desert_connect Posted November 19, 2017 Author Share Posted November 19, 2017 12 hours ago, windguy said: I like that. I also raised my rear plate after I got the van by drilling another set of holes in the plate to shift it upwards. Posted that in a thread. Your mounting looks cleaner than mine without the extra holes in the plate. The mounting is definitely not designed for US sized plates. AZ has a good looking plate. Van looks great in that first pic with the nice desert backdrop, except for the fencing part. Thanks, windguy! I did briefly look into re-drilling the license plate holes but looked like my numbers/letters would interfere so I made the sheetmetal adaptor. I don't see a good reason why Ford didn't raise it to begin with. The correct location would not have been any more trouble than the incorrect location. I also had to bend and modify the lic plate light housing clips. They were always popping loose and rattling. Quote Link to comment Share on other sites More sharing options...
desert_connect Posted November 19, 2017 Author Share Posted November 19, 2017 10 hours ago, Beta Don said: I put the chrome (stainless actually) dress up kit on the grille too Don Looks great, Don. A bit of SS really changes the front end looks! I looks like you got a German (?) plate. I found after searching around that I could get a plate with the state flag so I did that. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted November 19, 2017 Share Posted November 19, 2017 Yes, it's German. I found a guy on eBay (from Poland I think) who will make you any plate you want from most any European country, so since I have a 2014 TC XLT, that's what I went with. Think it cost about $25 and he had it shipped here in ten days or so The SS grille kit was $50. Both are installed with double faced tape Don Quote Link to comment Share on other sites More sharing options...
mrtn Posted November 19, 2017 Share Posted November 19, 2017 I have posted this before but there are number plate holders with every possible combination of bolt holes so you can mount it on any car. I bought this one and it worked just fine: Quote Link to comment Share on other sites More sharing options...
desert_connect Posted December 8, 2017 Author Share Posted December 8, 2017 I de-badged the rear doors removing the Transit Connect & XLT. I like the clean simple look w/o. Quote Link to comment Share on other sites More sharing options...
desert_connect Posted December 8, 2017 Author Share Posted December 8, 2017 I found this little 2.5" dia. x 2" H rechargeable (USB) light for my van. Bright enough to read under with 200+ lumens on high, 100 on med and 20 on low and has SOS. On high the battery is rated at 6 hrs and low up to 36 hrs. A magnetic base that can be angled and so far has stayed put while driving around now for a month. Also has a fold out bail and hook to be hung inside or outside and it's rainproof. Great little light for 19$. With this light I may not add anymore permanent lights inside Light link: https://www.amazon.com/gp/product/B018V6XMC2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
windguy Posted December 9, 2017 Share Posted December 9, 2017 6 hours ago, desert_connect said: I found this little 2.5" dia. x 2" H rechargeable (USB) light for my van. Bright enough to read under with 200+ lumens on high, 100 on med and 20 on low and has SOS. On high the battery is rated at 6 hrs and low up to 36 hrs. A magnetic base that can be angled and so far has stayed put while driving around now for a month. Also has a fold out bail and hook to be hung inside or outside and it's rainproof. Great little light for 19$. With this light I may not add anymore permanent lights inside Light link: https://www.amazon.com/gp/product/B018V6XMC2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 Cool find - thanks for sharing Quote Link to comment Share on other sites More sharing options...
desert_connect Posted July 23, 2018 Author Share Posted July 23, 2018 (edited) I finally got around to painting the cheap moisture wicking door panels. I did the rear door first and will do the sliding doors next. Scuffed the panels with 150# sandpaper. Painted a primer and a base coat on both sides and a granite top coat on the face only. The rough finish looks good but may prove to be a nuisance to clean. Edited July 23, 2018 by desert_connect Quote Link to comment Share on other sites More sharing options...
