B0NE Posted April 27, 2019 Share Posted April 27, 2019 I then slapped the mat back down and cut out the rubber around the hatch cutout. Dropped in the hatch, popped in the step trim, and screwed down my cargo tie downs. Finished product, thanks for looking at my creation, feel free to ask about anything I might have left out! windguy, Marquizzo, jrm223 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
windguy Posted May 2, 2019 Share Posted May 2, 2019 @bone - great job on your installation. Thanks for sharing your work. I too captured this storage space in my 2015 cargo with a different approach. I couldn't stand the vinyl cargo mat so used carpeting on plywood instead. I separated the foam from the vinyl mat and used that as filler under the plywood, which is very good sound proofing material. It's great to have the extra storage space making use of this dead space. Time for you to finish those bare door panels next! I used black paint on mine. Gives the van a nice finished detail. Marquizzo, jrm223 and flyeredup1973 3 Quote Link to comment Share on other sites More sharing options...
herb Posted May 26, 2019 Share Posted May 26, 2019 On 5/24/2019 at 8:08 PM, Fifty150 said: Install a hidden safe. Great if you need to lock your wallet & such while you're surfing. Maybe stash your handgun. Surfing ? People at our age don't surf , very grateful that i can still walk . flyeredup1973, CarrieLeigh, Bill Jackson and 1 other 4 Quote Link to comment Share on other sites More sharing options...
B0NE Posted August 7, 2019 Author Share Posted August 7, 2019 At first when I was getting ready to cut the supports, I just visualized what needed to stay and what didn't. I wanted to use as much of the existing hardware as possible and not take away the structural support. It was a little nerve wracking to be cutting things out of a new vehicle lol. Once I was sure, I used chalk to mark my lines and used a sawzall with a metal cutting blade. Once all the metal was cut, I put it back in place and put cardboard over top and carefully marked and cut it to shape. Folded it half and traced the other side which gave me a perfect match on both sides. I put the cardboard back on top, poked holes for where I wanted the bolts to go through and hand tightened them down to make sure it was a perfect template. Took it all apart and traced it onto 3/4 inch ply. I used a circular saw and jigsaw with the capability of angling the blade on a 45 to cut it out. I wanted to take the edge off the ply to make it a smoother transition from foam to wood once I placed the mat back down over top. Cutting the foam from under the mat was a pain, I used some black craft paint on the wood and pressed the mat with foam down on top. That gave me a rough idea of where to cut the foam. Slowly but surely, I kept taking bits of foam away until it fit smoothly over top. Measure twice, cut once. I can say now, that it was so worth the extra effort and money. I went on an extended roadtrip this summer and I was able to hide all kinds of stuff in there. It's amazing how much space is wasted in that area. I should mention that there is even more space to be had under the front seats. There's styrofoam inserts under there about 3 inches thick (once you pull the extension floor out, you can see what I mean). I decided to leave them in there for two reasons. One, insulation and road noise. Two, if you pull them out, the mats won't sit down in that space correctly without cutting them, so I let it be. wrightcoast 1 Quote Link to comment Share on other sites More sharing options...
wrightcoast Posted August 7, 2019 Share Posted August 7, 2019 8 hours ago, B0NE said: At first when I was getting ready to cut the supports, I just visualized what needed to stay and what didn't. I wanted to use as much of the existing hardware as possible and not take away the structural support. It was a little nerve wracking to be cutting things out of a new vehicle lol. Once I was sure, I used chalk to mark my lines and used a sawzall with a metal cutting blade. Once all the metal was cut, I put it back in place and put cardboard over top and carefully marked and cut it to shape. Folded it half and traced the other side which gave me a perfect match on both sides. I put the cardboard back on top, poked holes for where I wanted the bolts to go through and hand tightened them down to make sure it was a perfect template. Took it all apart and traced it onto 3/4 inch ply. I used a circular saw and jigsaw with the capability of angling the blade on a 45 to cut it out. I wanted to take the edge off the ply to make it a smoother transition from foam to wood once I placed the mat back down over top. Cutting the foam from under the mat was a pain, I used some black craft paint on the wood and pressed the mat with foam down on top. That gave me a rough idea of where to cut the foam. Slowly but surely, I kept taking bits of foam away until it fit smoothly over top. Measure twice, cut once. I can say now, that it was so worth the extra effort and money. I went on an extended roadtrip this summer and I was able to hide all kinds of stuff in there. It's amazing how much space is wasted in that area. I should mention that there is even more space to be had under the front seats. There's styrofoam inserts under there about 3 inches thick (once you pull the extension floor out, you can see what I mean). I decided to leave them in there for two reasons. One, insulation and road noise. Two, if you pull them out, the mats won't sit down in that space correctly without cutting them, so I let it be. Thank you for all of this I'm ordering that hatch today. I took the panels out to see what was down there and saw the foam blocks under the seats and I'll probably leave that for the same reasons you mentioned. It would be hard to access anyway. Quote Link to comment Share on other sites More sharing options...
windguy Posted August 7, 2019 Share Posted August 7, 2019 (edited) Sound proofing pics Edited August 7, 2019 by windguy cathpah and jrm223 2 Quote Link to comment Share on other sites More sharing options...
teamworker Posted March 24, 2022 Share Posted March 24, 2022 (edited) Edited March 24, 2022 by teamworker cathpah, RunAgroundSailor and skippyelwell 3 Quote Link to comment Share on other sites More sharing options...
