windguy Posted May 18, 2018 Share Posted May 18, 2018 Anyone have a favorite battery jump starter they like? I have no experience in using something like this so I'm buying one blind. I'd like to get one for each car in case of a dead battery, more so if I'm in a remote location away from AAA type service or don't want to wait around for them for just a jumpstart. For the van it would be convenient to have a portable 12v source. I like the concept of having this available but at the same time it's got to work when I need it. I checked Amazon's offerings and it seems the Antigravity models (AG-XP-10 is $180) are pitched as being one of the original sources of these. Others are knock-offs and much less expensive, less than half that amount. None of them got stellar reviews. Battery cable clamp failures seem to be a common fault or just not working at all. The DBPower 600A model at $70 seems okay. Nice and compact. There are a bunch of other ones at the $70 price point with similar specs and ratings. Another poster recently showed a pic of a Noco Genius Boost GB40 and that's $100 and about twice the depth and weight of the DBPower model with a higher amp rating at 1,000 vs 600-800. Thanks! Quote Link to comment Share on other sites More sharing options...
Jiquay Posted May 19, 2018 Share Posted May 19, 2018 Realise that these jumper packs are good when you leave your headlights on. However, when your car is 15 years old & a hard starter, and it's -25 degrees out, they can't do much for you... not like jumper cables off a running car. Unfortunately, modern computer control systems in cars means a split-second inattention with old-fashion jumpers can cause $1500 damage in a heartbeat. GK Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted May 19, 2018 Share Posted May 19, 2018 Okay, forget about price. After having tried a few of the smaller lithium battery style, and sent them back, and with experience from friends who did the same, there is only one that I like. A friend of mine likes Booster Pac TCB-ES580, which to me, is probably the same as Jump-N-Carry JNC318 I used to use those really big ones, about the size of a car battery, that weighed about as much. I had some pretty bad ones that looked good, but couldn't get a truck or boat started. But I also had some pretty good ones, and they did not have to cost a lot. What I learned was that while some of the more expensive ones worked well, some of the better ones were not that expensive. So you can't buy these based on price. With the old style jump starters, Clore made some of the best. Which reminds me, that I still have a Clore Jump-N-Carry in the toolbox of my pickup truck, that I should probably bring inside for a charge. In the old days, I carried a little unit in my Jeep that was about the size of a motorcycle battery, and it started everything I tried: sub-compact cars, large diesel trucks, boat that was sitting in storage, Obviously, some units are not practical for carrying around. Sure, you can get a decent price on Amazon. But the reviews are questionable. A lot of paid reviewers to make the product sound good. And even online, with a Google search, you get a lot of paid reviews. After trying a bunch of "Lightning Deal", "Deal of the Day", "Gold Box", and discounted products on Amazon, I sent back every unit that was sold by a seller in China & Fulfilled By Amazon. Why? They all failed when trying to jump start a larger displacement gasoline engine, or diesel engine, on light and medium duty trucks. If I can't jump start an F-150 or E-150 with a V8, or a little box truck, it is a waste of money. Windguy mentioned the DBPower brand. I had one that was advertised as 1200 amp from DB Power. I forget now, but I think that they claimed that it would start up to a 7 liter engine. Well, the typical small car has a battery that is about 500 or 600 Cold Cranking Amp. If your jump starter says 1200, you should be good, right? The DB Power 1200 couldn't start a little Honda 3.5 liter, 6 cylinder. From personal experience, I prefer buying a Jump Starter that does only that. If I need a tire inflator, I will buy that separately, and get an inflator which works well. I don't want a multi-use item, that doesn't do either task effectively. You are not buying a jump starter for the flash light. Get a good flash light. I like Streamlight. Old school flashlight that you can assault somebody with. If you are charging up a lithium battery jump starter, just to have something to plug your phone into, then you are wasting your time and money. Charge your phone at home! Quote Link to comment Share on other sites More sharing options...
windguy Posted May 20, 2018 Author Share Posted May 20, 2018 On 5/19/2018 at 12:05 AM, Jiquay said: Realise that these jumper packs are good when you leave your headlights on. However, when your car is 15 years old & a hard starter, and it's -25 degrees out, they can't do much for you... not like jumper cables off a running car. Unfortunately, modern computer control systems in cars means a split-second inattention with old-fashion jumpers can cause $1500 damage in a heartbeat. GK Expand Thanks Jiquay, good to know. My van use is in pretty mild climates. No sub freezing temps. Quote Link to comment Share on other sites More sharing options...
windguy Posted May 20, 2018 Author Share Posted May 20, 2018 (edited) @fifty150 - thanks for all the info. Very helpful. Both car and van are 4-cylinder vehicles so I don't think I need a super heavy duty starter. A light-duty model should do the job. The Jump-N-Carry starters from Clore Industries look like decent products. They caught my eye earlier when searching around. I think the JNC311 model (500amp) will be robust enough for my needs. It's still beefier in size compared to smaller foot print models like the DBPower 600A starter but closer to the Noco Genius Boost line (400amp). Also has longer cables at 17" compared to 4-6" for the other models. Noco has 14" cables. Regarding questionable reviews on Amazon, when I can remember, I'll go to Fakespot.com to sniff out product reviews on Amazon. A few starter models got F grades, but most got B grades and a few got A grades, like the Jump-N-Carry and Noco Genius Boost models. Fakespot also shows you how many reviews were deleted by Amazon, which is very interesting in how they manipulate the perception of the product. Thanks! Edited May 20, 2018 by windguy Quote Link to comment Share on other sites More sharing options...
G B L Posted May 20, 2018 Share Posted May 20, 2018 I have the NOCO 150 and several Regular sealed lead acid booster packs. If you are going to have one for emergency's get one big enough to do the Job! The butt it will save will be yours. windguy 1 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted May 21, 2018 Share Posted May 21, 2018 I bought my NOCO from my local battery distributor. I wanted something that could work on light duty & medium duty trucks. It had to hold a charge, even it it wasn't used for months on end. And I wanted to be able to return it ifitI didn't work. My distributor promised that he would honor the warranty if the product failed within a year. Of course, I also had to be honest about it if I didn't charge the device, and it did not have enough electricity to work. On a Friday night, my boss & I left all the headlights on, on every vehicle in our fleet. Then plugged in the charger to allow an overnight charge. On Saturday morning, we came in and jump started every truck in our yard. I was a believer. The boss ordered a NOCO for every car & truck in the fleet. At the time, the small lithium battery jump starters were still new to the marketplace. Only a few roadside assistance companies were willing to try them as an alternative to the old fashion jump packs. The battery distributor started out with about a half dozen brands, since all the reps were at his door trying to push their product. The distributor said that he would only carry the NOCO, because all the other brands he tried kept getting returned. Number 1 complaint was that they didn't work. I suppose if you have a tow truck, you need a device that works, 100%, all the time, and on big & small cars. A private person isn't jump starting 25 cars a day, with some of those cars being big trucks. But you should still expect it to work, 100% of the time, all the time. windguy 1 Quote Link to comment Share on other sites More sharing options...
windguy Posted May 22, 2018 Author Share Posted May 22, 2018 On 5/20/2018 at 11:50 AM, G B L said: I have the NOCO 150 and several Regular sealed lead acid booster packs. If you are going to have one for emergency's get one big enough to do the Job! The butt it will save will be yours. Expand Thanks GBL - appreciate your sage advise, as always. Quote Link to comment Share on other sites More sharing options...
windguy Posted May 22, 2018 Author Share Posted May 22, 2018 (edited) On 5/21/2018 at 7:57 AM, Fifty150 said: I bought my NOCO from my local battery distributor. I wanted something that could work on light duty & medium duty trucks. It had to hold a charge, even it it wasn't used for months on end. And I wanted to be able to return it ifitI didn't work. My distributor promised that he would honor the warranty if the product failed within a year. Of course, I also had to be honest about it if I didn't charge the device, and it did not have enough electricity to work. On a Friday night, my boss & I left all the headlights on, on every vehicle in our fleet. Then plugged in the charger to allow an overnight charge. On Saturday morning, we came in and jump started every truck in our yard. I was a believer. The boss ordered a NOCO for every car & truck in the fleet. At the time, the small lithium battery jump starters were still new to the marketplace. Only a few roadside assistance companies were willing to try them as an alternative to the old fashion jump packs. The battery distributor started out with about a half dozen brands, since all the reps were at his door trying to push their product. The distributor said that he would only carry the NOCO, because all the other brands he tried kept getting returned. Number 1 complaint was that they didn't work. I suppose if you have a tow truck, you need a device that works, 100%, all the time, and on big & small cars. A private person isn't jump starting 25 cars a day, with some of those cars being big trucks. But you should still expect it to work, 100% of the time, all the time. Expand Thanks Fifty150 - that's a good testimonial for Noco products. I decided to order a Noco GB40 with 1,000 amps, bumping up from the the GB20 with 400 amps, so I have extra power just in case. $100 at Amazon. PDF Spec sheet attached. I'll pick up a second one for my wife's car if this first one works out okay. The Noco GB40 does not come with a wall charger, only uses USB or 12VDC from the car battery. At first I really wanted to have a wall charger, but maybe that's just another part to fail, so I'm okay with using my phone's wall to USB adapter instead and a USB cable. Supposed to charge the battery pack in 2-4 hours with the Samsung charger. I'll report back after I get the unit. Appreciate everyone's input! Noco Genius GB40.pdfFetching info... Edited May 22, 2018 by windguy Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted May 27, 2018 Share Posted May 27, 2018 With 20/20 hindsight, I would buy the unit with the most power. The GB 150. It is expensive. But, a small price to pay for security. What would you pay when you're stuck in the middle of the night, on the freeway where other motorists are passing @ 70 MPH, with poor visibility, in the middle of a winter storm? Most road service calls are for lock-outs, jump starts, and flats. I want to cover those basics in every car I operate. I try to keep a key for every car with the ring that has my house keys and work keys, then drive with a key which is only attached to the vehicle's alarm remote. That way, if I lock the door with the key in the ignition, there is another key on a ring in my pocket. This is also why I keep a jump start device and tire plug kit in every car where the spare tire or jack set is. I try to keep it minimal, compact, and basic. Sort of like carrying Leatherman tool instead of a tool kit. Just as surely as I don't want a dead battery, I also don't want a flat tire. In every little car, and when I'm on my Harley, I try to keep some sort of tire repair kit handy. In the Transit Connect, in that cubby hole where the jack is, I've got a tire plug kit, a pair of Irwin Vise Grips multi-tool, and a compact tire inflator. Slime is better known for that junk that you are never suppose to put in your tires. Slime & Fix-A-Flat are both frowned upon by tire techs. A tire tech got furious with me this one time that I brought my ex-girlfriend's car in for a tire repair. She had a can of Fix-A-Flat, and she used it. This stuff was all over the inside of the rim and tire. Guy was yelling and cursing because he had to clean the stuff out. Then he turned on me, and demanded to know why I let her put that stuff inside the tire, since he knew me, and knew that I knew better. My answer? "You, with all your tools, supplies, and knowledge, weren't out there with her on the side of the road, in the middle of the night, on a dark & stormy night. Neither was I." Forget about the tire tech who has to clean up your mess later. That is what he gets paid for. And if he doesn't want your business, you will spend your next $1,000 on a set of tires somewhere else. I was just glad that she had the can of Fix-A-Flat, it worked, and she got home safe. You don't want to have to carry a full set of tools in every car. But that little Vise Grip tool does everything that I need to plug a tire, change a battery, and hopefully I will never need to find out how more more it can do. I can only imagine how it could come in handy with things like hose clamps, and other odd sized bolts that I can lock the teeth onto. Quote Link to comment Share on other sites More sharing options...
Jiquay Posted May 30, 2018 Share Posted May 30, 2018 Don't want to slime up a TPMS sensor but those cord plugs work well. If you live in colder climates, matches & candles would be a good addition in wintertime. Just don't put it on the dashboard or you'll crack the windshield. (Don't tell my boss I know this - now!) GK Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted May 30, 2018 Share Posted May 30, 2018 Cold climate citizens all have their own life hacks. Just don't eat the yellow snow. mrtn 1 Quote Link to comment Share on other sites More sharing options...
windguy Posted May 30, 2018 Author Share Posted May 30, 2018 Getting back to battery jump starters, I got the GB40 and it looks like a decent unit. Well packaged and the actual brick isn't too big. The cables seem beefy enough. I'm a bit confused about the 12V output port though. I also got an EC5 to cig adapter socket (link below) with the intent of being able to using the battery pack to run a tire inflator or other 12v devices remotely. I thought the EC5 connector was a standard on these jump starters. I was wrong. The adapter doesn't mate with the GB40. Anyone know what type of connector that is? https://www.amazon.com/LOTUS-POWER-Cigarette-Lighter-Adaptor/dp/B019IFHLAE Second question is can you even connect a 12V load, other than a battery, to this jump starter? I tried to connect a new LED light to test the intensity using the jump cables and it didn't work. Maybe I was doing something wrong or this jump starter has some sensing technology that prevents you from doing something like that. I had some other wiring between the LED and the jump starter so that could have been the problem. Didn't try it direct yet but scratching my head. Thanks! Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted May 30, 2018 Share Posted May 30, 2018 From the GB40 user guide: Low Voltage Batteries & Manual Override The GB40 is designed to jump start 12-volt lead-acid batteries down to 2-volts. If your battery is below 2-volts, the Boost LED will be “Off”. This is an indication that the GB40 can not detect a battery. If you need to jump start a battery below 2-volts there is a Manual Override feature, which allows you to force “On” the jump start function. This may allow you to use the GB40 to power utility loads. Quote Link to comment Share on other sites More sharing options...
windguy Posted May 30, 2018 Author Share Posted May 30, 2018 On 5/30/2018 at 5:25 PM, Don Ridley said: From the GB40 user guide: Low Voltage Batteries & Manual Override The GB40 is designed to jump start 12-volt lead-acid batteries down to 2-volts. If your battery is below 2-volts, the Boost LED will be “Off”. This is an indication that the GB40 can not detect a battery. If you need to jump start a battery below 2-volts there is a Manual Override feature, which allows you to force “On” the jump start function. This may allow you to use the GB40 to power utility loads. Expand Thanks Don for finding that out. Appreciate the help. I do remember reading that and I tried the button but was rushed in my attempt. I'll give it another try and go direct to the light this time. I'll report back on my results. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted May 30, 2018 Share Posted May 30, 2018 I think that NOCO engineered their jump starters to only work as a jump starter. Otherwise, they would sell you all of those attachments and accessories. Thanks for the info on the EC5 cigarette lighter adapter. Now I will inflate my tires the old fashion way. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 1, 2018 Share Posted August 1, 2018 On 5/30/2018 at 5:25 PM, Don Ridley said: From the GB40 user guide: Low Voltage Batteries & Manual Override The GB40 is designed to jump start 12-volt lead-acid batteries down to 2-volts. Expand In case anyone is interested, I have an Optima battery in the F-150. It is suppose to be "AGM". Absorbed Glass Mat technology makes no difference, and the NOCO GB40 (1000 AMP) started the truck with ease. https://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html Wet cell (flooded), gel cell, and absorbed glass mat (AGM) are various versions of the lead acid battery. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 1, 2018 Share Posted August 1, 2018 On 5/30/2018 at 5:12 PM, windguy said: I'm a bit confused about the 12V output port though. I also got an EC5 to cig adapter socket (link below) with the intent of being able to using the battery pack to run a tire inflator or other 12v devices remotely. Expand There is a 12V outlet from NOCO which works with the GB70, GB150, and GB500 models. I have a GB40 & a GB150. No way to even plug the accessory into the GB40. https://no.co/gbc010 GBC010 GBC010 Boost 12V Accessory Kit $19.95Buy Now Boost 12V Accessory Kit The NOCO GBC010 12V Accessory Kit connects directly to the NOCO Genius Boost jump starter's XGC IN and OUT ports. Easily power your favorite 12-volt devices directly from a GB70, GB150 or GB500, like a tire inflator, vacuum, coffee maker, fan, cooler and more. Made from a high-conductivity 16AWG 100-percent copper wire and a rated capacity of 15-amperes. Recharge NOCO Genius Boost UltraSafe Lithium Jump Starters from a vehicles 12-volt power source. Compatible with NOCO Genius Boost UltraSafe Lithium Jump Starter models GB70, GB150 and GB500. Power 12-volt device like a tire inflator, vacuum and more. High-conductivity 16 AWG copper wire and rated capacity of 15-amperes. Molded strain reliefs prevent unwanted strain on the XGC wire connections. Add to Cart $19.95 MSRP $19.95 In Stock UPC: 0-46221-18007-7 0.00lbs | 1.60 × 5.10 × 3.20 Datasheet No reviews Write Review Read Reviews Plug in XGC OUT for 12-volt power. Turn a NOCO jump starter into a 12-volt power source. A jump starter that can do more than just jump start batteries - power 12-volt devices. Easily convert a GB70, GB150 or GB500 into a 12-volt power source for powering tire pumps, power inverters, lights and more. Use the GBC010 Accessory Kit to connect 12V accessories to NOCO Genius Boost for endless possibilities. Switch and swap 12-volt adapter for rapid recharging. Easily connect and rapidly charge NOCO Genius Boost jump starters. Efficiently transfer maximum current flow with minimal power loss with the NOCO GBC010 12V male power connector. Compatible with GB70, GB150 and GB500. View All Jump Starters. Technical Specifications Input XGC Female 12V Male Plug Adapter Output XGC Male 12V Female Plug Adapter Wiresize 16AWG Length 24 Inches Weight 1.8 lbs Compatible Boost Models GB70 GB150 GB500 Since 1914 Home/ Products/ Accessories/ Boost Accessories/ GBC010 Quote Link to comment Share on other sites More sharing options...
MLB Posted August 5, 2018 Share Posted August 5, 2018 If you let any lithium ion battery sit too long and get too low on charge you damage it forever. The only way to keep those kinds of things alive is to charge them (and not up to 100% ideally) every other month or 3 months at most. it's a PITA and next to nobody remembers to do it, so they often don't work when needed. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 5, 2018 Share Posted August 5, 2018 On 8/5/2018 at 3:10 AM, MLB said: The only way to keep those kinds of things alive is to charge them (and not up to 100% ideally) every other month or 3 months at most. it's a PITA and next to nobody remembers to do it, so they often don't work when needed. Expand That was true for the old style heavy jump starters also. Nobody remembered to charge them. By the time you reached for it, the battery was dead. Useless to have a dead battery jumpstarting a dead battery. Just like a spare tire with no air. Or a jerrycan with no fuel. Quote Link to comment Share on other sites More sharing options...
Dust-it Posted August 20, 2018 Share Posted August 20, 2018 I have the Antigravity Micro Start , the old style was still on sale for around $65.00 to the door a mouth ago. I travel with it on my bike to charge phone , flashlights and the Bluetooth device on my helmet for long trips across the US.. I used it to start a Fully loaded V-Six Subaru that had a dead flat battery that would not light the headlights (45 degrees F) Very happy with it and small enough for your back pocket. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 21, 2018 Share Posted August 21, 2018 Just browsed the Antigravity Micros Start. It looks like a good unit. Roll over image to zoom in Antigravity Batteries Antigravity XP-10-HD HEAVY DUTY MICRO-START Lithium Jump-Starter Power Supply 4.2 out of 5 stars 19 customer reviews | 19 answered questions List Price: $219.99 Price: $197.99 Free Shipping for Prime Members You Save: $22.00 (10%) Product description The new HEAVY DUTY (HD) model of XP-10 Micro-Start has More Power and includes much larger, unbreakable All-Copper Smart Clamps. Built for mechanics and commercial or daily use, the XP-10-HD is the go-to Jump-Starter Kit for those with cars, trucks, boats, and other larger vehicles. Now with internal upgrades and using the Heavy Duty Smart Clamps the XP-10-HD can put out an additional 50A of cranking power over the original XP-10 (Top Rated by Consumer Reports). The HD Smart Clamps’ larger wires and jaw have stronger clamping force and transfer electrical current much better. The XP-10-HD is our most powerful jump-starter/ personal power supply (PPS). Fits in your hand yet has amazing power to start Diesels! JUMP-START Diesel vehicles up to 7.3L, and gas engines: any Car, Truck, Motorcycle or Powersports vehicle. 300 Amps starting current, 600A Peak! CHARGE and POWER most any of your devices. Four ports: 19V for Laptops (not compatible with Apple 16V laptops) 12V standard output (for GPS, mobile DVD players, small fans, etc) TWO 5V USB ports (for Smartphones, Tablets, Cameras, MP3 Players, Bluetooth devices, more) Massive capacity: 18000 mAh MORE FEATURES Hi-power 110-Lumen LED Flashlight built-in Lighted battery capacity indicator Automatic power-off when not in use Built-in over-charge and over-discharge protections for long battery life KIT CONTENTS: Leatherette Carry Case Micro-Start XP-10-HD PPS Smart HD Jumper Clamps (safety features prevent reverse polarity connection, over-charge, over-discharge, short-circuit, back-charge) Universal Cable for 12V accessories and use with tips 8 detachable Laptop Tips (fits many but not all laptop charging ports. Fits: Apple, Acer, Dell, HP, Asus, more) Universal 4-into-1 USB Cable (Tips: Mini USB, Micro USB, Apple 8-pin, USB type-C) Mobile Charger (plugs into cig lighter socket) Home/wall Charger Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 21, 2018 Share Posted August 21, 2018 Pricing aside, anyone in the market for something like this should consider what their needs are. Your car's battery could be 600A - 800A. So something small, light, inexpensive, 400A & under may not work. The Antigravity Micro Start is 600A. The GB40 is 1000A. The GB150 is 4000A. Not to say that those small units don't have a purpose. If you need to jump start a Barbie car or charge a cell phone........ Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 21, 2018 Share Posted August 21, 2018 On 5/30/2018 at 12:26 AM, Jiquay said: Don't want to slime up a TPMS sensor but those cord plugs work well. Expand Looking at the TPMS sensor/valve stem combinations, it looks like Fix-A-Flat would not be a good idea. It would probably still work to plug a small leak and get you off the side of the road on a dark & stormy night. But Fix-A-Flat & Slime would probably damage your sensors. And let's just say it worked, and your sensors did not get fouled. The tire tech will still insist on selling, installing, and reprogramming a new TPMS sensor because they can get more money out of you that way. Quote Link to comment Share on other sites More sharing options...
mdarren Posted August 30, 2018 Share Posted August 30, 2018 I recommend JNC660. It is considered the industry standard. Quote Link to comment Share on other sites More sharing options...
