Bart Luther Posted August 23, 2017 Share Posted August 23, 2017 Anyone found a locking fuel plug for the 2016 transit connect wagon? I bought this one below but it doesn't fit .looking for the correct part or aftermarket but not having any luck ? Genuine Ford 8U5Z-9C268-B Fuel Filler Plug Willygee 1 Quote Link to comment Share on other sites More sharing options...
mrtn Posted August 23, 2017 Share Posted August 23, 2017 Is yours an Easy-Fuel capless neck? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted August 23, 2017 Share Posted August 23, 2017 The capless design will not allow a siphon tube to be inserted. A prepared thief could fabricate something that would work, but they probably aren't that clever yet. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted August 23, 2017 Share Posted August 23, 2017 The refueling process on our van leaves much to be desired If you click on the pump handle and let it run and quit when the pump clicks off, it works fine, but if you try and add even a little more fuel (maybe to get to an even dollar amount) you end up with a gas smell inside the vehicle I'm not sure why this happens, because if you add the last few gallons v e r y s l o w l y you can easily get another 2 or 2 1/2 gallons more into the tank . . . . with no gas smell, but you've gotta do it very slowly and before the pump clicks off When it clicks off I drive maybe 20 or 25 miles and I can see the gauge come off the full mark, but if I slowly add the last few gallons, I can drive 50 or even 60 miles before the gauge comes away from the full mark - Anyone else notice this? There is obviously more room in the top of the tank when the pump clicks off - Why the gas smell in the vehicle when I try to add half a gallon more??? Don Quote Link to comment Share on other sites More sharing options...
Boomerweps Posted August 23, 2017 Share Posted August 23, 2017 I, too, have noticed the gas smell when trying to top off. I actually started following Ford's advice from the owner's manual. Only click it once after the auto pump shutoff and then wait several seconds before removing the nozzle. No more interior gas smell. Even drips on the filler area cause the smell. i think the fuel filler moldings attached to the body panel in a poor design, allowing leakage into the interior of vapors if gas gets on the outside of the molding. Gas stench EVERY time if you use that adapter and a gas can. I no longer rotate my gas stocked in my gas cans with this vehicle. Quote Link to comment Share on other sites More sharing options...
mrtn Posted August 23, 2017 Share Posted August 23, 2017 I have only used a few tankfuls (LPG mostly) so I have no good statistics but quite right, the needle drops pretty much in the first stretch of driving if I don't go crazy with multiple restarts. Never had fuel fumes in the cabin tho. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted August 23, 2017 Share Posted August 23, 2017 There is a complicated vapor recovery system on the TC and all newer vehicles. (Vapors from the gas tank are adsorbed into a carbon cannisters and later fed (desorbed) into the engine). Topping off the tank may be affecting this system. The F-150s capless system has a flaw and Ford was heavily penalized by California regulators. Maybe your fume smelling is related to this flaw? Maybe you are pushing liquid gas into the vapor recovery path? I don't top-off and have never smelled gas fumes. FYI, the vapor recovery system is the reason you don't smell gas fumes as you fill the tank. Quote Link to comment Share on other sites More sharing options...
Bart Luther Posted August 23, 2017 Author Share Posted August 23, 2017 (edited) yes mine is a easy fuel cap less system , and I just wanted a extra protection from tampering or vandalism . ford must have more than one design because this locking cap I purchased definitely does not fit my van and cant seen to find one that does . Edited August 23, 2017 by Bart Luther Quote Link to comment Share on other sites More sharing options...
Beta Don Posted August 23, 2017 Share Posted August 23, 2017 Maybe install a keyed lock on the fuel filler door? Don Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 24, 2017 Share Posted August 24, 2017 10 hours ago, Don Ridley said: A prepared thief could fabricate something that would work, but they probably aren't that clever yet. A prepared thief simply drills a hole in the bottom of the fuel tank. BSUPC 1 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 24, 2017 Share Posted August 24, 2017 My motorcycle fuel tank cap does not have a key. Nobody's siphoned off my 3.5 gallons of fuel yet. I'm guessing that even for the really desperate, starting the siphon action by sucking up a mouthful of fuel through a garden hose hasn't been done since the 70's. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted August 24, 2017 Share Posted August 24, 2017 14 hours ago, Fifty150 said: A prepared thief simply drills a hole in the bottom of the fuel tank. I agree - Even if you have 'all the right stuff' it's next to impossible to siphon fuel out of ANY modern vehicle. Much simpler (and quicker) for a thief to drill a hole in the plastic tank and let it run into a bucket Don Quote Link to comment Share on other sites More sharing options...
G B L Posted August 25, 2017 Share Posted August 25, 2017 The path for the siphon tube into the tank is the biggest deterrent to that type of theft. The biggest worry for me is some one pouring a contaminated liquid into the tank. Filling the tank with medium flow does a good job getting the tank full. Quote Link to comment Share on other sites More sharing options...
mrtn Posted August 25, 2017 Share Posted August 25, 2017 3 hours ago, G B L said: The biggest worry for me is some one pouring a contaminated liquid into the tank. Here's a worry for a young man who's into crazy girlfriends. Or just married ones. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 25, 2017 Share Posted August 25, 2017 I here that you only need to pour sugar into a gas tank, and it messes the car up. But that may be just an urban legend. BSUPC 1 Quote Link to comment Share on other sites More sharing options...
BSUPC Posted August 25, 2017 Share Posted August 25, 2017 (edited) If it is a cap less fuel system then that means they have already popped the window out and unlocked the door just to be able to reach the fuel port. Missing gas at this point is the least of the worries. In my neck of the woods if they have gotten that far, you do not have the van anymore or the gas. Now the odor of gas in the cabin is a real problem. Edited August 25, 2017 by BSUPC I can not spell. Quote Link to comment Share on other sites More sharing options...
jrm223 Posted August 25, 2017 Share Posted August 25, 2017 BSUPC, what are you talking about with popping windows out and unlocking doors?? I don't know about wagons, but my 2015 cargo van TC doesn't have a latching/locking fuel door. Just walk up to the van and open the fuel door... As for the worry about "contaminated liquids" or sugar, etc - the prankster/vandal or crazy ex-girlfriend would need to know to bring the right funnel with them like what's in our glove boxes. See this post about "proper fuel nozzle" to release the latches on the fuel door. Now that I see this, I'll have to try inserting different funnels that I have to see what happens - if this image is right, the funnels won't fit if they aren't the right diameter, interesting. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 26, 2017 Share Posted August 26, 2017 That funnel is an interesting accessory. I asked the salesperson (female) at the dealership about it, and she didn't know what it was for. I planted the idea in her head that it was something used to facilitate stand up urination for females. Click to open expanded view FAZA 4 Pcs Female Urination Device ,Travel Camping Outdoor Standing Pee Reusable Urinal Women Funnel Portable Urine Urinary 4.1 out of 5 stars 67 customer reviews | 4 answered questions Price: $15.98 Sale: $7.99 Free Shipping for Prime Members Quote Link to comment Share on other sites More sharing options...
mrtn Posted August 26, 2017 Share Posted August 26, 2017 2 hours ago, Fifty150 said: That funnel is an interesting accessory. I asked the salesperson (female) at the dealership about it, and she didn't know what it was for. I planted the idea in her head that it was something used to facilitate stand up urination for females. You are my hero. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 26, 2017 Share Posted August 26, 2017 Amazing what you can buy on amazon.com Quote Link to comment Share on other sites More sharing options...
BSUPC Posted August 26, 2017 Share Posted August 26, 2017 22 hours ago, jrm223 said: BSUPC, what are you talking about with popping windows out and unlocking doors?? I don't know about wagons, but my 2015 cargo van TC doesn't have a latching/locking fuel door. Just walk up to the van and open the fuel door... This is the only capless fuel system I have dealt with on a Ford. It was on a Ford Transit 250 I had the pleasure of playing around with. You have to physically open the drivers side door before the fuel door can be opened to reveal the fuel port. But it sounds like you are describing something completely different. So I guess Ford decided to change something between the Transit and the Connects. Quote Link to comment Share on other sites More sharing options...
Tiller Posted August 27, 2017 Share Posted August 27, 2017 18 hours ago, BSUPC said: This is the only capless fuel system I have dealt with on a Ford. It was on a Ford Transit 250 I had the pleasure of playing around with. You have to physically open the drivers side door before the fuel door can be opened to reveal the fuel port. But it sounds like you are describing something completely different. So I guess Ford decided to change something between the Transit and the Connects. That's a nice design. I kind of like that. But no. At least on the TC Titanium's (in the U.S), the refill is on the passenger side, rear panel. I love the capless refill. Faster and cleaner. Tiller Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 28, 2017 Share Posted August 28, 2017 If it's really a concern...... Quote Link to comment Share on other sites More sharing options...
