jbraica 0 Posted August 2, 2020 Has anyone installed an RV roof vent on a TC Wagon ? Since I can't see the structural ribs... I'm afraid of doing any cutting. Ant ideas ? Of is it too much trouble and not worth the effort. Share this post Link to post Share on other sites
billet_@bellsouth.net 8 Posted August 2, 2020 I'm planning on doing a vent, but mine is a cargo van. Seeing the roof rib is not an issue. Share this post Link to post Share on other sites
desert_connect 31 Posted August 2, 2020 A roof vent would be great no doubt, but is it necessary is the real question. Your van already has several opening windows which puts you way ahead of the non window cargo vans like I have. I added one opening window in the R slider which also solved a blind spot issue. Then using screens and a fan I solved my problem with condensation issues inside from overnight sleeping. I am not knocking a roof vent because it would work great. I did however solve my venting issues without cutting a big hole in the roof. Here is the link to my simple camper van: Share this post Link to post Share on other sites
MLB 8 Posted October 6, 2020 I think it only takes a little hole in the roof. Share this post Link to post Share on other sites
billet_@bellsouth.net 8 Posted October 6, 2020 (edited) 6 hours ago, MLB said: I think it only takes a little hole in the roof. The Maxair vent I installed requires a 14"x14" hole. Edited October 6, 2020 by billet_@bellsouth.net 1 jrm223 reacted to this Share this post Link to post Share on other sites
MLB 8 Posted October 8, 2020 "Maxair" sounds like that might not be the standard size. Share this post Link to post Share on other sites
JackGrimshaw 16 Posted October 8, 2020 Some thought should be given to placement.I know centering looks the best,but if you ever plan on purchasing a roof box like Thule or Yakima ( I have one and they're great),you will need to offset the location. Share this post Link to post Share on other sites
connectvanplans 10 Posted October 9, 2020 I used this adapter to level out the mating surface available on Ebay. The adapter worked very well, but you want to plan out where you might have solar panels or roof storage like Jack said if you're planning on going that route first before locating the hole for the fan. Share this post Link to post Share on other sites
jrm223 65 Posted October 9, 2020 On 10/7/2020 at 8:29 PM, MLB said: "Maxair" sounds like that might not be the standard size. ALL roof vents and A/C units are standard 14x14" hole size; Maxxair (two x's) is simply a manufacturer brand name. Share this post Link to post Share on other sites
sKiZo 54 Posted October 9, 2020 (edited) Mine need a 5x8 foot hole if I remember right ... ;-} ... and ya ... that is a MaxxAir fan, and measures 14x14. One word of caution - put the remote in a safe place as the built in control panel sucks ... not a bad idea to add the batteries for that to your annual list of things to do. PS - if the type two's are anything like my 2011, there's only one support rib between the front and rear doors. You can see where mine was cut out for the pop top. Edited October 9, 2020 by sKiZo 1 jrm223 reacted to this Share this post Link to post Share on other sites
jrm223 65 Posted October 10, 2020 My Gen 2 LWB has 2 support ribs in the roof; one right above the driver/passenger heads and the second is about halfway through the cargo area. Share this post Link to post Share on other sites
sKiZo 54 Posted October 11, 2020 Same as the gen one's then. No need to cut the front support as I don't need the extra headroom over the front seats, and it makes a nice reinforcement for a cargo area between the original roof and topper for light duty storage like blankets and such. 1 jrm223 reacted to this Share this post Link to post Share on other sites
Gary Roe 0 Posted December 26, 2020 (edited) You will need to measure the dimensions of your existing fan carefully. Although most RV vent fans are 14-inch x 14-inch, you should measure it again just to be on the safe side. You will need to remove the knobs and screws that hold the fan’s plastic shroud inside the recreational vehicle. After removing all the screws, the cover should just drop down. You just join them using clips to not even strip and join the wires later. Set the power supply wire aside so that it will not get in the way of the new fan, but make sure that you can still reach it later. This is the ways I installed my rv vent fan. If you need detail information, I will help you. https://vogeltalksrving.com/best-rv-vent-fans/#more-2220 Edited January 3 by Gary Roe Share this post Link to post Share on other sites
