Willygee Posted July 21, 2021 Share Posted July 21, 2021 2016 Transit connect. Hot here in Central Florida ..have the air conditioner on recirculation almost 100% of the time. Don't mind spending the money on premium. Any recommendations? Quote Link to comment Share on other sites More sharing options...
Gideon Posted July 23, 2021 Share Posted July 23, 2021 Welcome to "global warming". I doubt there's much, if anything, that you can do other than get a couple 12V fans. Old Land Rovers used to have a spaced second roof to reflect sun's heat and keep it from 'broiling' the vehicle. Quote Link to comment Share on other sites More sharing options...
jrm223 Posted July 26, 2021 Share Posted July 26, 2021 Ceramic tint keeps the interior around 40*F cooler and essentially works 24x7. In comparison, black versus white paint only makes about a 6-7°F difference inside the vehicle (with a time limit because eventually they hit a plateau of equal temperature, all else being equal) - most people attempting to argue color difference use an IR non-contact thermometer on the outside in an attempt to prove their point, which is irrelevant and shows their ignorance. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted July 27, 2021 Share Posted July 27, 2021 On 7/21/2021 at 6:22 AM, Willygee said: Don't mind spending the money on premium I've never heard of an "upgrade" to the OEM air conditioning. You can install a rooftop air conditioning unit. Mercedes Sprinters used for touring and camping have them. It would make the van look like you are delivering fish. But you will be comfortable. Quote Link to comment Share on other sites More sharing options...
Willygee Posted July 27, 2021 Author Share Posted July 27, 2021 I should have stated cabin air filter..my bad. jrm223 1 Quote Link to comment Share on other sites More sharing options...
jrm223 Posted July 28, 2021 Share Posted July 28, 2021 6 hours ago, Willygee said: I should have stated cabin air filter..my bad. I'll have to see what other people say, I've never replaced the one in my '15 TC with nearly 140K miles now. Granted, I could probably count the times I've used the A/C on just one - maybe two - hands! But it's making that weird noise that I've seen some others mention, so I know there's some cleaning & likely new filter needed. Quote Link to comment Share on other sites More sharing options...
JackGrimshaw Posted July 28, 2021 Share Posted July 28, 2021 (edited) Cabin air filter should be checked periodically.Many(including myself) have found evidence of mice. https://fordtransitconnectforum.com/topic/8863-solution-blower-fan-noise-dash-vibration-and-mice/ Edited July 28, 2021 by JackGrimshaw Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted July 28, 2021 Share Posted July 28, 2021 Using the recirculation setting on the AC produces colder air because the inside air is cooler than the outside air. The air filter does restrict the flow of outside air but that's not why it is less effective at cooling the cabin. The TC air conditioner is undersized in my opinion. Quote Link to comment Share on other sites More sharing options...
Willygee Posted July 31, 2021 Author Share Posted July 31, 2021 On 7/28/2021 at 10:21 AM, Don Ridley said: Using the recirculation setting on the AC produces colder air because the inside air is cooler than the outside air. The air filter does restrict the flow of outside air but that's not why it is less effective at cooling the cabin. The TC air conditioner is undersized in my opinion. Here in the hot Fla weather AC cools down hot interior quickly (on high for a few minutes) and maintains temp nicely after that usually on 1st or 2nd speed. All this on recirculation mode. Vehicle is a white cargo no window xlt 2016 which probably helps. Quote Link to comment Share on other sites More sharing options...
