mbrint Posted October 2, 2019 Share Posted October 2, 2019 Hello, thought I'd share some photos of my custom camperization for anyone interested/inspired to do the same. It took me a few months to complete, and definitely learnt a lot along the way. Despite being boxy, there are no straight lines to work off of! Pretty much every piece of wood had to be custom measured and cut (often multiple times). Since finishing it, I've been on lots of road trips on the West Coast of Canada and US. The TC handles it all! Feel free to ask any questions about the build or one's about your project. desert_connect, VannaWhite22 and mrtn 3 Quote Link to comment Share on other sites More sharing options...
windguy Posted October 2, 2019 Share Posted October 2, 2019 (edited) Thanks for sharing. Wonderful craftsmanship. Nice JOB! Cool looking dog too! I'm sure he/she thinks it's their van now and you're just the driver I like your sun/rain shade gizmo pulled over the barn doors. Good idea. I'm ready to mount speakers like you did in the rear doors. I have a Gen 2. Any issues I should know about that might help with my install? Edited October 2, 2019 by windguy Quote Link to comment Share on other sites More sharing options...
mbrint Posted October 3, 2019 Author Share Posted October 3, 2019 Thanks! The only tricky thing was feeding the speaker wire through the weather-sealed rubber hoses between the van and the doors. Just takes some patience and a stiff guide-wire to fish through. Also, you've got to watch how deep the speakers are in the door. There are a few metal braces that you have to avoid. Quote Link to comment Share on other sites More sharing options...
windguy Posted October 3, 2019 Share Posted October 3, 2019 39 minutes ago, mbrint said: Thanks! The only tricky thing was feeding the speaker wire through the weather-sealed rubber hoses between the van and the doors. Just takes some patience and a stiff guide-wire to fish through. Also, you've got to watch how deep the speakers are in the door. There are a few metal braces that you have to avoid. Got it, thanks. The Gen 2 door config is a bit different. I will need to remove the black plastic cover for the wipers to get to the pass through hose, which is up higher than your Gen 1. You've got a nice size panel to handle a larger speaker, 6 or 8" I'm guessing. The 4" round speakers I got have a shallow mounting depth, less than 1", and they are marine grade so moisture shouldn't be an issue. I tested the sound and it's okay. Hope being in a door cavity will improve that. BTW - Your pics are pretty nice too. That first one showing the mountains, which I presume is granite, is awesome. Quote Link to comment Share on other sites More sharing options...
mbrint Posted October 4, 2019 Author Share Posted October 4, 2019 I'm wondering the longevity of my standard speakers back there with moisture. I noticed a bit of road silt on the inside of the panels when I took them out. Thanks! That's a pretty big granite wall up in the Coast Mountains. There are a ton of them back there! Quote Link to comment Share on other sites More sharing options...
glennwelch Posted October 4, 2019 Share Posted October 4, 2019 Very nice woodwork and a great rear awning. Thanks. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 4, 2019 Share Posted October 4, 2019 Impressive Quote Link to comment Share on other sites More sharing options...
mdarren Posted December 13, 2019 Share Posted December 13, 2019 Looks like you got everything you need. I like the shade over the doors. Quote Link to comment Share on other sites More sharing options...
mbrint Posted December 13, 2019 Author Share Posted December 13, 2019 Thanks! Currently in the process of building a larger awning that comes off the roof racks to the side. Quote Link to comment Share on other sites More sharing options...
sKiZo Posted December 14, 2019 Share Posted December 14, 2019 Still working on mine, slowly but surly ... ;-} Kitchen is pretty much set up, and I'm going with a neat little chair/bed convertible that folds out into a comfortable bed and not to shabby for reading, eating, etc. One of the targets is having a short stay camper AND still keep it wheel chair accessible, just in case. I WILL be stealing a couple ideas from you if you don't mine though ... Quote Link to comment Share on other sites More sharing options...
kcd99 Posted September 21, 2020 Share Posted September 21, 2020 Love your build! I recently bought a 2010 Connect with the hopes of building it out into a long-term home and your's is the first I've come across that's as extensive as what I'd like to do. I was wondering how you installed your paneling and roof, did you attach a frame under there or just directly to the wall's of the van? I've read a lot about plus nuts people have used in other builds but they seem to be mostly regular transits and bigger vans and the holes in my connect seem kind of small and at awkward intervals, did you happen to utilize those at all? Thanks for any feedback if you see this! But also just thanks for the inspiration if not! Quote Link to comment Share on other sites More sharing options...
mbrint Posted September 28, 2020 Author Share Posted September 28, 2020 I tried to use those treaded inserts, but I found the locations weren't that convenient. I ended up using self-tapping sheet metal screws to attached 1x2" furring strips to the ribs of the van. Then I attached the panelling/sheets to them. Quote Link to comment Share on other sites More sharing options...
Régine Posted August 17, 2022 Share Posted August 17, 2022 Bonjour, Très beau travail !! Avez vous un plan pour la fabrication du auvent arrière ? Merci Quote Link to comment Share on other sites More sharing options...
