2nd gen with rear split doors - Unlock with fob?
On my 2015 XLT van, the rear cargo doors do not unlock when I use the fob. I can hear and feel the solenoid click when pressing the unlock button but the doors do not unlock unless I crawl into the back and use the yellow door handle to open them. Is this normal? Its a PITA to go through the side doors every time the doors lock, either from using the fob or when they autolock above a certain speed.
All my rear doors unlock from a double-press on the normal unlock button, or I can use the "rear doors" button to unlock them while leaving the front locked. If you can feel vibrations in the door while hitting the unlock button, but it stays locked, then something is probably wrong with the latch/lock mechanism in the right barn-door.
