deano Posted December 8, 2018 Share Posted December 8, 2018 I have a 2010 Transit Connect. I love it. But the doggone thing sheds wheel covers. Once it ejected the first one, I bought a set of aftermarket ones which attach in the same way as the originals. Of the eight wheel covers (4 original, 4 replacement), I am now down to three again, having ejected one again yesterday. Once I happened to be looking in my side mirror when one went sailing off my left rear for no apparent reason. Is anyone else having this bizarre problem? Not sure I want to buy four more, just to keep feeding the gods. Do those things have any really value/purpose, other than cosmetic? This is just my personal "utility truck," not my primary vehicle, and I am leaning towards leaving things as they are. Eventually all the other wheels will be bare as well. Quote Link to comment Share on other sites More sharing options...
G B L Posted December 9, 2018 Share Posted December 9, 2018 I have had that issue on other vehicles , My TC has Alloy's. The wheel covers work themselves off when the rim flexes. My Travel trailer spins lots of covers off in my travels. If you get the closed lug nuts to keep the wheel studs from rusting then you can go with out covers. Quote Link to comment Share on other sites More sharing options...
davidparker Posted December 9, 2018 Share Posted December 9, 2018 You could order a set of european "center" covers. They will probably stay on better, since they are much smaller and weigh less. But you will probably have to paint the exposed wheels since the factory paint is not very good and does allow the wheel to rust. https://www.fordpartsuk.com/alloy-wheel-centre-cap-5361 Quote Link to comment Share on other sites More sharing options...
WillMartin Posted December 9, 2018 Share Posted December 9, 2018 My wheels are good and rusty. The plastic covers make the van look much better, but all will be replaced with Fusion wheels sooner rather than later. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 9, 2018 Share Posted December 9, 2018 9 hours ago, deano said: Do those things have any really value/purpose, other than cosmetic? Yes. The hubcaps cover your hubs. Even aftermarket alloy wheels have a center hub cover or cap of some sort so that you just don't have a hole in the middle of the wheel. Protects the hubs from the elements, dirt, sand, road salt, mud, pee, et cetera. Imagine sand getting into your wheel bearings. While a hubcap is not perfect, and will not completely protect your hub & bearings, it keeps out a lot. Quote Link to comment Share on other sites More sharing options...
deano Posted December 13, 2018 Author Share Posted December 13, 2018 Thanks all! ? Quote Link to comment Share on other sites More sharing options...
davidparker Posted December 29, 2018 Share Posted December 29, 2018 Some of the hyper-milage guys attach vacuum formed lexan covers on their wheels with zip ties for aerodynamics. You might be able to zip tie the hubcap through holes in the cap and the holes in the wheel. May not look that good, but would certainly keep them from flying off. Quote Link to comment Share on other sites More sharing options...
mrtn Posted December 29, 2018 Share Posted December 29, 2018 Weird. Never lost one. Apart from the misplaced small caps. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 29, 2018 Share Posted December 29, 2018 1 hour ago, mrtn said: Weird. Never lost one. Apart from the misplaced small caps. You're not taking corners fast enough. Quote Link to comment Share on other sites More sharing options...
WillMartin Posted December 31, 2018 Share Posted December 31, 2018 I have not lost one. Yet. I'm amazed at how easily the front wheels spin up on a wet road. But, even with wheel spin, no lost cover. Yet. Quote Link to comment Share on other sites More sharing options...
mdarren Posted January 29, 2019 Share Posted January 29, 2019 On 12/9/2018 at 2:04 PM, WillMartin said: My wheels are good and rusty. The plastic covers make the van look much better, but all will be replaced with Fusion wheels sooner rather than later. Any update? I'm curious if Fusion wheels will look good on our TC's. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted January 29, 2019 Share Posted January 29, 2019 There's a thread in the Wheels & Tires forum titled 'Fusion Wheels' with pictures of some vans with wheels from other Ford products. There's a picture there of my 2014 with the Ford Focus wheels I bought on eBay to replace my steelies Don Quote Link to comment Share on other sites More sharing options...
