ang210 Posted January 30, 2016 Share Posted January 30, 2016 I a have already replaced the steering wheel with one that had the controls. The controls are illuminated now. What else is necessary to activate the cruise control? Quote Link to comment Share on other sites More sharing options...
DonShockley Posted January 30, 2016 Share Posted January 30, 2016 It looks like there's a couple modules in the steering column also. Quote Link to comment Share on other sites More sharing options...
Mikeeshaq Posted February 2, 2016 Share Posted February 2, 2016 Do not be surprised if you find out that you have to get the ECM programmed to accept the cruise control Of course you have to go to a Ford dealership that has invested perhaps up to $5000 for an ECM programmer Most important such a dealership needs to have a sharp technician Quote Link to comment Share on other sites More sharing options...
Mikeeshaq Posted February 7, 2016 Share Posted February 7, 2016 The after market version of the cruise control: Is that available from Ford? If yes then that would be the way to go I had a 2004 Focus wagon and they added the cruise control by the Ford dealership Quote Link to comment Share on other sites More sharing options...
Mikeeshaq Posted February 8, 2016 Share Posted February 8, 2016 Go to another Ford dealer, preferably larger Ask the service manage if they can add cruise control using OEM components This after market kit will be just fine until it conks out, then Ford service will say "we cannot fix it as it is not Ford" Quote Link to comment Share on other sites More sharing options...
ang210 Posted September 12, 2017 Author Share Posted September 12, 2017 Update I discovered I needed a different cluster. I purchased a used cluster with lower mileage than the original. I installed the new cluster to test it and everything still works. In addition the information controls now work. The cruise control still cannot be turned on. I think the PCM may need to be programmed to the new cluster. Does anyone know if that is the case? Existing Cluster DT1T-10849-PD Replacement cluster DT1T-10849-SCC I cannot find different part numbers for the clock-spring or Steering Angle Sensor Module. I believe they are the same in all models. Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted September 15, 2017 Share Posted September 15, 2017 (edited) I am in the process of doing the same thing but I travel a lot and I am barely home to work on the van. What are you using to program your van, IDS or FORScan and it says you installed the cluster in your van but did you program the cluster and change the Central Configuration in the BCM yet? Wow I just read the dates of the post and you have been working on this for a while Edited September 15, 2017 by dinocarsfast read previous posts Quote Link to comment Share on other sites More sharing options...
ang210 Posted October 7, 2017 Author Share Posted October 7, 2017 I had the new cluster programmed and cruise still does not work. After looking at two similar vans one with Cruise the other without the harness part numbers are different. It looks like a new wiring harness may be needed from steering column to BCM. I will update as soon as I know. Have been using IDS. A local guy has the software and is willing to attempt. Harness is expensive. Trying to locate one from a wreck and if not then will try to run the missing wires. Crossing my fingers this works. Anyone else have any suggestions? For the record I had the cluster programmed so the mileage read the same as mine. Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted October 9, 2017 Share Posted October 9, 2017 You said you programmed the new cluster but did you change the vehicle configuration "as built" in the BCM? I will be doing this next weekend or some time soon so I will let you know how it goes. Quote Link to comment Share on other sites More sharing options...
ang210 Posted October 23, 2017 Author Share Posted October 23, 2017 Verified no harness is needed. All the wiring is in place. Will have the BCM bits modified this week using bits I found from other vans that have cruise control. Will post my results after I accomplish this. I believe a BCM modification and an IPC modification will be required. Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted October 1, 2018 Share Posted October 1, 2018 I got the cruise control to work yesterday. I did not need to replace anything but the steering wheel and I have a base cluster. I previously used IDS version 101 and did not have any luck it had some bugs with reading the central configuration in my vehicle or maybe the problem was with vcm clone, idk. But with IDS version 109 it worked better. I was able to read the central configuration and it showed all the features but I still had problems downloading to the vehicle. after editing it. The way that I was able to successfully save the changes was to make the changes in the as-built file and upload that entire file from my computer. If anyone would like more detail or I can send the .xml files directly contact me via private message. I cant wait to drive this more now that I have cruise control and it only cost $60 ? jrm223 and davidparker 1 1 Quote Link to comment Share on other sites More sharing options...
donuts Posted October 8, 2018 Share Posted October 8, 2018 Hmmm, very interesting, just a steering wheel swap and some config changes and you now have cruise control? I have a base cluster just like yours and would love to add cruise. Can you provide more details on the steering wheel you installed? Thanks, Joe Quote Link to comment Share on other sites More sharing options...
Beta Don Posted October 8, 2018 Share Posted October 8, 2018 I might have a steering wheel that will work for you. My 2014 came with factory cruise and I replaced the OEM steering wheel with another OEM wheel which is leather wrapped and has the audio controls also - My original one was just vinyl and doesn't have the audio controls. I bought the leather one on eBay for $125 Don windguy 1 Quote Link to comment Share on other sites More sharing options...
donuts Posted October 8, 2018 Share Posted October 8, 2018 Thanks Don. That brings up another question - if I get a steering wheel with audio controls will I be able to control my base AM/FM radio? Volume control from the steering wheel would be nice. Can anyone tell me what the steps are to remove the steering wheel? I can buy just the cruise control switch "pod" and I'd like to look behind the air bag and find out if I can add it or if it would be simpler to just get a steering wheel that already has the switch pod. Thanks Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted October 8, 2018 Share Posted October 8, 2018 You should be able to turn on cruise control using Forscan. It performs many of the IDS functions. Quote Link to comment Share on other sites More sharing options...
donuts Posted October 9, 2018 Share Posted October 9, 2018 Which OBD II interface module are you using? I'm pretty certain I'm going to pursue this so I'd like to order (preferably from Amazon) a OBD II interface module and get Forscan or IDS all set up. Thanks Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted October 9, 2018 Share Posted October 9, 2018 OBDlink MX. Don't go cheap. You are messing with vital programming. Research Forscan on the f150, fusion and escape forums. They have good instructions. Quote Link to comment Share on other sites More sharing options...
donuts Posted October 9, 2018 Share Posted October 9, 2018 Thanks, exactly the kind of tip I'm looking for re OBDlink MX. Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted October 10, 2018 Share Posted October 10, 2018 On 10/9/2018 at 5:49 AM, Don Ridley said: You should be able to turn on cruise control using Forscan. It performs many of the IDS functions. I wasnt able to turn it on with Forscan when I first tried last year. I think it had bugs in the software but so did the IDS version I was using then, but yeah you should be able to. Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted October 10, 2018 Share Posted October 10, 2018 On 10/8/2018 at 12:55 PM, donuts said: Hmmm, very interesting, just a steering wheel swap and some config changes and you now have cruise control? I have a base cluster just like yours and would love to add cruise. Can you provide more details on the steering wheel you installed? Thanks, Joe I just got one from a local LKQ but ebay should work too, from what I remember it wasnt possible to just get the switches and mine might be from an escape. But if beta Don can find his I would use that Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted October 10, 2018 Share Posted October 10, 2018 On 10/9/2018 at 5:43 AM, donuts said: Thanks Don. That brings up another question - if I get a steering wheel with audio controls will I be able to control my base AM/FM radio? Volume control from the steering wheel would be nice. Can anyone tell me what the steps are to remove the steering wheel? I can buy just the cruise control switch "pod" and I'd like to look behind the air bag and find out if I can add it or if it would be simpler to just get a steering wheel that already has the switch pod. Thanks I am curious about the radio controls on a base radio also. I got a steering wheel without so I dont have the answer, if you find out let me know. I would probably be more likely to upgrade the instrument cluster first and have the mpg and better looking screen Quote Link to comment Share on other sites More sharing options...
donuts Posted October 10, 2018 Share Posted October 10, 2018 Thanks for the info Dino. I've got a deal set up with Don to buy his old steering wheel with the cruise buttons/switches, but without the radio buttons. I need cruise control but can live without the radio buttons. I'll post an update once I've got it all working. Quote Link to comment Share on other sites More sharing options...
donuts Posted October 18, 2018 Share Posted October 18, 2018 I received my "new" steering wheel from Beta Don the other day - big thanks to Don! Now I just have to order an OBDLink MX and find some time to do wheel swap and figure out the OBDLink, Forscan, etc. Dino - is the cruise control setting the only one you had to change? Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted October 19, 2018 Share Posted October 19, 2018 13 hours ago, donuts said: Dino - is the cruise control setting the only one you had to change? yeah, that was the only the one setting I had to change, but it wasnt straight forward for me, hopefully it goes better for you with forscan Quote Link to comment Share on other sites More sharing options...
donuts Posted October 20, 2018 Share Posted October 20, 2018 Thanks Dino. I got the new steering wheel installed today - easy swap. Now I've got to order that OBDLink MX... Quote Link to comment Share on other sites More sharing options...
