DanDweller Posted June 22, 2019 Share Posted June 22, 2019 After going through an automatic carwash, the AC is blowing, but not cold air. Any idea what is getting wet? Last time this happened, it started working again a few hours later. (TC, 2015, XL, LWB) Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted June 23, 2019 Share Posted June 23, 2019 The only part under your hood exposed to water from rainfall or a carwash is the front grille fascia. Water would have to spray directly in for anything to get wet. The only part on the front of the car exposed would be the air conditioning condenser, accumulator, fittings, and lines. This is the part that looks like a radiator, in front of your radiator. The air conditioning compressor is under the hood in the engine bay. Look for visible damage. Quote Link to comment Share on other sites More sharing options...
PhotoAl Posted June 23, 2019 Share Posted June 23, 2019 I would be suspicious of a connection getting wet, maybe belt for compressor getting wet and slipping but Id be surprised at that. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted June 23, 2019 Share Posted June 23, 2019 Does the windshield leak? Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted June 23, 2019 Share Posted June 23, 2019 May have a damaged condenser. Rock strikes. Bird strikes. Animal damage. But probably not a line leak or bad fitting. Quote Link to comment Share on other sites More sharing options...
zalienz Posted June 24, 2019 Share Posted June 24, 2019 It's possible the outside ambient air temperature sensor is getting wet in the car wash. They are often located up front near or under the front bumper for airflow, and cold water can drop the temperature reading below the expected parameters which the computer will see as a sanity malfunction and switch off the compressor to protect it. Once the sensor warms back up the computer restarts the compressor. I've seen this happen on other vehicles, but not Ford. But it's entirely plausible scenario. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted June 24, 2019 Share Posted June 24, 2019 Very good point about the ambient air temperature sensor. Sensor also has wiring and a connector which could get wet. In most cases, if there is damage and/or a leak, it would be consistent. Not just after going through a car wash. You probably won't find a leak with a visual inspection or tracer dye. There very well may be water wetting a bad electrical connection. No reason why water is getting under the hood. Even if you go through a car wash which sprays water upward, there is an underbody shield. I can only imagine water spraying in past the passenger side wheel well, towards the side of the engine where the belts and pulleys are. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted June 24, 2019 Share Posted June 24, 2019 From the service manual on a 2016: zalienz 1 Quote Link to comment Share on other sites More sharing options...
DanDweller Posted June 26, 2019 Author Share Posted June 26, 2019 On 6/23/2019 at 12:36 PM, Don Ridley said: Does the windshield leak? Not that I know of. Quote Link to comment Share on other sites More sharing options...
DanDweller Posted June 26, 2019 Author Share Posted June 26, 2019 On 6/23/2019 at 11:37 PM, Fifty150 said: Very good point about the ambient air temperature sensor. Sensor also has wiring and a connector which could get wet. In most cases, if there is damage and/or a leak, it would be consistent. Not just after going through a car wash. You probably won't find a leak with a visual inspection or tracer dye. There very well may be water wetting a bad electrical connection. No reason why water is getting under the hood. Even if you go through a car wash which sprays water upward, there is an underbody shield. I can only imagine water spraying in past the passenger side wheel well, towards the side of the engine where the belts and pulleys are. I did notice this plastic shield beside the rqdiator (driver side) is busted. Quote Link to comment Share on other sites More sharing options...
zalienz Posted June 26, 2019 Share Posted June 26, 2019 Good find on the plastic shield. Looking at the sensor location, it is up front next to the condenser. But which side is a little murky. This photo from the service manual shows it, but on the big photo it looks like it's on the left, the smaller (upper left) picture in a picture shows it on the right.... Update - Just looked at my 2017 - it is on the left. You can see yours in your photo just below the middle strake of the fascia. That's a great place to start, considering there is damage in that area. In any case, you have intermittent a/c operation, which indicates a more likely electrical or sensor issue. If there was a leak in the refrigerant portion of the system, it would stop working and not come back on until repaired. Unfortunately you will need to catch it in the non working state and do some diagnosis, pull codes from the computer that will point you in the right direction to continue diagnosis and find the cause. Replacing the sensor proactively is easy, but with hit or miss results. All outside connectors are water proof, and generally do a good job of keeping moisture out, but since there is damage there, it may have damaged the connector or sensor, which would explain intermittent operation. You may want to pull the undercover and take a good look. Quote Link to comment Share on other sites More sharing options...
Double Nickels Posted June 26, 2019 Share Posted June 26, 2019 I would get a piece of plastic, epoxy it in place to protect the sensor, and the problem is solved. Sensor works fine when dry. Keep it dry. Nobody will see that patch job. Or you can find a replacement front grille fascia, and change it out to a new part. It's probably an entire new front end piece, bumper cover, grille, all I 1 body part. Quote Link to comment Share on other sites More sharing options...
zalienz Posted June 29, 2019 Share Posted June 29, 2019 Actually that plastic piece is behind the sensor, it doesn't do anything to protect it. The sensor needs airflow to work properly, which is why it is up front and in the vent area. It just needs a good visual inspection to see of there is any damage. Quote Link to comment Share on other sites More sharing options...
G B L Posted June 29, 2019 Share Posted June 29, 2019 Have you run a scan on the AC system? That could tell you a lot. Quote Link to comment Share on other sites More sharing options...
gwbasley Posted May 2, 2020 Share Posted May 2, 2020 OK, so I am posting this a year later for anyone having an intermittent A/C problem. I drive a 2016 TC XLT and within the past 6 months, (I live in Florida so I use A/C in December), began having a problem where my A/C would suddenly just start to blow warm....a few miles further and it would work normally again. This was totally unpredictable and no amount of fiddling with the controls would would have any effect. After a major internet search, which included this thread, I decided to change out the ambient air temp sensor since It was only $16.00 at NAPA. On my vehicle it was located exactly as shown in Zalienz's post above. The view shown there is from the inside out after the plastic shield has been removed...this puts it on the driver's side in the lower corner of the cowl. I also took this opportunity to replace the push rivets on the underpan which were damaged or missing from oil changes. The fix worked perfectly. zalienz and Don Ridley 2 Quote Link to comment Share on other sites More sharing options...
