stekdehey Posted November 21, 2021 Share Posted November 21, 2021 Hello everybody! I am Marco Heijstek from the Netherlands. i bought this week a second hand transit connect. And i am very happy about it! This Ford is my 7th Ford. My previous cars are, Ford Focus hatchback, Ford Focus CC (2x), Ford Puma (2x), Ford Escort convertible. I am planning on making my transit connect a full options van. mrtn 1 Quote Link to comment Share on other sites More sharing options...
Willygee Posted November 22, 2021 Share Posted November 22, 2021 Looks like my 16TC cargo but yours has the short wheelbase i think(no sliding door).What motor? Quote Link to comment Share on other sites More sharing options...
stekdehey Posted November 22, 2021 Author Share Posted November 22, 2021 I has the 1.6 Diesel engine and no sliding door Quote Link to comment Share on other sites More sharing options...
Willygee Posted November 23, 2021 Share Posted November 23, 2021 Out of curiosity does it take a while to get cabin heat in cold weather? I heard diesels take there time. Quote Link to comment Share on other sites More sharing options...
stekdehey Posted November 29, 2021 Author Share Posted November 29, 2021 Yes that's true. this morning it was 2 degrees outside (celsius). 35 degrees (fahrenheit). and it took about 10 minutes to get a bit less cold in the cabin. Quote Link to comment Share on other sites More sharing options...
Gideon Posted November 29, 2021 Share Posted November 29, 2021 Here in Canada, and probably the USA too, we only get the long wheelbase gas[petrol] engine models. My 2018 XLT [2.5L] starts easily in -10'C and cabin heat is noticeable fairly quick. But due to volume, it does take a while to feel warm/comfy inside. Quote Link to comment Share on other sites More sharing options...
Gideon Posted December 25, 2021 Share Posted December 25, 2021 (edited) Yesterday it was -16'C (about 4'F) all night and in morning. My 2018 wagon started-up no problem and engine reached operating temp in about 5 minutes. I have the electrically heated front windshield, but could not see any difference over 'normal' windshield for defrosting. Love the heated outside mirrors though. Also noticed wires going to the front washer jets under the hood. Seems they have some sort of heater that works with the electrical wind shield. Nothing in the owner's manual about it. HAPPY HOLIDAYS TO ALL, Please stay healthy and safe!! Edited December 25, 2021 by Gideon add details BSJBSJ 1 Quote Link to comment Share on other sites More sharing options...
BSJBSJ Posted December 26, 2021 Share Posted December 26, 2021 (edited) Hmmm. I wonder if the jets could be retrofitted. Ford Transit Connect Nozzle. Washer. Transit Connect Van; w/Heated Washers. W/heated - DT1Z17603D | Havre Ford, Havre MT Edited December 26, 2021 by BSJBSJ Quote Link to comment Share on other sites More sharing options...
G B L Posted December 27, 2021 Share Posted December 27, 2021 Where I live , Northern Vermont , if the right fluid Is used ( I use the -25 Rainex Fluid) heated nozzles are not necessary. The gas powered 2.5 starts to at least -25F as long as the the battery is in good shape. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted December 27, 2021 Share Posted December 27, 2021 The heated windshield will defrost much faster than a standard windshield. It draws about 40 amps. Check your fuses. Quote Link to comment Share on other sites More sharing options...
Gideon Posted January 4, 2022 Share Posted January 4, 2022 (edited) On 12/27/2021 at 1:29 AM, G B L said: Where I live , Northern Vermont , if the right fluid Is used ( I use the -25 Rainex Fluid) heated nozzles are not necessary. The gas powered 2.5 starts to at least -25F as long as the the battery is in good shape. Expand I live midway between Ottawa,Ont. and Montreal, Que. I mentioned the heated washer jets only because I noticed them. This van [as my previous one] was bought used. I'd never bother with asking for [pay extra for] the heated jets nor the heated windsheild - not worth the cost IMHO. Use quality washer fluid rated -40C and good to go. Also this 2018 van doesn't have a block-heater as my 2016 had. No big deal. I've a homemade "trickle charger" to keep battery OK and that's all I really need. I do however try to keep fuel at 1/2 or more to help keep out condensation and do occasionally use gas-line 'anti-freeze' [when temps go up/down like a yo-yo]. Edited January 4, 2022 by Gideon Quote Link to comment Share on other sites More sharing options...
G B L Posted January 6, 2022 Share Posted January 6, 2022 On 1/4/2022 at 12:16 AM, Gideon said: Also this 2018 van doesn't have a block-heater as my 2016 had Expand The new engines start really well, the most important thing on really cold starts is to let the warm up be long enough to protect the plastic parts that are now every where in the engine and transmission. Quote Link to comment Share on other sites More sharing options...
Gideon Posted January 9, 2022 Share Posted January 9, 2022 As I usually do only short trips [especially with all the pandemic restrictions we have], I use the old trick of blocking the grille to keep cold air from directly hitting the radiator and engine. It really helps the engine to reach and maintain operating temps. Quote Link to comment Share on other sites More sharing options...
mrtn Posted January 9, 2022 Share Posted January 9, 2022 Petrol models have active grille shutter. At least my 1.6 does. Check yours. Quote Link to comment Share on other sites More sharing options...
Gideon Posted January 10, 2022 Share Posted January 10, 2022 No active grille on my old 2016 nor on this 2018. Was it standard or an option?? If an option, I'm happy NOT to have it [one less 'gimmick']. FYI: In the late "50's", my father had a used MB-180 Diesel that had a curtain [in tracks] in front of radiator operated by a pull-chain below the dash. You could adjust as required, 0 to 100% coverage. That diesel was very reliable. Quote Link to comment Share on other sites More sharing options...
mrtn Posted January 10, 2022 Share Posted January 10, 2022 I don't know. It came with in mine. Works fine, the engine gets warm really quick. It would make even more sense in a diesel machine. Quote Link to comment Share on other sites More sharing options...
G B L Posted January 11, 2022 Share Posted January 11, 2022 On 1/9/2022 at 12:16 PM, mrtn said: At least my 1.6 does. Expand Once again you Eu guy's get offered all the cool stuff, like Diesel engines and adjustable head lights and grill shutters. Quote Link to comment Share on other sites More sharing options...
stekdehey Posted July 6, 2022 Author Share Posted July 6, 2022 Mu updates sofar outside: Bumper front and rear in body color mirrors in body color door handles in body color alloy wheels rear light reflectors above the rearlights rear view camera inside: steering wheel with cruise control and programmed Alpine halo 9 seats from a Ford B-max with seat heating (don't know if they are sold in the USA) Quote Link to comment Share on other sites More sharing options...
