OLDSCHOOLFOOL Posted January 26, 2020 Share Posted January 26, 2020 This is the biggest issue I have had with my "backup assist system". Quote Link to comment Share on other sites More sharing options...
Trident Posted January 28, 2020 Share Posted January 28, 2020 Hi Guys! Just signed up for the Forum after doing a search for this very issue. My problem was noted at test drive and thought it was just where the dealer plates had been hung close to the bumper sensor. That was early March 2019. Unfortunately it happened on my way home after taking delivery and happens almost every time reverse is selected. Each time the vehicle has been serviced, inspected I raise this issue and to date this has been looked at 5 to 6 times by 2 dealers over 10 months. In In October the Parking Aid Module was replaced under warranty and this did not cure the problem. I am now harassing the salesman that sold me the vehicle who has been helpful and has tried to resolve the issue within the dealership. 2 weeks ago I called Ford and was given a case number and advised to call my Service Manager. Today I called again and received a second case number and was told to expect contact from Fords local Area Manager within 24 hour. My Ford Dealer has been great, but as I see it they are stuck between a 'rock and a hard place'. They acknowledge and can replicate the problem, they have implemented what Ford has instructed them to do. And the latest I was told is that the problem is with Ford Engineering. They belive the problem is in the wiring harness, but it could take hours to find and repair and probably days to replace. My dealer will not expend time if Ford are not going to pay! Meantime, we have this issue that frankly 'Pisses me OFF!" every time I select reverse gear. I think i'll text the sales guy every time this happens, Piss him off too! Quote Link to comment Share on other sites More sharing options...
sKiZo Posted January 28, 2020 Share Posted January 28, 2020 (edited) I suppose next step would be to get the detector system replaced. Seems to me, that's a separate module mounted up behind the rear bumper cover? I know it was an option on the earlier models that could be added after delivery if you decided you couldn't live without it, and it 's a fairly simple procedure until the bolts seize with age. Then again, could be some way to adjust the sensitivity of the detector array once they get in there. Then again, could be your mechanics haven't bothered to read the book and doesn't know to apply some super secret code in the TC's brain ... Luck wit it. Worse comes to worse, just disconnect the thing - my grand daddy got er done with mirrors and hand signals, eh. ;-} Edited January 28, 2020 by sKiZo Quote Link to comment Share on other sites More sharing options...
davidparker Posted January 28, 2020 Share Posted January 28, 2020 There is a button to disable the system (for towing etc). While it won't fix the problem. It might make it a little less annoying. I hope you get a solution fast! Quote Link to comment Share on other sites More sharing options...
ATK Posted January 29, 2020 Share Posted January 29, 2020 Hello, everyone! I think the problem has been solved… My local Ford dealer said that a TSB had been published stating that the vehicle required reprogramming on the PAM module. The service was performed, and I have not had an issue since. Any word from anyone else? Quote Link to comment Share on other sites More sharing options...
sKiZo Posted January 29, 2020 Share Posted January 29, 2020 About what I figured though ... stoopid computers! Be interesting to find out when that bulletin was published. If it's been a while, shame on the dealer who's supposed to keep up with that stuff. If it's something they finally just came up with due to customer complaints, well ... way to go, team! Score one for the squeaky wheels of the world! Quote Link to comment Share on other sites More sharing options...
G B L Posted January 30, 2020 Share Posted January 30, 2020 On 1/29/2020 at 3:09 AM, sKiZo said: About what I figured though ... stoopid computers! Expand I think it is not the computer but the programer or algorithm. I think more of the people who write the algorithm's should actually drive the cars. Quote Link to comment Share on other sites More sharing options...
timsmish Posted January 30, 2020 Share Posted January 30, 2020 I have 2020 transit connect with the exact same issue Quote Link to comment Share on other sites More sharing options...
Aaron W Posted January 31, 2020 Share Posted January 31, 2020 I have 32 pictures of my transit doing this. It’s been to the shop 3 times for the problem but they can not duplicate it. It’s starting to piss me off. Quote Link to comment Share on other sites More sharing options...
BlackManta2020 Posted February 7, 2020 Share Posted February 7, 2020 (edited) Taking mine in this coming Monday for the TSB. I noticed that it was originally posted in November 2019? I had not heard from the dealer and/or Ford. We'll see.. UPDATE: Went in for service yesterday. Reprogramming complete in about 1.5 hours, no charge. No issues so far. Edited February 12, 2020 by BlackManta2020 Update: Reprogramming complete Quote Link to comment Share on other sites More sharing options...
Transit19 Posted May 2, 2020 Share Posted May 2, 2020 Any updates yet? Quote Link to comment Share on other sites More sharing options...
Gideon Posted January 28, 2021 Share Posted January 28, 2021 (edited) My 2016 LWB wagon (95000-Km) just started to give the same problem. Wonder if its loose wires/connectors in the bumper? Otherwise the back-up camera works aok. BUT the "P" switch does NOT work - it stays lit [as when turned off manually]. Edited January 28, 2021 by Gideon Quote Link to comment Share on other sites More sharing options...
