bocephus205 1 Posted February 16, 2019 google brought me here, I've searched this site and all over and can't find what center caps will work with our vans, this guy has exactly what I'm looking for but unfortunately he hasn't been active in a while. I found ford part number 4367100, but no one in the states carry these. anyone else found any that are compatible? Share this post Link to post Share on other sites
Fifty150 307 Posted February 16, 2019 1 ncranchero reacted to this Share this post Link to post Share on other sites
bocephus205 1 Posted February 24, 2019 https://www.amazon.com/dp/B075XHGZPQ/ref=cm_sw_em_r_mt_dp_U_boECCbXNXYRD9 Thought I had something cooking with these, had sourced some ford emblems made for the center as well, but the clips were to fat to fit between the hub and the wheel. Ended up going with Mr. Gasket 2486 dust caps, but they were smaller than they should have been by almost 2mm, took a cutoff wheel and cut some tabs in the back side and flared them out for a snug fit, had to pound them in with a hammer, hopefully they're road worthy. I'll post back in a couple months when I get this thing back going. Share this post Link to post Share on other sites
OLDSCHOOLFOOL 47 Posted February 28, 2019 On 2/23/2019 at 7:29 PM, bocephus205 said: https://www.amazon.com/dp/B075XHGZPQ/ref=cm_sw_em_r_mt_dp_U_boECCbXNXYRD9 Thought I had something cooking with these, had sourced some ford emblems made for the center as well, but the clips were to fat to fit between the hub and the wheel. Ended up going with Mr. Gasket 2486 dust caps, but they were smaller than they should have been by almost 2mm, took a cutoff wheel and cut some tabs in the back side and flared them out for a snug fit, had to pound them in with a hammer, hopefully they're road worthy. I'll post back in a couple months when I get this thing back going. I was trying to work something out like this with push thru center caps, trim rings & chrome lug nuts. What I was looking at was using some steel wheels at 65.1mm hub dia. with a push thru center cap. Theory was that the thickness of the center caps would reduce the diameter down close to 63.4mm (.030" material thickness) and retain the hub-centric aspect. My question to you is: What is the hub diameter on these wheels? Share this post Link to post Share on other sites
bocephus205 1 Posted March 2, 2019 the opening on the oem wheels was 63mm. I went ahead and polished the rear dust caps, so now I have shiny centers front/rear 1 davidparker reacted to this Share this post Link to post Share on other sites
K9transit 1 Posted May 7, 2019 I got these from the UK...OEM euro Ford center caps for my 2015 and 2017 TC's. Part number DT111A059AB (also known as DT1Z1130A). It's what they use on the steelies in europe. Perfect fit. Not sure about the older TC's. I'm getting rid of them along with the OEM amber fender markers shown in the picture, as well as some other cool Transit stuff 1 bocephus205 reacted to this Share this post Link to post Share on other sites
mdarren 4 Posted August 19, 2019 On 3/3/2019 at 7:37 AM, bocephus205 said: the opening on the oem wheels was 63mm. I went ahead and polished the rear dust caps, so now I have shiny centers front/rear Looks great. What polishing product did you use? 1 PhotoAl reacted to this Share this post Link to post Share on other sites
bocephus205 1 Posted September 29, 2019 On 8/19/2019 at 2:50 AM, mdarren said: Looks great. What polishing product did you use? $4 kit from Harbor Freight https://www.harborfreight.com/4-piece-buffing-kit-43657.html?_br_psugg_q=polishing+kit Share this post Link to post Share on other sites
OLDSCHOOLFOOL 47 Posted December 29, 2019 I am going to try the Mr. Gasket 2486 center caps. Married my stock black rims with some 245/50/16s and need something to cover the ugly centers. First criteria is they must be chrome, the black Euro caps are just butt ugly to me (just my opinion). Ordered four from Amazon for $25 so if they end up not working I haven't lost too much. I'm on the fence about adding some beauty rims (already have these) or not. They may end up making the whole look too "busy". Share this post Link to post Share on other sites
OLDSCHOOLFOOL 47 Posted January 10, 2020 (edited) Center caps arrived and look very good indeed. A little bit too small just as Bocephus205 says, but I have a different plan. Edited January 10, 2020 by OLDSCHOOLFOOL add text Share this post Link to post Share on other sites
Fifty150 307 Posted January 11, 2020 Really cool how you are doing so much to get the look you want. 1 OLDSCHOOLFOOL reacted to this Share this post Link to post Share on other sites
Fifty150 307 Posted January 11, 2020 On 12/29/2019 at 6:56 AM, OLDSCHOOLFOOL said: need something to cover the ugly centers And keep dirt, sand, grime, road salt, mud, pet hairs, and flu virus out of your hubs. Share this post Link to post Share on other sites
OLDSCHOOLFOOL 47 Posted January 11, 2020 20 hours ago, Fifty150 said: And keep dirt, sand, grime, road salt, mud, pet hairs, and flu virus out of your hubs. My '16 XLT cargo didn't come with any caps front or rear so I'm assuming it is a "sealed" system. Leastways I couldn't see any caps in the rear. but the view was partially obstructed with some spacers I have on there. Didn't look like it, but it was cold when I stuck the snow tires on and I was in a hurry. Anyways, the caps are purely for looks. Share this post Link to post Share on other sites
bocephus205 1 Posted January 19, 2020 On 1/10/2020 at 11:45 AM, OLDSCHOOLFOOL said: Center caps arrived and look very good indeed. A little bit too small just as Bocephus205 says, but I have a different plan. I made some cuts and flared the ends like this jeep center cap, but I was in a hurry to get it done, I'm sure a large enough o-ring would work as well Share this post Link to post Share on other sites
OLDSCHOOLFOOL 47 Posted January 20, 2020 1 hour ago, bocephus205 said: I made some cuts and flared the ends like this jeep center cap, but I was in a hurry to get it done, I'm sure a large enough o-ring would work as well Yes, I get what you did. I was a little confused at first, thinking you were placing them between the wheel and hub, which did not make too much sense to me. With the rim of the cap flared out.....have they all stayed in place? Share this post Link to post Share on other sites
bocephus205 1 Posted January 20, 2020 yea no Issues, it was a really tight fit after the modifications Share this post Link to post Share on other sites
