dinocarsfast Posted June 7, 2018 Share Posted June 7, 2018 (edited) I'm looking for All-Terrain tires and the best option I found so far is Yokohama 205/70r15 98H they are only 4% larger compared to stock. If 15" steel wheels fit over the front brakes does anyone know what vehicle I could get these wheels from used? Or will 215/65r16 98H fit? They are 6.7% taller Or the last option because they do not have the rated weight rating 215/60r16 95H, Edited June 7, 2018 by dinocarsfast Quote Link to comment Share on other sites More sharing options...
sKiZo Posted June 8, 2018 Share Posted June 8, 2018 Here's a good place to check on wheel specs ... https://www.wheel-size.com/size/ford/transit-connect/ The critical bits would be stud spacing (5x108), center bore (63.4), and wheel offset (52.5). Get close to those, and whatever wheel you select should work. It's my understanding that pretty much any Focus wheel will fit, but don't quote me on that. Quote Link to comment Share on other sites More sharing options...
G B L Posted June 10, 2018 Share Posted June 10, 2018 If it is a Gen 2 the 15" wheels won't clear the brakes. Quote Link to comment Share on other sites More sharing options...
MLB Posted August 5, 2018 Share Posted August 5, 2018 You only need to worry about the weight rating if you plan to haul near the 1600 lb weight limit. For most that never approach that, it's a needless concern. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 5, 2018 Share Posted August 5, 2018 33 minutes ago, MLB said: You only need to worry about the weight rating if you plan to haul near the 1600 lb weight limit. For most that never approach that, it's a needless concern. 7 fat guys in a wagon. Quote Link to comment Share on other sites More sharing options...
