Chris Moorhead Posted February 8, 2017 Share Posted February 8, 2017 Hi, just took my 2016 SWB Wagon to the dealership on 2/6/17 to have this recall work done, and the rear sliding doors now require excessive force to open them from the outside. This is the recall for the faulty pawl spring tab on the rear sliding door's latches. The recall number is 16S30 "SIDE DOOR LATCH REPLACEMENT". I would estimate it takes at least 4 times the strength to pull the outside door handle than it previously took. My pre-teen daughters now cannot open the doors. Has anyone else had this recall work done yet? I'm wondering if this is an issue with Ford's repair parts, or if my dealership has screwed up. Thanks for the feedback! Quote Link to comment Share on other sites More sharing options...
mrtn Posted February 9, 2017 Share Posted February 9, 2017 Mine has a similar problem but only in certain temperatures. The dealership has tried to adjust it but with no actual success. The handle unlatches the door but it takes a serious pull to get the door moving. Quote Link to comment Share on other sites More sharing options...
G B L Posted February 9, 2017 Share Posted February 9, 2017 I have been sent the first notice but not the next step, I am thinking that i will refrain till some thing breaks, right now the doors are perfect. Quote Link to comment Share on other sites More sharing options...
MLB Posted May 22, 2017 Share Posted May 22, 2017 I just bought a leftover 2016, does the recall apply to all models that year? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted May 22, 2017 Share Posted May 22, 2017 No. Mine was built in April 2016 and did not need the modification. Somewhere there is a post with the mfg dates that apply. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted May 23, 2017 Share Posted May 23, 2017 We don't carry passengers in the rear very often - I may wait until I have a problem before allowing the dealer to screw up the latches on it which work as they should right now. I called to see about getting the recall done and was told they needed a full day to do the work. Seems like a long time just to replace door latches? Don Quote Link to comment Share on other sites More sharing options...
