Beta Don Posted December 13, 2016 Share Posted December 13, 2016 I replaced the headlights on my 2014 TC today. First, as a credit to Ford (and probably because our TC's were all built in Europe) every stock halogen bulb in my wagon was made by Osram, which in my book is the best overall OEM bulb of them all. My standard upgrade on my other cars has always been to order me a new set of higher performance Osram's straight from Germany - Beware of ordering them from China and if you buy them locally, check to see that they're not from China. Like many other brand names, there are both a genuine article and Chinese knock-offs which are always inferior. The ones that came out of the car say 'Germany' right on them Fifty150 ordered a set of Street Cat LED H11's from Amazon and they are unlike any LED replacements I've ever seen. First, they came with a 'driver' which accepts any voltage from 9 VDC to 36 VDC and outputs exactly the correct stabilized voltage and current for the LED chips, no matter how much the input voltage may vary. This has got to make for both a brighter, more even light and a longer lasting bulb. Second, his replacements have a built-in 8,000 RPM fan which cools the LED chips. Again, this has got to increase the life of the bulbs IIRC he got a closeout price on the 2015 version rated at 4,000 lumens and 6000K color which is bright white, but not too far into the blue spectrum. A standard halogen bulb is around 1,350 to 1,500 lumens and the color is quite yellow, usually around 3000K. I bought the 2016 version of the Street Cat H11's which are now advertised to use Philips brand chips and they are now rated at 4,800 lumens or a bit more than triple the amount you get from an equivalent H11 halogen bulb. This isn't to say that you'll have triple the light down the road because other factors limit the useful light, but they are noticeably brighter . . . . and whiter A link to the ones I bought - https://www.amazon.com/Headlight-Conversion-Upgraded-version-Philips/dp/B01LXO0W17/ref=sr_1_2?ie=UTF8&qid=1481579843&sr=8-2&keywords=street+cat+h11 They are not a 10 minute install, IMO - We spent at least an hour in total, but then I was changing both high and low beams. The space inside the dust cap is small and my fingers are large, but I managed to get them inserted correctly and my wife was able to twist them to lock them in the headlight. I mounted the little driver boxes nearby with double stick trim tape. Like Fifty150 I left the dust caps off - I think you could probably cut a notch in them to allow the wires to come out (necessary because the driver won't fit inside) and get the dust caps back on, but with them off the ventilation must be better and the LED assembly with fan is rated as waterproof For the high beams, which are 65 watt H-9's I opted to replace those with PIAA Xtreme White halogens. *Supposedly* these give you 120 watts of light from just 65 watts of power which makes it sound like they are almost twice as bright (I take that with a few grains of salt) and they are 4150K in color, which is very white for a halogen bulb. These are popular replacements because they are so powerful and so white, but in low beam applications many reviewers report they only last for a year or two. I don't think I would choose them for your low beams (They cost about the same as the LED's anyway) but for high beam use, they should last a long time. We'll see. They *are* quite white . . . . nearly as white as the LED's to the naked eye The LED's do light up the road much better - Low beams don't appear to reach much (if any) farther than before - It does look like I could raise them just a bit and I probably will, but the amount of light on the road in front of me is noticeably increased. The high beams are just . . . . WOW! They really do reach farther and are much brighter than before. They light up everything! I'll get some pictures from out on the road and post them in the next few days - So far I'm very happy with the upgrade. Probably the best $100 I've spent on it so far Don Slonie 1 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 13, 2016 Share Posted December 13, 2016 LED lighting is only getting better and better. Cars should simply be built with LED. My 3rd brake lamp & license plate light came with OEM LED. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 13, 2016 Share Posted December 13, 2016 26 minutes ago, Beta Don said: I bought the 2016 version of the Street Cat H11's which are now advertised to use Philips brand chips and they are now rated at 4,800 lumens or a bit more than triple the amount you get from an equivalent H11 halogen bulb. This isn't to say that you'll have triple the light down the road because other factors limit the useful light, but they are noticeably brighter . . . . and whiter A link to the ones I bought - https://www.amazon.com/Headlight-Conversion-Upgraded-version-Philips/dp/B01LXO0W17/ref=sr_1_2?ie=UTF8&qid=1481579843&sr=8-2&keywords=street+cat+h11 You should write an Amazon review and post pics. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 13, 2016 Share Posted December 13, 2016 23 hours ago, Beta Don said: Fifty150 ordered a set of Street Cat LED H11's from Amazon and they are unlike any LED replacements I've ever seen. IIRC he got a closeout price on the 2015 version rated at 4,000 lumens and 6000K color which is bright white, but not too far into the blue spectrum. They are not a 10 minute install, IMO - We spent at least an hour in total, but then I was changing both high and low beams. Depending on who is doing it, how familiar you are with performing the task, and how fast you can work, it could be 10 minutes. 10 minutes per side, or 10 minutes per lamp? Varies. After all, it's really not a lot of work, because you're not taking anything apart. Simply removing the rubber dust cap, removing the OEM lamp, and then inserting the LED lamp. Beta Don only spent 15 minutes per lamp (1 hour for 4). That's not bad. On other cars, you actually have to have tools to remove different pieces, in order to get to the lamps. On my F-150, the entire headlamp unit has to be removed from the body. I first bought the 2015 version with 4000 lumen as an Amazon Lightning Deal. Those were installed as low beam. Then I purchased the 2016 version with 4600 lumen for the high beams. Amazing how bright they are. I will never drive with yellow halogen on any car, ever again. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 14, 2016 Share Posted December 14, 2016 On 12/12/2016 at 4:06 PM, Beta Don said: Street Cat LED H11's from Amazon and they are unlike any LED replacements I've ever seen. Don, Check out the LED I am using in the F-150. Lamp head has a heat sink. Fan is detachable. Lamp & fan are powered separately. LED driver/ballast converts power from OEM headlamp socket to power headlamp and fan. This makes for easy trouble shooting and maintenance, if the need should arise. And allows you to change parts separately if need be. If the LED fails, just change that. If the fan stops working, replace with new fan. Switch the different parts around, so that you can isolate the problem. Different LED technology. These are CREE, as opposed to Philips operate at 7200 lumen (1800 lumen per LED), and function as low beam & high beam in one unit. But with the high beams on, I see everything I need to see when I'm off-road. No more 100W KC lights. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 15, 2016 Share Posted December 15, 2016 Big difference is that with the H13 in the F-150, both high beam and low beam combined, I only have 7200 lumen. With the Transit Connect, I can have 9600 lumen in the low beam, and 9600 lumen in the high beam, for a combined 19200 lumen. But there is not much that I can do about that, since it's almost impossible to change the headlamp housing to a different size or type. Quote Link to comment Share on other sites More sharing options...
MLB Posted June 24, 2017 Share Posted June 24, 2017 The bulbs aren't available on Amazon anymore. I find the brights just fine, can you replace the low beams with LED and leave the highs alone or have to replace both? (assuming there are other options in LED's now) Quote Link to comment Share on other sites More sharing options...
Beta Don Posted June 24, 2017 Author Share Posted June 24, 2017 The LED's I installed are for low beams only - I still have the OEM bulbs in the high beams Don Quote Link to comment Share on other sites More sharing options...
mrtn Posted June 24, 2017 Share Posted June 24, 2017 My friend installed LED bulbs in place of factory HID. Much brighter but also too bright in front of the car. Almost unbearable. He loves it tho. Quote Link to comment Share on other sites More sharing options...
jrm223 Posted June 27, 2017 Share Posted June 27, 2017 On 6/24/2017 at 11:03 AM, MLB said: The bulbs aren't available on Amazon anymore. I find the brights just fine, can you replace the low beams with LED and leave the highs alone or have to replace both? (assuming there are other options in LED's now) Searching "Street Cat H11" shows this page. It says 4000 lumens each, so I guess they're old-stock 2015 version. Amazon Street Cat H11 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 31, 2017 Share Posted August 31, 2017 Street Cat isn't the only seller. Street Cat is one of those sellers based in China that sells all kinds of weird things on amazon.com, with the products handled and shipped by amazon.com. They source the product from whichever manufacturer, then arrange for the items to be warehoused and shipped by amazon.com. Street Cat does not actually produce the item themselves. They are just selling to you. Look on amazon.com for H11 LED. You will find tons of options. Within the last year, literally, prices have dropped and lots of people are selling the same exact headlamps, all made in the same factory in China, then branded with their label. Compare the different lamps, and you will notice that they are mostly the same lamp. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 31, 2017 Share Posted August 31, 2017 Sponsored HIKARI LED Headlight Bulbs Conversion Kit -H11(H8,H9),CREE XHP50 9600lm 6K Cool White,2 Yr Warranty by HIKARI $ 69 99 $139.99Prime Get it by Friday, Sep 1 4.3 out of 5 stars 1,191 Best Seller Sponsored Zdatt 12000LM H11 LED Headlight Bulbs Super Bright 100W H8 H9 Fog Lights Conversion Kits 360 Degree(4 Sides) Lighting Lamps for Car Light Replacement-3000K Yellow/6000K Cool White/8000K Blue(2 Pack) by Zdatt $ 39 99 $99.99Prime Only 5 left in stock - order soon. 4.1 out of 5 stars 119 Sponsored LASFIT H11/H8/H9/H16 LED Headlight Kits-Flip COB Chips-72W 7600LM 6000K-Hi/Lo Beam/Fog Light Bulbs by LASFIT $ 31 99 $49.99Prime| FREE One-Day Get it by Tomorrow, Aug 31 FREE One-Day Shipping on qualifying orders over $35 4.3 out of 5 stars 251 CougarMotor H11 (H8, H9) LED Headlight Bulbs All-in-One Conversion Kit,7200 Lumen (6000K Cool White) by Cougar Motor $ 42 99 $46.99Prime Get it by Friday, Sep 1 4.3 out of 5 stars 1,030 BEAMTECH H11 LED Headlight Bulb, 50W 6500K 8000Lumens Extremely Brigh H8 H9 CSP Chips Conversion Kit by BEAMTECH $ 35 99 Prime In Stock More Buying Choices $35.99(2 new offers) 4.3 out of 5 stars 152 HIKARI LED Headlight Bulbs Conversion Kit -H11(H8,H9),CREE XHP50 9600lm 6K Cool White,2 Yr Warranty by HIKARI $ 69 99 $139.99Prime Get it by Friday, Sep 1 More Buying Choices $55.99(8 used offers) 4.3 out of 5 stars 1,191 JDM ASTAR G1 8000 Lumens Extremely Bright H11 H8 COB LED Headlights, Xenon White by JDM ASTAR $ 49 99 $129.99Prime| FREE One-Day Get it by Tomorrow, Aug 31 More Buying Choices $39.99(5 used & new offers) 3.9 out of 5 stars 853 JDM ASTAR 1300 Lumens Extremely Bright 3030 Chipsets H11 LED Bulbs for DRL or Fog Lights, Xenon White (H11) by JDM ASTAR $ 22 99 $49.99Prime| FREE One-Day Get it by Tomorrow, Aug 31 More Buying Choices $19.54(5 used & new offers) FREE One-Day Shipping on qualifying orders over $35 3.6 out of 5 stars 134 Win Power H11(H8 H9) LED Headlight CREE Bulbs Conversion Kits + Canbus (1 Pair)-2 Year Warranty by Win Power $ 29 99 $69.99Prime| FREE One-Day Get it by Tomorrow, Aug 31 More Buying Choices $29.99(3 new offers) FREE One-Day Shipping on qualifying orders over $35 4 out of 5 stars 497 Auxbeam LED Headlights F-S2 Series H11 LED Headlight Bulbs with 2 Pcs of H11 LED Conversion Kits 72W 8000LM Bridgelux COB Chips Fog Light - 1 Year Warranty by Auxbeam $ 29 99 Prime| FREE One-Day Get it by Tomorrow, Aug 31 FREE One-Day Shipping on qualifying orders over $35 4.2 out of 5 stars 572 YITAMOTOR 2x Extremely Bright Chipsets 60W H11 LED Bulbs with Projector for DRL or Fog Lights, 6000K Xenon White by YITAMOTOR $ 12 99 Prime| FREE One-Day Get it by Tomorrow, Aug 31 More Buying Choices $9.74(1 used offer) FREE One-Day Shipping on qualifying orders over $35 and 3 more promotions 2.9 out of 5 stars 145 Best Seller simdevanma LED Automobile Headlight Bulbs with Advanced LED Chip and All-in-One Conversion kit-80W/8,000LM/6,000K-2 Year Warranty(Upgraded Version) (H11(H8,H9)) by Simdevanma $ 49 99 $99.99Prime| FREE One-Day Get it by Tomorrow, Aug 31 More Buying Choices $42.49(2 used offers) 4.6 out of 5 stars 448 ANNT 2 Pcs CREE LED Headlight Bulbs F-16 Series Conversion Kit -H11 (H8, H9) COB Chips Fog Light, 8000LM 6.5K Cool White IP67 by ANNT $ 15 99 $69.99Prime Get it by Friday, Sep 1 More Buying Choices $13.33(1 used offer) 3.7 out of 5 stars 44 JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H11 LED Bulbs with Projector for DRL or Fog Lights, Xenon White by JDM ASTAR $ 19 99 $34.99Prime| FREE One-Day Get it by Tomorrow, Aug 31 More Buying Choices $19.99(2 new offers) FREE One-Day Shipping on qualifying orders over $35 3.6 out of 5 stars 481 JDM ASTAR Extremely Bright CSP Chipsets H11 H8 LED Bulbs for DRL or Fog Lights, Xenon White by JDM ASTAR $ 29 99 $69.99Prime Get it by Friday, Sep 1 More Buying Choices $29.99(2 new offers) 4.3 out of 5 stars 42 OPT7 Fluxbeam LED Headlight Kit w/ Clear Arc-Beam Bulbs - H11 (H8, H9) - 60w 7,000Lm 6K Cool White CREE - 2 Yr Warranty by OPT7 $ 87 99 Prime 4.1 out of 5 stars 4,724 H11(H8,H9) 6000K 8000 Lumens LED Headlight Bulbs Conversion Kit ,Leakind N7 Series Plug and Play Crystal Clear Cool White Lamp, 80W,3 Year Warranty by Leakind $ 31 99 $49.99Prime| FREE One-Day Get it by Tomorrow, Aug 31 FREE One-Day Shipping on qualifying orders over $35 4.2 out of 5 stars 88 Philips H11 Standard Halogen Replacement Headlight Bulb, 1 Pack by Philips $ 8 44 $9.64Prime| FREE One-Day Get it by Tomorrow, Aug 31 More Buying Choices $2.53(12 used & new offers) FREE One-Day Shipping on qualifying orders over $35 and 1 more promotion 4.2 out of 5 stars 1,936 SYLVANIA H11 SilverStar zXe High Performance Halogen Headlight Bulb, (Contains 2 Bulbs) by Sylvania $ 33 44 Prime| FREE One-Day Get it by Tomorrow, Aug 31 More Buying Choices $14.59(33 used & new offers) FREE One-Day Shipping on qualifying orders over $35 and 1 more promotion 3.8 out of 5 stars 2,601 Zdatt 9600LM Super Bright 80W H8 H9 H11 Led Headlights Bulbs All-in-One Conversion Kit 6000K Fog Lights for Car Lamp Replacement, Xenon White-2 Pack by Zdatt $ 22 99 $99.99Prime In Stock More Buying Choices $22.99(2 new offers) 3.9 out of 5 stars 31 Best Seller Zdatt 12000LM H11 LED Headlight Bulbs Super Bright 100W H8 H9 Fog Lights Conversion Kits 360 Degree(4 Sides) Lighting Lamps for Car Light Replacement-3000K Yellow/6000K Cool White/8000K Blue(2 Pack) by Zdatt $ 39 99 $99.99Prime Only 5 left in stock - order soon. More Buying Choices $33.14(3 used & new offers) 4.1 out of 5 stars 119 Sponsored Zdatt 11000LM H8 H9 H11 LED Headlight Bulbs Conversion Kits CREE XHP50 Chip Replacement Fog Lights 3000K Amber/6000K White/8000K Blue with Canbus System-2 Yr Warranty by Zdatt $ 52 99 $149.99Prime Only 10 left in stock - order soon. 4.5 out of 5 stars 13 Sponsored SiriusLED Extremely Bright COB LED Chip 8000 Lumens Headlights Fog Lights Bulb Conversion Kit H11 H8 6000K Xenon White (2017 Version) by SiriusLED $ 39 95 Prime| FREE One-Day Get it by Tomorrow, Aug 31 4 out of 5 stars 44 Sponsored PUSHIDUN LED Headlight H11 Bulbs Conversion Kits 6,000K -1 Year Warranty (Upgraded Version) by PUSHIDUN $ 49 95 $95.37Prime Only 10 left in stock - order soon. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 31, 2017 Share Posted August 31, 2017 H11/(H8/H9) LED Headlight Bulbs Conversion Kit (Upgraded version) COB LED Chips 80W 8000LM 6000K per Set - Low Beam/ High Beam/ Fog Light Bulbs (by STCT Street Cat) by STCT Street Cat $ 49 99 $65.99Prime Only 4 left in stock - order soon. 3.7 out of 5 stars 48 Sponsored HIKARI LED Headlight Bulbs Conversion Kit -H11(H8,H9),CREE XHP50 9600lm 6K Cool White,2 Yr Warranty by HIKARI $ 69 99 $139.99Prime Get it by Friday, Sep 1 4.3 out of 5 stars 1,191 Sponsored Zdatt 11000LM H8 H9 H11 LED Headlight Bulbs Conversion Kits CREE XHP50 Chip Replacement Fog Lights 3000K Amber/6000K White/8000K Blue with Canbus System-2 Yr Warranty by Zdatt $ 52 99 $149.99Prime Only 10 left in stock - order soon. 4.5 out of 5 stars 13 Sponsored LASFIT H11/H8/H9/H16 LED Headlight Kits-Flip COB Chips-72W 7600LM 6000K-Hi/Lo Beam/Fog Light Bulbs by LASFIT $ 31 99 $49.99Prime| FREE One-Day Get it by Tomorrow, Aug 31 FREE One-Day Shipping on qualifying orders over $35 4.3 out of 5 stars 251 Best Seller Sponsored Zdatt 12000LM H11 LED Headlight Bulbs Super Bright 100W H8 H9 Fog Lights Conversion Kits 360 Degree(4 Sides) Lighting Lamps for Car Light Replacement-3000K Yellow/6000K Cool White/8000K Blue(2 Pack) by Zdatt $ 39 99 $99.99Prime Only 5 left in stock - order soon. 4.1 out of 5 stars 119 Sponsored SiriusLED Extremely Bright COB LED Chip 8000 Lumens Headlights Fog Lights Bulb Conversion Kit H11 H8 6000K Xenon White (2017 Version) by SiriusLED $ 39 95 Prime| FREE One-Day Get it by Tomorrow, Aug 31 4 out of 5 stars 44 Sponsored PUSHIDUN LED Headlight H11 Bulbs Conversion Kits 6,000K -1 Year Warranty (Upgraded Version) by PUSHIDUN $ 49 95 $95.37Prime Only 10 left in stock - order soon. Sponsored SiriusLED X3 Series Extremely Bright... $ 59 95 3.5 out of 5 stars2 HIKARI LED Headlight Bulbs Conversion... $ 69 99 $119.99 4.3 out of 5 stars1,190 N7 H11/H8/H9 80W LED Headlight Bulbs... $ 28 00 H11 H8 LED Fog Light Bulb 80W 1600... $ 18 99 Quote Link to comment Share on other sites More sharing options...
