доверять, но проверить
Fifty150
I see that some people are reporting great mileage.  Mileage which is displayed on the vehicle dashboard.  I have always used the old fashion method of miles driven, divided by amount of fuel consumed.
No science here.  I went from full tank baseline to the next fuel refill.  I just decided to use my tablet computer to read the OBD II port to see what the vehicle's computer sees.  An Amazon Fire ($35) with Torque Lite (the free version).  So I'm reading the same display as what most of you are reading.  According to the car's computer, I'm getting great mileage.  The last tank was 28.5 MPG.  But in the real world, I drove 177.1 miles, which consumed 11.385 gallons of fuel.  15.555 MPG.
You guys can believe what you want.  Truth is, some people must be getting the great mileage estimated by the car's computer.  Just not me.  And apparently, I'm not alone.  Others have also reported poor mileage.
Anyone else looking over the fuel purchases and comparing it to the odometer?
Edited by Fifty150
I did when I first got my wagon. The discrepancy was not too bad: 19.5 MPG real life vs 20.4 MPG computer reading.
Not nearly as good as the 28 MPG range reported by some on this forum, but I do a have a heavy foot, and do very little long distance highway travelling, which would substantially alter my readings, even without changing shoes.
I could go up or down in height by 1/2" when I change shoes.  I remember Prince use to wear those high heel boots because he was so short.  I'll tell my "when I met Prince" stories some other time.
Image result for prince high heel boots
I don't believe much of anything, but I don't know how to prove the odometer reading one way or another.  Being a bit of a geek, I do the math in my head based upon a reset trip meter after every tank of fuel and whatever the pump tells me I put into the tank.  Both are probably a little off, but close enough for jazz.  Nowhere close to 28 MPG, but so far, more than 20 mpg.  I'm pretty happy after feeding a full size van.
Here's what Fuelly.com reports, for about five thousand fillups of Ford Transit Connects with 2.5 liter four-cylinder gas engines.  So there's obviously a huge range, close to 2:1, in the actual fuel economy that folks are achieving.  They don't report what folks' trip computers are reading.
I've only had my van long enough for one fillup... so no real-world data from me, yet.
Screenshot-2018-12-19 Ford Transit Connect MPG - Actual MPG from 77 Ford Transit Connect owners.png
It also depends on who is doing the reporting, and their driving styles.  I doubt if any fleet users have an employee posting their numbers for the entire fleet.  So anyone who drives 8 - 10 hours a day, low speed, engine idling, stop & go....is for the most part, not reported.  Guys like me who get very poor mileage, are not represented in those statistics.
I see that someone reported 10 MPG.
Just interesting that the window sticker mileage is an "EPA" mileage estimate.  I suppose that's true with every vehicle.  Real world driving varies from person to person.  We all have different driving styles, and road conditions.
I have never personally seen the window sticker mileage on any car I've owned or driven.
Didn't MythBusters do a few episodes on mileage?
The EPA test is a standardized test route.  I forget the details of it, but it's changed several times over the decades.  Most of the changes were to make it more realistic, but it's still done on a stationary dyno.  Tailpipe analysis is done to measure fuel consumption (count the carbon atoms, basically, which tells you how much fuel when in.), they don't rely on the gauges or a refueling system.
I've had cars that I routinely beat the EPA numbers on (at least on the highway), and cars that were much much worse.
