isellford Posted July 25, 2009 Share Posted July 25, 2009 Acccording to the owners manual, Ford does not recommend any type of towing with the Transit Connect. Quote Link to comment Share on other sites More sharing options...
Roadstergal Posted September 14, 2009 Share Posted September 14, 2009 Not even a Class I hitch? Even a Miata can haul a motorcycle on a light trailer with a Class I. :P Quote Link to comment Share on other sites More sharing options...
isellford Posted September 15, 2009 Author Share Posted September 15, 2009 This is a quote right out of the owners manual " WARNING: Never tow a trailer with this vehicle. Your vehicle is not equipped to tow. No towing packages are available through an authorized dealer" Quote Link to comment Share on other sites More sharing options...
hkr701 Posted November 30, 2009 Share Posted November 30, 2009 I have a bicycle rack that fits into a trailer hitch on the Transit Connect. I also have the reverse sensing system. Is there a way to disable the system? Is there a fuse that I can pull out? I can't seem to find a fuse for this system in the owners manual. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
lenovo Posted December 5, 2009 Share Posted December 5, 2009 On 11/30/2009 at 1:51 PM, hkr701 said: I have a bicycle rack that fits into a trailer hitch on the Transit Connect. I also have the reverse sensing system. Is there a way to disable the system? Is there a fuse that I can pull out? I can't seem to find a fuse for this system in the owners manual. Any help would be appreciated. This site in the UK says the Transit will tow 2800 kgs http://www.intervans.co.uk/vans/ford/transit-connect-swb/ Dimensions - Transit Connect SWB Overall Length: 4275mm Overall Width: 1795mm Overall Height: 1815mm Wheelbase: 2664mm Turning Circle: 11m kerb-to-kerb Loading Height: 598mm Rear Door Height: 1145mm Rear Door Width: 1293mm Load Height: 1193mm Load Length: 1760mm Load Width: 1226 / 1490mm Load Volume: 2.8m3 Gross Payload: 648kg Gross Vehicle Weight: 2040kg Kerb Weight: 1392kg Towing Limit: 2840kg Fuel Tank Capacity: 60 /13.2 litres Quote Link to comment Share on other sites More sharing options...
PetrosA Posted December 6, 2009 Share Posted December 6, 2009 Ford is going to have to deal with this issue better than it is with this CYA approach. We're driving the same Connect as they do in Europe and we have access to the same information as the European drivers do. U-Haul is even selling a hitch for the TC at this point. If Ford really is serious about the One Ford concept, then they need to get on the ball. Quote Link to comment Share on other sites More sharing options...
wahoonc Posted January 3, 2010 Share Posted January 3, 2010 On 12/5/2009 at 10:07 PM, lenovo said: This site in the UK says the Transit will tow 2800 kgs http://www.intervans.co.uk/vans/ford/transit-connect-swb/ Dimensions - Transit Connect SWB Overall Length: 4275mm Overall Width: 1795mm Overall Height: 1815mm Wheelbase: 2664mm Turning Circle: 11m kerb-to-kerb Loading Height: 598mm Rear Door Height: 1145mm Rear Door Width: 1293mm Load Height: 1193mm Load Length: 1760mm Load Width: 1226 / 1490mm Load Volume: 2.8m3 Gross Payload: 648kg Gross Vehicle Weight: 2040kg Kerb Weight: 1392kg Towing Limit: 2840kg Fuel Tank Capacity: 60 /13.2 litres That works out to around 6400#, however the EU spec version uses a manual transmission and as best I can tell the US only gets an automatic. On 12/6/2009 at 12:27 AM, PetrosA said: Ford is going to have to deal with this issue better than it is with this CYA approach. We're driving the same Connect as they do in Europe and we have access to the same information as the European drivers do. U-Haul is even selling a hitch for the TC at this point. If Ford really is serious about the One Ford concept, then they need to get on the ball. Agreed, because I won't buy one if I cannot at least tow 1500# or a bit more. Aaron Quote Link to comment Share on other sites More sharing options...
MINICooperS Posted March 3, 2010 Share Posted March 3, 2010 (edited) On 1/3/2010 at 11:50 AM, wahoonc said: That works out to around 6400#, however the EU spec version uses a manual transmission and as best I can tell the US only gets an automatic. Agreed, because I won't buy one if I cannot at least tow 1500# or a bit more. Aaron I would hope the TC would tow more than my 1995 Saturn SL2 5-spd with a 1.9L Twin Cam I-4 at 240,000 miles. I'm trying to upgrade and this is at least what I need to tow. If not, I'll go back to shopping for a 4WD Jeep Patriot 2.4L 5-spd manual for less money and factory aluminum wheels. Edited March 3, 2010 by MINICooperS Quote Link to comment Share on other sites More sharing options...
LittleChickie1 Posted April 6, 2010 Share Posted April 6, 2010 Your conversion factor is off. A kilogram is 2.2 lbs; so 2800 Kg = 1370 lbs or thereabouts. No? That should enable me to tow a small pram (boat) and motor on a trailer. I now tow with a Honda CRV and can't even tell it's back there. I really want the diesel engine and plan to build a mini-micro motor home on the Connect. Just enough for a couple days out fishing. Need some insulation to keep from freezing; some water storage; few other things. Has anyone seen one tricked out as an RV yet? fishingal432 1 Quote Link to comment Share on other sites More sharing options...
tone007 Posted April 13, 2010 Share Posted April 13, 2010 On 4/6/2010 at 4:19 AM, LittleChickie1 said: Your conversion factor is off. A kilogram is 2.2 lbs; so 2800 Kg = 1370 lbs or thereabouts. No? 1Kg = 2.2lbs, so that means a kilogram is heavier than a pound (the equivalent of 2.20462262lbs, to be exact.) 2800Kg * 2.2 = 6160lbs. Either way, if you go by the European specs it should handle it, but if Ford US says no, it might not be in your best interest. Quote Link to comment Share on other sites More sharing options...
4DThinker Posted June 15, 2010 Share Posted June 15, 2010 This concerns me as well. When I first looked at a TC I took my tape measure to see what would fit inside. My motorcycle is too long and too tall (windscreen) so I asked the salesperson about towing it. He quickly stated that a tow package would surely come along as they have them in Europe, but there were none available now. Quote Link to comment Share on other sites More sharing options...
Joe Posted June 27, 2010 Share Posted June 27, 2010 I cannot believe this. In France you see these vehicles all over the place in fact my wifes family owns one with a trailer hitch no less. They use the vehicle for there business. I am also frustrated that ford only offers one engine and transmission combination, How ridiculous. I only hope that it is to gage the American market and that soon VERY SOON they will offer what we want. This Vehicle would be perfect for me if it had a Slightly more powerful engine Towing capacity, I would also like to carry 8 feet of wood along the floor of the truck. A little less utilitarian in the front driver seat, I could end up being there for hours in my line of work. To think driving six hours to a customer in this thing on the highway does not give me the warm fuzzies. I foot would be to the floor the whole ride and i would also be concerned with the comfort of the seat as well. I am not asking for the rear seats to be more comfortable I only carry passengers on very rare occasions. Well I have aired my comments and or concerns Thank you. Quote Link to comment Share on other sites More sharing options...
Flying Media Posted June 28, 2010 Share Posted June 28, 2010 Got Sprinter?? Quote Link to comment Share on other sites More sharing options...
Joe Posted June 28, 2010 Share Posted June 28, 2010 Oh come on now. The Transit connect could use more power and a little more room without being a sprinter!! Quote Link to comment Share on other sites More sharing options...
Flying Media Posted June 28, 2010 Share Posted June 28, 2010 On 6/28/2010 at 3:17 AM, Joe said: Oh come on now. The Transit connect could use more power and a little more room without being a sprinter!! power sure..... room it works for me i have done a few 3 hour oneway trips and it rides fine and i dont feel like i have ben beaten along the way Quote Link to comment Share on other sites More sharing options...
Joe Posted June 29, 2010 Share Posted June 29, 2010 I was Just at the dealership today talking with a salemen. He read a part of a manual to me, and his exact words were (Towing is not recomend with this vehicle) so its not that it cannot tow ford does not recomend it. Does this mean if I should tow a little trailer, and somthing were to happen to the engine and or transmision that ford will still honer there warranty. After all they say its not recommended not that you cannot or do not do it period. Quote Link to comment Share on other sites More sharing options...
cbeddow Posted August 29, 2010 Share Posted August 29, 2010 On 4/13/2010 at 6:40 PM, tone007 said: 1Kg = 2.2lbs, so that means a kilogram is heavier than a pound (the equivalent of 2.20462262lbs, to be exact.) 2800Kg * 2.2 = 6160lbs. Either way, if you go by the European specs it should handle it, but if Ford US says no, it might not be in your best interest. I agree with your conversion factor; however, 6000 plus pounds towing capacity just does make any sense. My interpretation of the european chart is : towing limit (2840 kg) minus gross vehicle weight (2040 kg) = 800 kg. 800 kg times 2.2 lbs/kg = 1760 lbs. This sounds realistic to me. Smartcarp 1 Quote Link to comment Share on other sites More sharing options...
cabmeister Posted August 29, 2010 Share Posted August 29, 2010 I have had the Hitch from Uhaul fitted to my TC , a class 3 hitch with 2" receiver. Although I will not be towing anything often .I felt that although it reads that Ford does not recomend towing why on earth does the tc have built in holes and welded nuts to accept a hitch . I did , just last weekend try the trailer towing thing . I have a Northern tool 5ft. X 8ft. single axle with rear drop down gate which has a 1 7/8" receiver. it was loaded with cabinetry around 700 lbs. the van was loaded with my install tools with 2 passengers and has a roof rack fitted. the trip was 125 mls one way mainly interstate flat land (florida) a few inclines (sunshine skyway bridge ) etc. Cruise control was set to 65 , OD was set on . Also A/C was running . The TC took it in its stride ,no sweat . I was counting when the transmission had to down shift , 3 times in total . It passed my personal test of being able to handle a trailer for what I personally want . Miles to gallon went from my normal 24 - 25 down to 21 which i think is to be exspected. Oh! I had only 2 , 272 miles on the vehicle. Quote Link to comment Share on other sites More sharing options...
BIKE SAG Posted September 2, 2010 Share Posted September 2, 2010 On 8/29/2010 at 5:28 PM, cabmeister said: I have had the Hitch from Uhaul fitted to my TC , a class 3 hitch with 2" receiver. Although I will not be towing anything often .I felt that although it reads that Ford does not recomend towing why on earth does the tc have built in holes and welded nuts to accept a hitch . I did , just last weekend try the trailer towing thing . I have a Northern tool 5ft. X 8ft. single axle with rear drop down gate which has a 1 7/8" receiver. it was loaded with cabinetry around 700 lbs. the van was loaded with my install tools with 2 passengers and has a roof rack fitted. the trip was 125 mls one way mainly interstate flat land (florida) a few inclines (sunshine skyway bridge ) etc. Cruise control was set to 65 , OD was set on . Also A/C was running . The TC took it in its stride ,no sweat . I was counting when the transmission had to down shift , 3 times in total . It passed my personal test of being able to handle a trailer for what I personally want . Miles to gallon went from my normal 24 - 25 down to 21 which i think is to be exspected. Oh! I had only 2 , 272 miles on the vehicle. Quote Link to comment Share on other sites More sharing options...
BIKE SAG Posted September 2, 2010 Share Posted September 2, 2010 I too have a TC and I am towing with it. I have to keep the speed down and not use the cruise control. Don't expect to travel fast and let the TC slow down when pulling a grade. It will keep up with the 18 wheelers on the hills. I have over 15,000 miles on our TC in the past three months. We use it for our business and do a lot of traveling with it. We pull a 6X 12 enclosed trailer with 300lbs tong weight. Trailer gross close to 1600#. Most of our miles are towing. You can visit our website and see what we actual do and how we are using our TC. We have a lot of photos showing that we do tow whit it. I also live in FL and have traveled to N. GA with it. I will be leaving soon taking our operations to Las Vegas NV for Interbike. jimCognito 1 Quote Link to comment Share on other sites More sharing options...
ncranchero Posted September 2, 2010 Share Posted September 2, 2010 What's your website address???????????? Quote Link to comment Share on other sites More sharing options...
BIKE SAG Posted September 3, 2010 Share Posted September 3, 2010 On 9/2/2010 at 7:46 PM, ncranchero said: What's your website address???????????? Website address is www.bikesag.com Quote Link to comment Share on other sites More sharing options...
Connect owner UK Posted November 14, 2010 Share Posted November 14, 2010 Fords UK actualy list a TC towbar in their sales catalog, part number 1-449-603 Remeber though, over here we do not have the petrol engine and auto transmision, we have 3 different 5 speed manual diesels, 75, 90, and 110. The specs for the 110 version engine is" Grossing at 2,340kg, T230 can handle a gross payload of 898kg and haul a braked trailer grossing at 800kg" Download an e-brouchure on the UK TC here UK spec TC Also, look at the ford accesory brochure, is has a few nice TC accesories. Quote Link to comment Share on other sites More sharing options...
Steve Posted December 25, 2010 Share Posted December 25, 2010 On 9/2/2010 at 4:08 PM, BIKE SAG said: I too have a TC and I am towing with it. I have to keep the speed down and not use the cruise control. Don't expect to travel fast and let the TC slow down when pulling a grade. It will keep up with the 18 wheelers on the hills. I have over 15,000 miles on our TC in the past three months. We use it for our business and do a lot of traveling with it. We pull a 6X 12 enclosed trailer with 300lbs tong weight. Trailer gross close to 1600#. Most of our miles are towing. You can visit our website and see what we actual do and how we are using our TC. We have a lot of photos showing that we do tow whit it. I also live in FL and have traveled to N. GA with it. I will be leaving soon taking our operations to Las Vegas NV for Interbike. Got my Curtis hitch installed through the dealer at purchase. Will be towing first time tomorrow - 4x6 enclosed utility trailer. Probably 800-900 lb gross. We have 11k in 5 mos. And love it as a family car which my wife uses to haul around her large paintings. BIKE SAG 1 Quote Link to comment Share on other sites More sharing options...
Steve Posted January 3, 2011 Share Posted January 3, 2011 Towed a 4x6 trailer 1000 miles this past week with absolutely no problems. Could hardly tell it was back there. Got 21 mpg loaded and 25 mpg on the return trip. This is better mileage than we used to get pulling this same trailer with a Toyota Matrix (same HP). The only wrinkle was needing to get the powered taillight converter. Installer had not used the required powered unit, the Transit's computer did not like it, and turn signals would flash fast and then no turns. No fuse was blown - after a new keystart, the system was back up, and with the proper 3:2 converter the lights work like a charm. Quote Link to comment Share on other sites More sharing options...
