Connecting in Transit Posted October 11, 2020 Share Posted October 11, 2020 @Double Nickels did you end up clearing your adaptive learning table? Can you let me know how that's done? I don't have a code reader but wondering if the scanners at auto parts stores are capable enough/if I could convince them to do it for me for free. I just bought my TC with 56k miles on it and did a transmission flush today. Feeling like it might be a good idea to have it relearn the shifting to adjust to my driving style. Quote Link to comment Share on other sites More sharing options...
G B L Posted October 11, 2020 Share Posted October 11, 2020 I think forscan will do it, I use scan tool. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted October 11, 2020 Share Posted October 11, 2020 Forscan can reset the tables. I don't know if there are any problems doing this. I use the transmission sport mode for better shifting. Quote Link to comment Share on other sites More sharing options...
Double Nickels Posted November 4, 2020 Share Posted November 4, 2020 I didn't clear the transmission adaptive learning table. Because I bought the car new. I'm the only driver. Besides, it's adaptive. It will eventually learn your driving style. Quote Link to comment Share on other sites More sharing options...
69DropTop Posted March 16, 2022 Share Posted March 16, 2022 I'm trying to check the fluid on my 2017 in may end up cycling it out. I do not have the same level plug as in the pictures that I have seen so far in this thread. I'm guessing this bolt is the level bolt for mine. Can anyone confirm? Quote Link to comment Share on other sites More sharing options...
G B L Posted March 16, 2022 Share Posted March 16, 2022 7 minutes ago, 69DropTop said: I'm guessing this bolt is the level bolt for mine You are correct. Quote Link to comment Share on other sites More sharing options...
69DropTop Posted March 16, 2022 Share Posted March 16, 2022 4 minutes ago, G B L said: You are correct. Awesome, thanks for the confirmation! Quote Link to comment Share on other sites More sharing options...
69DropTop Posted March 17, 2022 Share Posted March 17, 2022 I removed the full plug, it was full but the fluid was dark. I can't say for sure but I might have even seen a little sparkly on the paper towel. I am debating if it's even a good idea to flush the trans now because you hear people talking about when you put new fluid in a transmission with old bad fluid that it can cause the trans to go out. I was thinking of just going ahead and doing one drain and fill cycle, driving it, and then seeing what things look like. Any thoughts or suggestions? Quote Link to comment Share on other sites More sharing options...
dgotc Posted September 25, 2022 Share Posted September 25, 2022 On 3/16/2022 at 4:21 PM, 69DropTop said: I'm trying to check the fluid on my 2017 in may end up cycling it out. I do not have the same level plug as in the pictures that I have seen so far in this thread. I'm guessing this bolt is the level bolt for mine. Can anyone confirm? I have the same drain plug and it is 10mm allen socket, I believe. I did mine recently and it worked out great. I did two drainings of 3 quarts each and the 3rd draining I let it completely drain. This resulted in using about 1 extra quart of fluid, but made putting the drain plug back in with thread sealant less messy. I didn't take the drain plug to full specified torque because it just didn't feel good, so I got it to about 100 inch-pounds. Still tight and sealed well. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted January 23, 2024 Share Posted January 23, 2024 On 3/16/2022 at 5:46 PM, 69DropTop said: I am debating if it's even a good idea to flush the trans now because you hear people talking about when you put new fluid in a transmission with old bad fluid that it can cause the trans to go out. It's never a good idea, in any car, to simply leave old fluid in the transmission and wait for the transmission to reach the end of it's useable service life. Lifetime transmission fluid for the lifetime of the transmission. You can leave the fluid in the transmission until the transmission fails. Don't worry about it. Transmissions don't fail until after the warranty expires. Change the fluid. Amazon is selling Valvoline at a decent price. Quote Link to comment Share on other sites More sharing options...
