Camperconnect Posted October 18, 2019 Share Posted October 18, 2019 (edited) Hi I have a 2010 transit connect that I want to upgrade the wheels on. I know that the previous generation Focus wheels fit it, but Im more interested in the modern wheel options. Are there any modern ford wheels that will fit on it with correct center bore, and offset? I like the wheels on newer focus, fusion, and fiesta. Thanks Edited October 18, 2019 by Camperconnect Quote Link to comment Share on other sites More sharing options...
mrtn Posted October 19, 2019 Share Posted October 19, 2019 Here's PCD info and a compatibility list: CLICK Camperconnect 1 Quote Link to comment Share on other sites More sharing options...
Camperconnect Posted February 13, 2020 Author Share Posted February 13, 2020 Does anyone know if the new generation American Ford Fusion and Focus wheels fit 2010-2013 American TC? I see bolt specs are the same but Im concerned about rubbing, with the wider and taller tire width, than stock wheels. Quote Link to comment Share on other sites More sharing options...
OLDSCHOOLFOOL Posted February 15, 2020 Share Posted February 15, 2020 On 2/13/2020 at 3:36 PM, Camperconnect said: Does anyone know if the new generation American Ford Fusion and Focus wheels fit 2010-2013 American TC? I see bolt specs are the same but Im concerned about rubbing, with the wider and taller tire width, than stock wheels. Your choice of tire size is going to determine if you have a rubbing issue (not the wheels). What size tires were you considering? You haven't mentioned that. Quote Link to comment Share on other sites More sharing options...
Camperconnect Posted February 15, 2020 Author Share Posted February 15, 2020 17 hours ago, OLDSCHOOLFOOL said: Your choice of tire size is going to determine if you have a rubbing issue (not the wheels). What size tires were you considering? You haven't mentioned that. Any of the factory size tires on the focus and fusion 18" wheels. Quote Link to comment Share on other sites More sharing options...
OLDSCHOOLFOOL Posted February 15, 2020 Share Posted February 15, 2020 1 hour ago, Camperconnect said: Any of the factory size tires on the focus and fusion 18" wheels. A 2017 Focus calls for 235/40/18 whereas 2010 TC says 205/65/15. The difference in those two sizes is the 18" tire is .1" shorter (dia.) but 20mm (3/4") wider. Shouldn't cause any rubbing issue at least not with that exact size. I just picked 2017 Focus out of the air because you weren't specific. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted February 15, 2020 Share Posted February 15, 2020 2 hours ago, OLDSCHOOLFOOL said: A 2017 Focus calls for 235/40/18 whereas 2010 TC says 205/65/15. The difference in those two sizes is the 18" tire is .1" shorter (dia.) but 20mm (3/4") wider. Shouldn't cause any rubbing issue . . . . . . . . . . assuming the offset of both wheels is close to the same Don OLDSCHOOLFOOL 1 Quote Link to comment Share on other sites More sharing options...
sKiZo Posted February 15, 2020 Share Posted February 15, 2020 2017 Focus is a 55mm offset. 2010 TC is 53mm offset. Center bore is 63.4 for both. Eh ... close enuf, eh. Humphrey's Van and OLDSCHOOLFOOL 1 1 Quote Link to comment Share on other sites More sharing options...
OLDSCHOOLFOOL Posted February 16, 2020 Share Posted February 16, 2020 14 hours ago, sKiZo said: 2017 Focus is a 55mm offset. 2010 TC is 53mm offset. Center bore is 63.4 for both. Eh ... close enuf, eh. Both you and Don are correct. Two sites that give very good info on this subject: wheel-size.com tiresize.com Quote Link to comment Share on other sites More sharing options...
mrtn Posted February 16, 2020 Share Posted February 16, 2020 2 hours ago, OLDSCHOOLFOOL said: Both you and Don are correct. Two sites that give very good info on this subject: wheel-size.com tiresize.com Add this in your list, it also has cross-reference which other cars have this size for cross-shopping of wheels and possible tire sizes: Quote Link to comment Share on other sites More sharing options...
Camperconnect Posted February 22, 2020 Author Share Posted February 22, 2020 On 2/15/2020 at 1:41 PM, OLDSCHOOLFOOL said: A 2017 Focus calls for 235/40/18 whereas 2010 TC says 205/65/15. The difference in those two sizes is the 18" tire is .1" shorter (dia.) but 20mm (3/4") wider. Shouldn't cause any rubbing issue at least not with that exact size. I just picked 2017 Focus out of the air because you weren't specific. What about ford fusion wheels and tires, 17" and 18".The tires are bigger than focus. Im assuming that the factory tire size will be the same all styles. I felt the space between the TC factory wheels and the strut. They is very little space availble. Quote Link to comment Share on other sites More sharing options...
MLB Posted September 3, 2020 Share Posted September 3, 2020 A fusion is a heavier car than the focus and comes with heavier wheels (from what I read). Better match for TC's load hauling. Quote Link to comment Share on other sites More sharing options...
Aukai Posted April 27, 2025 Share Posted April 27, 2025 I have a 2010 Ford Transit Connect and I’m confused. Some sites say that the bolt pattern is 5X108 and some say 5X114.3. Which is it? Quote Link to comment Share on other sites More sharing options...
mrtn Posted April 27, 2025 Share Posted April 27, 2025 5x108 mm. Quote Link to comment Share on other sites More sharing options...
drum_buster Posted January 3 Share Posted January 3 Anyone on this particular thread who has upsized their gen 1 connect (15" rims to 16 or 17 or 18) can you comment on improvements and drawbacks. I don't want to oversize from factory specs too much, but I do want to get a nicer alloy rim and if that means a slightly wider tire, i'm ok with that also. If I can re-program my 2013 connect computer to compensate for a larger diameter tire, I would consider that, but I'm trying to determine if an increased rim size will really gain me anything - aside from perhaps a better selection of tire. Quote Link to comment Share on other sites More sharing options...
