Doc Hoy Posted October 28, 2018 Share Posted October 28, 2018 I originally put this is the wrong topic. I have a 1TC which was giving me fits which finally wound up as a top end problem. I opted for an engine swap from a wrecked Focus. When I got the truck back, it had substantially more power than the original motor (when it worked properly) and substantially more power than my 2012 1TC. In doing some reading, I have learned that the 2.0 Duratec motor came in two versions. 1 produced 136 HP and the other produced 140 HP. But the improvement in performance of this 1TC can't be explained by a mere four HP. So are there other versions of the 2.0 or the later 2.3 that fit in this truck that are hotter engines? I can break the tires loose on this truck from a standing start. I am having to be careful not to twist an axle or hose up the transmission. Quote Link to comment Share on other sites More sharing options...
G B L Posted October 28, 2018 Share Posted October 28, 2018 Cool ! Do you know if the engine went in with all the sensors or did the installer put your sensors on it? Could you have gotten a 2.3? Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 29, 2018 Share Posted October 29, 2018 What you are describing in power difference is not 4 HP. Unless your old engine was in such poor condition that it underperformed. Quote Link to comment Share on other sites More sharing options...
Doc Hoy Posted October 29, 2018 Author Share Posted October 29, 2018 GBL....Don't know. The engine seems to interface with the computer properly. No odd alerts and such. 150.... Agree and that would have to be true of the other 1TC I own and operate daily. The two trucks had essentially identical performance before the 2012 began to act up. BTW, I got them mixed up in my lead in post. The 2012 is the one with the engine swapped out. The 2011 will less miles on it runs fine. Sorry for the confusion. Quote Link to comment Share on other sites More sharing options...
Doc Hoy Posted November 9, 2018 Author Share Posted November 9, 2018 Update...... Performance of my 1TC with the replaced engine has changed. It now runs exactly (to my ability to compare) the same as the 2011 1TC. I don't have to be careful not to break the tires loose any more. It doesn't drop into a lower gear so quickly when accelerating at speed anymore. It doesn't seem to have substantially more power than the 2011 any more. There are still no alerts on the dash. Sounds right. Seems to be fine. I only have one potential explanation: When I was reading the articles on the internet about swapping the injectors, I read several times about removing the battery cables from the battery and shorting them together to discharge capacitors in the computer allowing the computer to "relearn the shift points for the transmission." When I did this after the injector change, I did note the process of the computer learning the shift points. Seemed to be a little off for the first coupla dozen miles, then settled down to good even performance. So I am wondering if there are other things the computer has to "learn" about a new engine. Maybe mixture, or timing advance. Anyone smart on the computer? Quote Link to comment Share on other sites More sharing options...
G B L Posted November 10, 2018 Share Posted November 10, 2018 The scanner I have will stop the learning process or erase the history. Your engine going through a learn process to fit the Pcm of the Tc would totally fit your experience. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted November 10, 2018 Share Posted November 10, 2018 Relearning the drive cycle is normal. Happens every time you disconnect the battery. Quote Link to comment Share on other sites More sharing options...
Doc Hoy Posted November 10, 2018 Author Share Posted November 10, 2018 Guys, I am thinking that is what happened. It makes sense given the performance chips marketed to improve the performance of engines through no other means than changing how the computer operates the engine. I had a 2003 BMW Z3M with a Dinan performance chip that added about 60 horse power. The downside is that it was too much power for the frame. It pulled the weldments for the differential carrier away from the frame. $3,000.00 repair. Quote Link to comment Share on other sites More sharing options...
WillMartin Posted November 12, 2018 Share Posted November 12, 2018 For what it's worth, my 2010 will spin its front wheels at times. I think the tires may be old and hard, and it generally happens on a wet road. It sometimes happens on a dry road, which makes me wonder if maybe it is relearning. It had a mostly flat battery right before I got it. I don't mind slow, so I hope it's learning to make less power. Quote Link to comment Share on other sites More sharing options...
jrm223 Posted November 12, 2018 Share Posted November 12, 2018 If you're worried about tires slipping off the line, I don't think you'll ever want a TC2, haha. Mine has constantly spun the tires since the day I bought it brand new - and I don't do it on purpose. The 2.5L & 6 speed has more than enough torque off the line to spin brand new tires on dry pavement. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted November 12, 2018 Share Posted November 12, 2018 On 11/12/2018 at 2:52 PM, jrm223 said: The 2.5L & 6 speed has more than enough torque off the line to spin brand new tires on dry pavement. Expand . . . . and it will do so at about half throttle! - If you're in a hurry from a standing stop, you've got to be reaaaallllly careful!! Don jrm223 1 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted November 13, 2018 Share Posted November 13, 2018 You can feel the torque steer on the Gen2 also. I just did not think the little engine had enough power to do that. I discovered that on my test drive. Dealership salesgirl was wide eyed, and speechless, as I chirped the tires and the steering pulled hard on take off. I looked at her with bewilderment, and said, "first time in a minivan, do they all do that?" jrm223 1 Quote Link to comment Share on other sites More sharing options...
G B L Posted November 13, 2018 Share Posted November 13, 2018 The electric steering assist is set up to center the wheels, which amplify's the torque steer. Had a 1978 Olds Tornado, that had torque steer! Quote Link to comment Share on other sites More sharing options...
Doc Hoy Posted November 14, 2018 Author Share Posted November 14, 2018 So does anyone know what things the computer is programmed to "learn" about a new performance feature such as a replaced engine or performance impacting work done to an engine or to "relearn" perhaps even on a continuing basis? I have two data points about shift points: 1. I read several time (or listened to a video) that the computer relearns shift points 2. I know that the patterns in shifting of my 2012 1TC changed over a period of about four days after the motor was replaced. So in addition to shift points, what other things does the computer monitor and adjust for? Quote Link to comment Share on other sites More sharing options...
