rjisq Posted September 6, 2018 Share Posted September 6, 2018 You We have 10 2016 transit connects in our fleet. 3 of these vehicles have approximately 70,000 miles and all 3 are making a clicking noise coming from the front end, similar to what bad cv joints make. Is this a common issue with these vehicles? Quote Link to comment Share on other sites More sharing options...
PhotoAl Posted September 6, 2018 Share Posted September 6, 2018 Haven’t seen it discussed on this board as a problem. Are the boots torn? A torn boot will cause a CV joint to fail. Quote Link to comment Share on other sites More sharing options...
sKiZo Posted September 6, 2018 Share Posted September 6, 2018 Could be cv's, brakes, bearings, etc ... Maybe some more info. This noise happen rolling straight, at certain speeds, during breaking, when turning? Quote Link to comment Share on other sites More sharing options...
rjisq Posted September 7, 2018 Author Share Posted September 7, 2018 (edited) Thank you for the reply. Happens when vehicles make turns at lower speeds as well as when backing up straight. Boots are not torn. Edited September 7, 2018 by rjisq Quote Link to comment Share on other sites More sharing options...
G B L Posted September 7, 2018 Share Posted September 7, 2018 How far from straight do you have to turn to get the noise? Have you had some one walk beside the car when you go forward and turn at slow speed? The fact that it is a clicking noise says cv joint. What kind of service are the Tc's in? Quote Link to comment Share on other sites More sharing options...
mdarren Posted September 7, 2018 Share Posted September 7, 2018 Wheel bearing is a common issue. Try to inspect it. Quote Link to comment Share on other sites More sharing options...
