spare tire reel 2014 connecr
eddwal50
I you get the TC up so you can have good access you could find a way to unload it and free up the cable.  I bet if you loosen the mount  you will be able to free the cable.
Good Luck and keep us posted.
  • 5 weeks later...
the reel is fucked turns out if you wind up the reel to far something in the reel breaks tried to lower the reel after putting weight on it reel turns cable does not move ford should have put a cable stop on the cable have purchased a used reel assembly will be replacing it on the weekend ford used 1/4 rivits to secure hose reel in place starting in 2014 thru 2018 vans so when I replace the reel I will add a cable stop
9 hours ago, eddwal50 said:
the reel is fucked turns out if you wind up the reel to far something in the reel breaks....
The manual for my 2015 Wagon has this caution on page 243....
"Do not raise the spare wheel carrier
without the wheel attached. Damage can
occur to the winch mechanism if lowered
without a wheel attached."
I might still have a spare reel if I can find it.  My van didnt have a spare tire when I got it and I needed the removable part on the end of the cable that the spare bolts to.  I wont be home until mothers day weekend.
PM me if you are interested, I will give it away for shipping costs if I can find it.
  • 3 months later...
