Fifty150 Posted October 13, 2016 Share Posted October 13, 2016 In case anyone needs to remove the rear liftgate panel, here are photos of what mine looks like. I hope it helps with your custom installations and modifications. mrtn 1 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 13, 2016 Author Share Posted October 13, 2016 Driver side channel going up alongside the rear window. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 13, 2016 Author Share Posted October 13, 2016 Passenger side channel going up alongside the rear window, with OEM wiring. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 13, 2016 Author Share Posted October 13, 2016 License plate lamp housing is attached by 4 bolts. Beta Don 1 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 13, 2016 Author Share Posted October 13, 2016 Note the positioning of snap in tabs on the inside of the liftgate panel so that you don't break yours when removing. Captainobvious 1 Quote Link to comment Share on other sites More sharing options...
mrtn Posted October 13, 2016 Share Posted October 13, 2016 While you're at it: spray Tectyl wax inside the bottom edge of the door to prevent condensation to cause rusting there. Quote Link to comment Share on other sites More sharing options...
G B L Posted October 13, 2016 Share Posted October 13, 2016 I use a Canadian product Crosion Free for the rust protection. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted October 22, 2016 Share Posted October 22, 2016 Thanks for the photos. I notice when I lift the tailgate, my parking lights come on automatically and so does the license plate light. It should be pretty easy to install an LED light on the inside of the liftgate and with a mercury switch so it only lights when the liftgate is raised, it will make a very useful light to illuminate the cargo area when loading or unloading Don Plyman 1 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 22, 2016 Author Share Posted October 22, 2016 Sounds like all that you need will be a couple of small LEDs. I like the ones on the head of a hollow bolt. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 22, 2016 Author Share Posted October 22, 2016 But if you tap into the license plate light wiring, those lights you install on the interior will be on whenever you drive at night. Think about tapping into the interior lamps instead. Quote Link to comment Share on other sites More sharing options...
Beta Don Posted October 23, 2016 Share Posted October 23, 2016 That's what the mercury switch is for - Unless the liftgate is up which closes the mercury switch, there's no power to the LED's - Tapping into the interior lights would require running a wire from them into the liftgate - Using a mercury switch is so much simpler . . . . especially since I already have both the lights and the switch in my junkbox! Don Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 23, 2016 Author Share Posted October 23, 2016 6 hours ago, Beta Don said: . . . . especially since I already have both the lights and the switch in my junkbox! Don't we all have a collection of useful stuff, that we're not using? Quote Link to comment Share on other sites More sharing options...
