Ford Transit Connect Manual Transmission Kit
  • 3 months later...
  • 1 year later...
  On 12/28/2013 at 6:55 AM, zombiechad said:
I am selling my complete Ford Transit Connect Manual Transmission swap kit. Most of the major components are from a 2008-2011 Ford Focus. The mechanical and wiring is almost identical between the 2008-2011 Focus and the 2010-2013 Ford Transit Connect. The Transit Connect specific parts were imported from Europe.
I assembled all these parts to do a manual transmission swap in a 2010 Transit Connect. I did extensive research on the subject. These parts will all bolt right in and there is just a small wiring change required pertaining to the neutral safety switch required to make it all work. The goal of the swap was to make it more fun to drive, lower maintenance costs, and improve fuel economy.
It includes:
1. Manual Transmission with all mounts and sensors 3.56 Final Drive (from 2009 Focus w/ 60k miles)
2. Manual transmission wiring harness and ECU (from 2009 Focus w/ 60k miles)
3. Shift linkage with cables (from 2009 Focus w/ 60k miles)
4. Clutch and brake pedal assembly (from 2009 Focus w/ 60k miles)
5. Jack shaft and CV shafts (from 2009 Focus w/ 60k miles)
6. Clutch and Flywheel (from 2009 Focus w/ 60k miles)
7. Clutch reservoir and hydraulic lines (from 2009 Focus w/ 60k miles)
8. Shifter surround, boot, and know (from LHD German Transit Connect, New parts)
9. Electronic copies of the wiring diagrams of both the Transit Connect, an Automatic Ford Focus, and a Manual Ford Focus.
I am asking $700. This is what I paid for the transmission by itself.
Expand
  • 3 years later...
