JQG4 Posted January 19, 2022 Share Posted January 19, 2022 Hi all I have a 2016 LWB with 122k miles. It runs great, other than an occasional really bad vibration at low idle. Moving to neutral reduces vibration, which makes me think motor mount. Has any one else changed mounts because of a similar issue? Any idea on costs? Thanks! Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted January 19, 2022 Share Posted January 19, 2022 Check for misfires using a scan tool. You may have an ignition problem that can be solved with plugs and/or coil packs. JQG4 1 Quote Link to comment Share on other sites More sharing options...
Willygee Posted January 19, 2022 Share Posted January 19, 2022 Also check for carbon build up in the throttle body. Any CES illuminated? Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted January 20, 2022 Share Posted January 20, 2022 With 122,000 miles, if those are the original spark plugs, I would bet on a misfire. Even without a scan tool to check for misfires, the first thing that I would do is change the plugs and coil packs. Quote Link to comment Share on other sites More sharing options...
JQG4 Posted January 21, 2022 Author Share Posted January 21, 2022 Thanks everyone! Quote Link to comment Share on other sites More sharing options...
zalienz Posted January 23, 2022 Share Posted January 23, 2022 I have a 2017 work TC with the same mileage and I also have a bad vibration at idle. While a misfire could definitely cause the symptom, I'm more inclined to think weak engine mounts. My spark plugs were replaced at 120k and there was no difference in the vibration. Today's computer systems are very sensitive to misfire conditions as when a cylinder misfires, the unburned fuel goes out the exhaust and can internally melt catalytic converters if it continues. The oxygen sensors will quickly detect this and illuminate the check engine light. If consistent - think dead coil or spark plug etc, the check engine light will flash to get your attention. I have not had my engine mounts replaced, but plan on bring the issue up at my next service interval, which is coming up soon. I'll re-post after a diagnosis. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted January 23, 2022 Share Posted January 23, 2022 I agree that it would take a significant misfire to cause hard idling. The rear engine/transmission mount greatly dampens vibrations. I installed a hard rubber performance-type mount and this created unacceptable vibration and rattle at idle. This motor mount is very easy to inspect and change. Two bolts are easy to access once the vehicle is raised. Look for broken rubber in the center section. Quote Link to comment Share on other sites More sharing options...
JQG4 Posted January 28, 2022 Author Share Posted January 28, 2022 I just had it at the garage. Of course it's an intermittent vibration and of course they couldn't duplicate it. Motor mounts and belts all look fine. This is a place I generally trust. They checked the vehicle end to end, and all I ended up with was a $71 shop fee. The attached video might give you a better idea of sound, though it's short to fit the 10 Meg limit. 20211111_135118.mp4 Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted February 1, 2022 Share Posted February 1, 2022 Do you have any accessories running (fan, AC...etc)? Did the shop scan for any codes? You may have to drive it until it gets bad enough to diagnose. Quote Link to comment Share on other sites More sharing options...
Michael C Posted March 15, 2022 Share Posted March 15, 2022 My 2012 was vibrating Bad, while van shook so much I was sure I had a major engine problem. Replaced all 3 engine mounts, labor was $225. now I can hear motor at all, extreme change. Quote Link to comment Share on other sites More sharing options...
ajh25 Posted December 19, 2023 Share Posted December 19, 2023 (edited) My 2020 Connect is making this same noise. The dealer has had it for a couple days now searching for the issue. Did you ever figure this one out? Edited December 19, 2023 by ajh25 Quote Link to comment Share on other sites More sharing options...
andipoll Posted February 11 Share Posted February 11 I had the vibration issue with my 2013 TC after about 3 years. Started with vibration at idle, then got progressively worse until the only time it didn't vibrate badly was when cruising in top gear. I was convinced it was something bad, but turned out to be 3 broken engine mounts. Once changed out, the vibs disappeared totally. However I now have a vibration at idle when the vehicle first starts in the morning, but once the motor warms up it disappears. I'm in Florida so the engine doesn't really get that cold most of the year. I put my OBD on it and it showed a red x against the EGR. After a few weeks I decided to change the EGR out. It has made no difference, and the red x is still there against the EGR. I'm using an Autel AL319 OBDII, which shows a green tick when I run a ready test. I had no codes showing before I changed the EGR, and 500 miles afterwards it's still not throwing any codes, just the red x. Anyone any ideas? Quote Link to comment Share on other sites More sharing options...
