Misfire limp mode
hallam109
My 2014 transit connect diesel has just suddenly developed a misfire while driving at 40mph it has gone into limp mode won’t go above 2000 Revs and service engine now is on also the engine management light is on and the traction control light
Any ideas
These types of problems require a scan tool to read the error codes. It's impossible to troubleshoot without this information. The scanners can be expensive. Forscan is free but requires a $40-75 adapter. This has been discussed on the forum so search Forscan for info.
On 8/22/2021 at 3:26 PM, hallam109 said:
connect diesel
Injectors maybe but not the plugs., I
If the clutch was slipping it would rev past 2000.
You need to start with a scan tool or forscan!
Keep us in the loop, I am not much help as we have no diesels here.
Not necessarily. My friend just experienced this in his Accord. Went to limp mode every time at 80 mph, no other symptoms, no noticeable clutch slip but it still turned out to be just that.
