hallam109 Posted August 22, 2021 Share Posted August 22, 2021 My 2014 transit connect diesel has just suddenly developed a misfire while driving at 40mph it has gone into limp mode won’t go above 2000 Revs and service engine now is on also the engine management light is on and the traction control light Any ideas Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted August 22, 2021 Share Posted August 22, 2021 These types of problems require a scan tool to read the error codes. It's impossible to troubleshoot without this information. The scanners can be expensive. Forscan is free but requires a $40-75 adapter. This has been discussed on the forum so search Forscan for info. Quote Link to comment Share on other sites More sharing options...
Double Nickels Posted August 23, 2021 Share Posted August 23, 2021 I don't recommend it, but you could start with the plugs. At least change them. Quote Link to comment Share on other sites More sharing options...
mrtn Posted August 23, 2021 Share Posted August 23, 2021 Could be something as simple as the clutch slipping. Quote Link to comment Share on other sites More sharing options...
G B L Posted August 24, 2021 Share Posted August 24, 2021 On 8/22/2021 at 3:26 PM, hallam109 said: connect diesel Injectors maybe but not the plugs., I If the clutch was slipping it would rev past 2000. You need to start with a scan tool or forscan! Keep us in the loop, I am not much help as we have no diesels here. Quote Link to comment Share on other sites More sharing options...
mrtn Posted August 25, 2021 Share Posted August 25, 2021 On 8/24/2021 at 6:32 AM, G B L said: If the clutch was slipping it would rev past 2000. Not necessarily. My friend just experienced this in his Accord. Went to limp mode every time at 80 mph, no other symptoms, no noticeable clutch slip but it still turned out to be just that. Quote Link to comment Share on other sites More sharing options...
