Brake Seizing
2017 Ford Transit Connect cargo.
30,000 miles.
Two weeks ago, the front left caliper seized when stopping for traffic on  the highway.  The traffic was stop and go, but not anything heavy, and not anything i have not driven in before. I pulled off the highway, and the caliper retracted when the brake cooled. Note: there was smoke coming from the pads, and the acrid smell of burning brake pads.  It took about 3 hours to cool down.
I replaced the caliper and flexible hose to that wheel. Also replaced both driver and passenger side brake pads, and flushed the system brake fluid.
The new caliper and pad squeaks, so i tried a few heavy stops on back roads, and the squeaking stopped.  When i pulled into my garage about 15 miles later  i could smell burning pads, and the driver side steelie boiled water that i flicked on it. The passenger side was not hot — i could place my hand on it..
I took the van to the dealer, but they couldn’t duplicate the issue. When i drove home from the dealer and parked in the garage, the drivers side steelie seemed hotter.  Traffic home was light, and i didnt’ do any heavy braking.
Also note that I am a very easy on the brakes during normal driving.
What could cause this issue?
—ty
Edited by Tyzap
willygee: concur on driving hard and pulling into dealership,, but would like to do some additional troubleshooting before i do that. The dealership i took the van to didn’t seem to interested in my business. Van is not under warranty.  It has been three years since i bought it.
GBL:
I live in DC.  The van has not seen any major snow, slush, etc. It is not a daily driver, i metro to work, and the van is mostly garaged. I can’t remember ever driving it in snow. I drive it weekends, and a few times during the week. It may go 3 days without a drive, max.
Pics of disk attached. Note, there is no pulsing when i apply brakes. There was no pulsing  before the seize, or after i replaced the caliper, pads, and hose. The pics are before the caliper replacement.  Replacement caliper was sourced from NAPA.
Also note that when i now apply the brakes at a stop, then release and press the gas, there is a creak from the brakes. I am assuming this is because the pads have not fully released from the disk.
There is that white material on the edge of the disk….
Edited by Tyzap
You have replaced all of the suspect mechanical components. You may have a problem components related to ABS, traction control or hill assist. You need to a scan tool (Forscan or other professional scan tool) to check for codes to see if the ABS or other systems are being activated. A message should appear in the center message center if these functions are activated. But there are valves in the Hydraulic Control Unit (HCU) that control the flow of brake fluid to each wheel and maybe one of them are faulty or getting a bad signal from the ABS control unit.
Edited by Don Ridley
Don is correct about the scan tool.
When you drive it does the left disk end up hotter every time ?
If it does then you need to take a ride and get the brakes hot and get home and lift the wheel while it is hot to feel if there is drag. if so crack the brake line to see if you get a spurt of fluid and a release of the drag.  Because you replaced the hose it would be very rare to get a bad hose, it would point to the ABS unit.  If you slack the line to hose connection first you would test the hose also.
The plot thickens, keep us posted.
Edited by G B L
  • 3 months later...
Issue is finally fixed.
I replaced the used OEM rotors, pads, left side (aftermarket) caliper and (aftermarket)hose, and determined it was either the aftermarket caliper or the aftermarket hose.
All parts are now OEM, and the issue is resolved.
I will note the aftermarket hose was shorter than the OEM, and was slightly bent at the connection to the caliper most likely due to turning to the left. The OEM hose install was so much easier than the aftermarket.  I installed both the OEM caliper and OEM hose at the same time. I just wanted the van fixed, and didn’t want to bled the systems twice.
This update is a bit late, but i don’t drive the van all that much, and before posting i wanted to make sure the van was fixed.
Thanks everyone.
  • 3 years later...
I have a 2020 Transit Connect wagon with 51K miles.  Front brakes started seizing at speeds over 60 mph and took to mechanic.  Diagnosed piston/caliper problems, replaced in both front brakes as well as drums and pads.  Seemed fixed with driving around town and short trips on highway.  Drove on interstate today for over an hour and same seizing occurred at speeds over 60mph.  Probably burned up another pair of pads. Will have to take it back to mechanic next week.  Could it be ABS pump system? No warning light has ever come on.  Any previous owner experience with this problem would be most appreciated.
