Sign in to follow this
MiniGripVan
Horn honks twice when unlocking
Hi all,
Just bought my van, and my 2014 TC XLT honks loudly twice when I unlock and once when I lock. It's really going to bug the neighbors, as I live in a triplex. I can't find any info on how to disable. I tried the Ford 'hold unlock and lock until the blinkers flash" thing and no changes. All Ive heard is it must be an aftermarket alarm, but I cannot find evidence of this and I have an OEM key.
Any ideas?
Many thanks!
Here is a link to the owners manual.  You may find info on how to change it.
http://www.fordservicecontent.com/Ford_Content/Catalog/owner_information/2014-Transit-Connect-Owners-Manual-version-3_om_EN-US_07_2014.pdf
Until then, you can go "old school" and insert the key in the door lock and manual lock/unlock.
I'm fairly certain that it can be changed by re-programming.  But thats a bit more involved and requires some equipment.
Great thanks, I'll report back. Actually when I use the key it starts honking like I broke in 😕
Can't find anything about it in the manual, unfortunately. I wonder if there is an app I can reprogram with an OBD module? Thanks
My 2014 XLT doesn't honk the horn when I lock it . . . . unless I press the lock button twice.  One press, it locks the doors and flashes the lights, two pushes it locks, flashes and honks, but just once
So . . . . it must be programmable  -  I'd check with a Ford dealer
Just found out it's an aftermarket alarm, had my mechanic rip it out as it was causing electrical issues in addition I found out
Thanks!
My 2016 also starts honking if I use the key to get in AND am slow to put key into the ignition switch. Pressing the alarm button on key fob does shut the honking.
