List of Bulb Types?
Hey gang, I always thought it would be a great idea to have a list of what bulb types go into each part of the van. I tried finding one somewhere, but no luck. Anyone have a list going already for what goes where?
If not, I may start one and share it with all you fine folks ?
EDIT- I found one, but the model range goes from 2010-2007
https://sealight-led.com/pages/ford-transit-150-250-350-bulb-size-guide
High beam headlight for 2010~2013 Ford Transit Connect: H13 ( dual high and low beam headlight share the same bulb); for 2014~2017 Ford Transit Connect: H9
Low beam headlight for 2010~2013 Ford Transit Connect: H13 ( dual high and low beam headlight share the same bulb);for 2014~2017 Ford Transit Connect: H11
Fog light: H11
Cornering light: H11
Front turn signal light for 2010~2013 Ford Transit Connect: 3457A / 3457NAK / 3157-SCK ( parking light); for 2014~2017 Ford Transit Connect inner turn signal light: 5200 ; outer turn signal light: 2825
Rear turn signal light: 7440A / 7440NA
Brake Tail light: 7443 / 7443-SCK
Back-up reverse light for 2010~2013 Ford Transit Connect: 921;
for 2014~2017 Ford Transit Connect:7440
3rd Brake light / Center high mount stop light: LED
License plate light / Tag light: 2825 / 2825L / W5W
Interior Map light for 2010~2013 Ford Transit Connect: 6411;for 2014~2017 Ford Transit Connect: 2825
Interior Dome light: 2825 / 2886X / 2825L / W5W
Front side marker light: 2825 / 2825L / W5W
Parking / City light for 2014~2017 Ford Transit Connect: 2825 / 2825L / W5W
Edited by i86hotdogs
I've actually never removed the shrink wrap from mine, lmao. Quite some time back, someone had posted the link for the digital copy, so I downloaded that since it's instantly searchable via computer. Also grabbed the body builders book, so I know where the "do not modify" areas are and stuff like that.
I attached the 2015 owners manual here, I don't recall what year yours is. But 2014-18 is nearly all the same, anyway.
2015-Transit-Connect-Owners-Manual.pdf
  • 1 year later...
2 hours ago, MLB said:
 Not all Gen 2.  My 2016 doesn't (didn't) have LED dome lights rear.
I take it that you missed the little asterisk * next to "Rear Dome lamp" that says *Vehicles with panoramic roof., right?? Do you have a panoramic roof? My cargo van doesn't, so it had regular incandescent cargo light bulbs.
