BSUPC Posted October 30, 2016 Share Posted October 30, 2016 Took a hard hit to my drivers side front tire today. Some igmo hit me in the Lowe's parking lot. now the traction control light is staying on. Read one post on here that says to check the magnetic ring on the bearing, so that shall be done. Anyone have any other suggestions as well ? Included a pic ofor the tire and wheel. Wheel goes to the tire shop to be checked out Monday hopefully. Quote Link to comment Share on other sites More sharing options...
G B L Posted October 30, 2016 Share Posted October 30, 2016 You will need a wheel and most likely a tire. The ABS system needs a scan to see if the wheel sensor is sending data. The harness could also be compromised. The front end need an alignment and a general check out. Quote Link to comment Share on other sites More sharing options...
zalienz Posted October 30, 2016 Share Posted October 30, 2016 There is most likely damage to the ABS sensor and/or the ring on the hub or bearing. Traction control uses the sensor input to make it's decisions. I agree you'll need a wheel, tire, general inspection & alignment in addition to the ABS stuff. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 31, 2016 Share Posted October 31, 2016 Glad that you're okay and that you didn't get hurt. That's the most important. Anything else? That is what insurance is for. Lesson learned. Go to Home Depot instead of Lowes. Quote Link to comment Share on other sites More sharing options...
BSUPC Posted October 31, 2016 Author Share Posted October 31, 2016 Luckily I was in the store at the time it happened. I would have probably done something stupid otherwise. The igmo hit me and fled leaving no note, only damage behind. Tire shop says the tire and wheel are both good to go. Damage to the wheel is only cosmetic. Will update when I can get the the van in the air to work on it. Will be checking the ABS sensor as well as the pigtail and bearing. Van was already due for an alignment so that will be done as well. The cosmetic damage may give me a reason to upgrade the wheels again next year. lol Like I have said before, eventually something will break, just a matter of time. My radiator has developed a small leak in the drivers side lower corner. This was pre igmo hit. Quote Link to comment Share on other sites More sharing options...
G B L Posted November 1, 2016 Share Posted November 1, 2016 Good to here , What I first thought was a crack must be just a gouge. Quote Link to comment Share on other sites More sharing options...
BSUPC Posted November 1, 2016 Author Share Posted November 1, 2016 8 hours ago, G B L said: Good to here , What I first thought was a crack must be just a gouge. It appeared that away to me as well. But they removed the tire and checked it over to make sure it was not cracked. And it took a lot to convince me it was not cracked. lol But it is a nice deep gouge in the wheel. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted November 1, 2016 Share Posted November 1, 2016 Sounds like an excuse to just simply buy another car. Trade it in for next year's model. Quote Link to comment Share on other sites More sharing options...
