Snowman Posted January 22, 2016 Share Posted January 22, 2016 I didn't get a chance to go hunting this year, so instead I bagged a pheasant on I-90 yesterday with my LH headlight. The score was about even,- Pheasant 0 Headlight 0. The front glass/plastic is all gone, but no body damage which with it being a big old bird at 80mph is impressive. It looks like the front of the car has to come off to replace the headlight(?) really?, how did Ford make a simple task so complicated. So, looking for information and tips on the simplest way to go about this job. many thanks in advance! Quote Link to comment Share on other sites More sharing options...
G B L Posted January 23, 2016 Share Posted January 23, 2016 There is a black plastic radiator shield and when that is removed the head light has a couple of screws and a push pin all from the top should be fairly easy. I checked the headlight bulb replacement before I purchased mine . I have a Malibu that is a 3 hour ordeal to change the bulb. Now one of the first things I do is check the headlight replacement when looking at a car. Should be easy Good luck Was the Pheasant Good? Quote Link to comment Share on other sites More sharing options...
windguy Posted January 24, 2016 Share Posted January 24, 2016 (edited) Was the Pheasant Good? I was thinking the exact same thing after reading Snowman's post. Does it taste like chicken? Edited January 24, 2016 by windguy Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted September 20, 2016 Share Posted September 20, 2016 On 1/23/2016 at 5:55 AM, G B L said: I have a Malibu that is a 3 hour ordeal to change the bulb. On my friend's mother-in-law's Honda CRV, we had to take off the bumper cover and grill, remove the headlamp mounting screws, and then slide the entire assembly out. There was just no way for us to get our hands in there to do it from under the hood. Of course, if we had a small child, or a trained monkey, it would have been a piece of cake. I was so mad, I made him buy brand new lamps for everything on both driver and passenger sides, since we already had the bumper & grill off, so that we wouldn't have to do it again if another light failed. He didn't get away with simply beer to drink while we worked on the car. He had to buy lunch too. Quote Link to comment Share on other sites More sharing options...
Johnstoc Posted October 11, 2016 Share Posted October 11, 2016 Snowman, how did this go? Was it as simple as described by BGL? I need to remove both headlight assemblies on a 2016 Transit Connect XLT. Any tips? Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 11, 2016 Share Posted October 11, 2016 Yikes. What happened to your 2016. I found this online. Hope it helps a little. Quote Link to comment Share on other sites More sharing options...
Johnstoc Posted October 12, 2016 Share Posted October 12, 2016 Fifty150 I can't see what you posted, shows a broken image. Can you check the link/image? I need to pull the headlight assemblies out so I can retrofit HID projects into the housings. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 13, 2016 Share Posted October 13, 2016 Okay. Let's see if this helps a little. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 13, 2016 Share Posted October 13, 2016 (edited) I can see that CM5Z-13E003-A is the bracket, and HS1 & HS2 are fasteners. Once those parts are removed, then the rest of the headlight assembly is probably just held in by pop in tabs. Edited October 13, 2016 by Fifty150 Quote Link to comment Share on other sites More sharing options...
Snowman Posted April 11, 2017 Author Share Posted April 11, 2017 OK, i'm back. I have been driving the car with the light taped up, yeah, lazy. Well, I just purchased a replacement light for my van so should have some info on changing it in a few weeks. * The pheasant wasn't in any condition to eat, but it would have been very tender! Quote Link to comment Share on other sites More sharing options...
G B L Posted April 13, 2017 Share Posted April 13, 2017 Too bad you will have to modify your Pheasant hunting technique!! Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted August 31, 2017 Share Posted August 31, 2017 Most of us use a gun. Shotgun shells are less expensive than headlights. Quote Link to comment Share on other sites More sharing options...
