vectorpickle Posted February 13, 2013 Share Posted February 13, 2013 Put some 17" Focus wheels shod with Sumitomos, even have the Blue Oval center caps. robertlane 1 Quote Link to comment Share on other sites More sharing options...
azdamay Posted February 15, 2013 Share Posted February 15, 2013 Nice! As the Focus guys say, needs tint and a drop. Haha. Quote Link to comment Share on other sites More sharing options...
vectorpickle Posted February 18, 2013 Author Share Posted February 18, 2013 Probably going to do a mild drop. Got the rear figured out, trying to figure out what Focus lowering spring will work for the front... Quote Link to comment Share on other sites More sharing options...
azdamay Posted February 19, 2013 Share Posted February 19, 2013 Huh, I was just kidding, didn't realize you were actually going to do that. So how are you going to deal with the rear? From the little bit that I've seen on the internet, the Euro guys have done some dodgy stuff to get the back end to sit lower (certainly things that would modify the load rating, anyway). Quote Link to comment Share on other sites More sharing options...
Capnbill Posted February 24, 2013 Share Posted February 24, 2013 Nice look. Still got the original 15's on ours, but I'm looking at options when it's time to replace them. Any change in mileage? I'd like to widen the wheelbase too, but seems like all the wheels on TireRack are 40mm offset. I think the stock is 52mm or so. Quote Link to comment Share on other sites More sharing options...
vectorpickle Posted November 19, 2013 Author Share Posted November 19, 2013 Mileage is seems about the same. They are quieter than the stock tires Quote Link to comment Share on other sites More sharing options...
mrtn Posted November 19, 2013 Share Posted November 19, 2013 Huh, I was just kidding, didn't realize you were actually going to do that. So how are you going to deal with the rear? From the little bit that I've seen on the internet, the Euro guys have done some dodgy stuff to get the back end to sit lower (certainly things that would modify the load rating, anyway). Euro guys flip the rear axle around so it would sit on top of the spring leaf. Quote Link to comment Share on other sites More sharing options...
robertlane Posted November 20, 2013 Share Posted November 20, 2013 Put some 17" Focus wheels shod with Sumitomos, even have the Blue Oval center caps. Really nice addition to your Transit Connect! Quote Link to comment Share on other sites More sharing options...
ActiveIndy Posted November 21, 2013 Share Posted November 21, 2013 Nice! I'm doing the poor mans version...ditched the hubcaps after I lost one that popped off, added stainless steel trim rings to the OEM steel wheels and am going to hit them with a coat of black paint this winter when I have some time. Then I'm going to try the "painted laundry detergent cap" center cap that someone else on the forum posted awhile back to finish them off. Should end up with about $50 invested when I'm done and will post pics... Quote Link to comment Share on other sites More sharing options...
mudslinger Posted December 11, 2013 Share Posted December 11, 2013 ActiveIndy - What size info did you need to buy trim rings? And what is this about detergent cap? I am about to replace my tires after 3 years of ownership and am considering a new look Quote Link to comment Share on other sites More sharing options...
ActiveIndy Posted December 14, 2013 Share Posted December 14, 2013 http://fordtransitconnectforum.com/gallery/image/572-tide-center-caps/ I just searched for "stainless steel trim rings" for our stock wheel size (15" if I recall?) and found them online for just under $50 I think. Quote Link to comment Share on other sites More sharing options...
carlodalessandro Posted January 17, 2014 Share Posted January 17, 2014 HI Guys, Greetings from Scotland, I'm a newbie here. I recently bought 15" steel ring embellishers to brighten up the factory standard steel wheels that came with my Connect. Trouble is they don't fit. I stupidly thought that buying 15" steel rings would be a sensible fit on 15" steel wheels... There is a recess that these need to fit into? and I think I need to get 13" ones to make them fit. (I hacksawed 2/3 inches out of one of the 15" ones, and it looks like 13" is the right diameter). I have contacted the company I bought them from for advice but waiting to hear back so thought someone here might know which diameter is needed. I notice that azdamay has successfully fitted these rings Any help greatly appreciated!! Cheers, C Quote Link to comment Share on other sites More sharing options...
Willie Posted January 18, 2014 Share Posted January 18, 2014 HI Guys, Greetings from Scotland, I'm a newbie here. I recently bought 15" steel ring embellishers to brighten up the factory standard steel wheels that came with my Connect. Trouble is they don't fit. I stupidly thought that buying 15" steel rings would be a sensible fit on 15" steel wheels... There is a recess that these need to fit into? and I think I need to get 13" ones to make them fit. (I hacksawed 2/3 inches out of one of the 15" ones, and it looks like 13" is the right diameter). I have contacted the company I bought them from for advice but waiting to hear back so thought someone here might know which diameter is needed. I notice that azdamay has successfully fitted these rings Any help greatly appreciated!! Cheers, C Can't figure what the problem might be, I bought generic 15 inch hubcaps for mine and they fit just fine. Quote Link to comment Share on other sites More sharing options...
deaster Posted February 18, 2014 Share Posted February 18, 2014 Looks killer vectorpickle...also like the addition of the cattle guard & fogs. Quote Link to comment Share on other sites More sharing options...
johnsonmy Posted February 28, 2014 Share Posted February 28, 2014 Hey Indy, If you search around there are 2 or 3 different styles of OEM center caps from the UK market, and frequently available on Ebay UK. Quote Link to comment Share on other sites More sharing options...
graphics1125 Posted March 23, 2015 Share Posted March 23, 2015 What size rims and tired are those? Really nice! Quote Link to comment Share on other sites More sharing options...
scottythe1nonly Posted April 6, 2015 Share Posted April 6, 2015 (edited) I bought a black 2014 TC Titanium last October. For winter I outfitted it with a set of Michelin snow tires on black Momo Winter Pros: I had considered larger wheels for summer driving, but I was a bit concerned about harshing out the ride. And after riding the 16s all winter I liked the black on black look and figured I didn't need larger rims. Last week I ordered a set of black16 inch Momo Revenge wheels. I should have them mounted within the next week. Edited April 6, 2015 by scottythe1nonly MarkMcCoskey 1 Quote Link to comment Share on other sites More sharing options...
scottythe1nonly Posted April 25, 2015 Share Posted April 25, 2015 (edited) couldn't get the Momo Revenge. So I got the WIN 2 instead. Edited April 25, 2015 by scottythe1nonly 15Dan15, MarkMcCoskey and mustang 3 Quote Link to comment Share on other sites More sharing options...
