radiator upgrade
rallybag
  • 4 months later...
On 9/17/2020 at 1:28 PM, rallybag said:
hi guys
I have an 07 tc and am looking to upgrade the radiator.  has anyone already done this or know of a rad that will fit apart from stock
thanks
You go to a hot rod shop or engine builder for high performance radiators.  And you pay $.
In case rallybag is still paying attention.......  most race car builders upgrade the cooling system because they have upgraded performance engines.  Follow the flow.  Start with a lower temperature thermostat.  Some engines will delete the pulley driven water pump and replace it with an electric water pump.  Backing the custom radiator are high CFM electric fans set to operate  at different temperatures, with seperate thermostatic switches taking readings from the inlet and the outlet of the radiator.  Depending on what you're building the car for, you need to take other metrics into consideration.  If you're only running 1/4 mile, and you're looking to cover it in less than 9 seconds at over 200 mph.......how are you going to do that in a Transit Connect?
