Interior heights of 2010-2013 question
Hello, I'm looking to buy a TC soon, but I'm curious about the interior height dimensions of the 2010-2013 era - I've looked at the brochures, and they say that the interior heights are very different for each year. Like the 2010 says the maximum cargo height is 59.1, but the 2011 says 53.7. I'm confused because the bodies look very similar/the same. Can any body confirm the actual heights for the different years? Thanks!
As far as I know, the gen 1 USA is all the same body. The difference in heights you're seeing is most likely ceiling height versus door opening height - there's unibody framework above the door opening that hangs down several inches for both generations. I have a gen 2 and the ceiling height (cargo model, no headliner in cargo area) is easily 6-7" above the lowest point of the rear door opening. So, the G1's probably have a ceiling height of 59.1" but a rear door opening height of 53.7".
  • 1 year later...
On 9/27/2019 at 5:48 PM, G B L said:
Here are the two profiles showing the differences .  Have fun with the slide rule
Why does one say rhe length is 6’ while the other says it’s over 8’?
  • 1 year later...
On 9/27/2019 at 8:19 AM, mrtn said:
True. There's only LWB/high-top body Gen1 in the US.
I live in the southeast and I swear I saw at least a low roof. Huh...
I've been looking on google for about an hour now, and wow, you're right :0
