Krustybiker Posted September 12, 2019 Share Posted September 12, 2019 Not sure if this is the correct area, here goes. The heater on my 2015 1.6 diesel Connect Tourneo is blowing cold. On occasion, the engine temperature rises and the motor loses power, then within about half a mile returns to normal. The cooling fan runs pretty much constantly. Help! Please, I'm sure someone has the answer! Quote Link to comment Share on other sites More sharing options...
Double Nickels Posted September 13, 2019 Share Posted September 13, 2019 Engine is heating. Coolant is not carrying heat to the heater core. Fan is on. I would datalog and do a computer diagnostic. It appears as if the cooling system is controlled by the car's computer, and there are electrically controlled valves. One of those valves or a sensor may be at fault. Or it could be an old fashion mechanical thermostat not working. A bad water pump could also be an issue. What is the coolant level? Do you see coolant in the degas bottle? The computer is reading the coolant temp, and that's why the fan is turning on. Check the upper hose, heater hose, and radiator to see if they are hot. If not, then coolant is not getting past the thermostat. Get a scan tool to see what temperature the coolant is, and check if your transmission fluid is also hot. If the engine heats up, your transmission fluid may not cool properly via the heat exchanger. Quote Link to comment Share on other sites More sharing options...
Krustybiker Posted September 13, 2019 Author Share Posted September 13, 2019 (edited) I have been told it could be a head gasket, there seems to be air in the system. I really hope not, as I know this could be expensive. The coolant level is low, when I release the pressure cap, it comes back up. Where's it hiding?? There are bubbles in the return tube (the small one, I think is a bypass, at the bottom of the bottle. Edited September 13, 2019 by Krustybiker extra info Quote Link to comment Share on other sites More sharing options...
G B L Posted September 14, 2019 Share Posted September 14, 2019 Is it loosing coolant? You can test for combustion gasses in the coolant with a tester. If it is not loosing coolant then you could have a thermostat issue. If there is no heat then the coolant is low, top it off and see how long it takes to get low again Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted September 14, 2019 Share Posted September 14, 2019 Eddy Kilowatt posted a good exploded view of the cooling system. 2 hours ago, Krustybiker said: There are bubbles in the return tube (the small one, I think is a bypass, at the bottom of the bottle. There appear to be 2 hoses in the Degas bottle. I hope the diagram helps you figure out which hose goes where, and where those bubbles may be returning from. Quote Link to comment Share on other sites More sharing options...
Eddy Kilowatt Posted September 16, 2019 Share Posted September 16, 2019 On 9/13/2019 at 7:19 PM, Fifty150 said: Eddy Kilowatt posted a good exploded view of the cooling system. Um, note that diagram is from the manual for the 2015 USA-spec 2.5 gas engine (as best as I can tell... the manual is not always clear about the differences between the 2.5 and the 1.6 turbo). Euro spec diesel is probably going to be quite different from this picture. Quote Link to comment Share on other sites More sharing options...
keith862777 Posted December 2, 2023 Share Posted December 2, 2023 Hi. I am having same issues.did you get it resolved. 2015 ford connect 1.6 diesel Quote Link to comment Share on other sites More sharing options...
