oil change tips you might like Gen2
Willygee
This link excellent tips on diy oil and filter changes:
In addition to those above: Prefill your oil filter prior to install . Filter is a vertical install and screws in easily even when full.
                                                pre-grease the 6 x T27 torx screw threads prior to skid pan install to minimize corrosion seize...i used some
                                                Marine propeller grease i had handy. Cheers
Good report, but i will pass on the pre filling of the oil filter that is just a good way of getting some contaminants directly into the engine. The center hole of the filter sends oil directly into the engine with out filtration .
