Eliminating 4.2" screen on a 2015
On 9/24/2019 at 2:35 PM, Double Nickels said:
Did you have to drill a hole in the roof?
The antenna doesn't come apart, so you'd need a sort of large hole to pass-through the connector that goes to the radio. I just have the wire going out through the driver side sliding door (tacky, but whatever); never noticed any leaking but the wire is also only like 24awg or something. Eventually, I'd like to get an antenna that uses NMO base - which does require drilling a hole, but it's sealed up when the antenna is put on. Here's a pic for those unsure of what NMO mounts look like.
I've heard of people sticking the satellite antenna on their dash in the windshield, but I don't know about all that. Mine on the driver-side roof loses signal when drive-thru's have that little overhang above me, even if it only covers half the van. So I don't understand how the dash can keep a reliable signal, but who knows. When I do the NMO, I'll probably end up putting it on the passenger side, instead.
