RiverTowy Posted April 10, 2019 Share Posted April 10, 2019 2006 Connect T220L SWB 1.8 Diesel. No engine management light on when key turned in ignition on starting. Should it light up? All other dials/guages/LEDS work fine. I have run the cluster self test and the EML does illuninate, so the LED is good. Quote Link to comment Share on other sites More sharing options...
RiverTowy Posted April 15, 2019 Author Share Posted April 15, 2019 It has been suggested on another forum, that the problem is probably a processor communication to the CEL fault/malfunction. I cannot afford to pay £150+ to take it to a Ford garage to be put on a diagnostic tool. How would I go about getting this investigated? Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted April 15, 2019 Share Posted April 15, 2019 On cars I've owned, when key is turned to first position, ACC, all dash warning lights will turn on to indicate that they work. Assumption is that your car should do the same thing. On most cars which fail government inspection, the obvious fix is usually a bulb or fuse. We know that the light can illuminate, which means you can rule out the first obvious test. No need to test the lamp. No need to test the fuse. The least expensive option is to download ForScan for free. ForScan can run "key on, engine off" and "key on, engine on" tests,. This may work if your vehicle is compatible with ForScan. There are a lot of scan tools on the market, and some are Ford specific. But buying your own electronic diagnostic equipment may also be cost prohibitive. You will need a computer and OBD II connector for Forscan. Most people suggest using a laptop computer with a cable, as opposed to a tablet computer with bluetooth and/or WiFi connection. The cable is stable, and there is less of a chance that you will lose connection to the computer in mid-test. A laptop could be plugged into an extension cord, so that you don't risk low battery failure in mid-test. The laptop computer version of ForScan may be a better version of the software. You could also do something obvious to trigger the check engine light, just to see that if there is a problem, the light will come on. I've heard of people taking the fuel cap off, then turning on the car. In theory, if the fuel cap is defective, loose, or off, the check engine light is suppose to turn on, to indicate that you have a problem. Another option is to use a wiring diagram and check wiring for a bad connection somewhere. Are there any independent service shops in your area who have diagnostic tools or diagnostic computers? Is there an independent shop in your area whom specializes in Ford vehicles. Some "tuner" shops, or "speed" shops, are more knowledgeable about electronic diagnostics since they dyno-tune, and may have better electronic diagnostic equipment than shops whom do mostly mechanical work. Some independent shops can perform the diagnostic for less than what Ford will charge you. There is also a person online, who has posted tons of great videos, and many follow his advice on repairs and maintenance. You could try contacting him. Maybe this is something that a professional mechanic sees, has a simple solution for, and us non-professionals just don't know about. As reference to the video below, this guy sees more than most people, and as he points it all out, it was all obvious and people just don't see what's in front of them. https://m.facebook.com/FordTechMakuloco/ https://www.youtube.com/user/FordTechMakuloco Quote Link to comment Share on other sites More sharing options...
G B L Posted April 16, 2019 Share Posted April 16, 2019 Does your engine have a oil pressure gauge or light? If a light, does that come on? Check the Sender wire on the engine oil pressure sender it could be involved? Quote Link to comment Share on other sites More sharing options...
RiverTowy Posted April 19, 2019 Author Share Posted April 19, 2019 Fifty150 thank you for such a comprehensive and informative reply. I broke down the other day, coolant temerature sensor failed. The CEL/EML did not come on. New sensor got me going again. Mechanic read fault codes and cleared them. Subsequent to that, out of interest, he read them again couple days later. U1262 and B1318 present. I have now got ForScan and a USB ELM327. Not used it yet though. GBL, oil pressure indicator is a LED. It comes on in startup position just like it should and goes off on starting. Quote Link to comment Share on other sites More sharing options...
Connectrob1991 Posted April 1, 2020 Share Posted April 1, 2020 Did you ever fix your engine light issue I have it as well 2006 ex Royal mail Quote Link to comment Share on other sites More sharing options...
ludo_2002 Posted June 23, 2024 Share Posted June 23, 2024 (edited) I have a similar problem. My Mk1 connect has failed DOE test because the engine warning light is not working. Should it illuminate when I turn the key? It doesn't. I have removed the dash panel and the lights are all LEDs, no bulbs. Could it be a blown LED?? Any help appreciated UPDATE : I ran the self test for the instrument panel and the LED is good.... Edited June 28, 2024 by ludo_2002 new info Quote Link to comment Share on other sites More sharing options...
