Flying Media Posted October 15, 2011 Share Posted October 15, 2011 whats the trick to remove a headlight assy Quote Link to comment Share on other sites More sharing options...
JWWOODY Posted October 15, 2011 Share Posted October 15, 2011 (edited) According to the service manual, you have to remove the bumper cover assembly. There are three bolts that hold the headlight, two below and the visable one above, disconnect the electrical coonector and thats it. The bumper cover seems a bit more involved. Remove the fender splash shields, the 5 radiator screws, the 4 bumper cover side bolts(2 each side), fender mouldings,the side marker lamp electrical connedtors, the 2 front bumper cover bolts( under the plastic covers) and take off the bumper cover. And as the manual states, to install, reverse the removal proceedure. Hope this helps. Woody whats the trick to remove a headlight assy Edited October 15, 2011 by JWWOODY Quote Link to comment Share on other sites More sharing options...
Flying Media Posted October 15, 2011 Author Share Posted October 15, 2011 According to the service manual, you have to remove the bumper cover assembly. There are three bolts, two below and the visable one above. disconnect the electrical coonector and thats it. The bumper cover seems a bit more involved. Remove the fender splash shields, the 5 radiator screws, the 4 bumper cover side bolts(2 each side), fender mouldings,the side marker lamp electrical connedtors, the 2 front bumper cover bolts( under the plastic covers) and take off the bumper cover. And as the manual states, to install, reverse the removal proceedure. Hope this helps. Woody ok i'll have to go back under and look i need to buy a manual Quote Link to comment Share on other sites More sharing options...
Flying Media Posted October 15, 2011 Author Share Posted October 15, 2011 thanks woody !!!!! Quote Link to comment Share on other sites More sharing options...
34schwant Posted April 6, 2016 Share Posted April 6, 2016 (edited) I have just replaced the O/S unit on my 65 plate Connect 240 LTD, following a hefty pheasant strike yesterday !!! £182.44 replacement unit from Hendy... Above posts refer to different model I think, but there are no 'bottom bolts' on this model...no need to remove any bumpers, trims or anything... Switch off lights & ignition...remove connector block from unit. Undo the top back screw, including odd shaped fixing plate, near bonnet hinge, then remove a couple of securing clips under the rubber trim along front above front grill. This will allow a bit of 'wiggle room' Remove the bottom screw...then look at your new unit...note what sticks out where etc, this will help greatly with removal of old unit. Just a case of carefully lifting, turning, easing etc till its out. Wiggle and turn, ease new one in, replace screws, weird looking plate, and clips etc. Check everything works OK Don't forget to save any working bulbs before you chuck the old unit. ...Final note... The £182.44 handed over to Hendys...the unit is complete, including all bulbs, only things to re-use are your 2 fixing screws. Hope that helps someone out, I arrived here following a Google search...but nowt came up specific to the newer model. (Admin /mod please edit / move to more relevant section if required) Edited April 6, 2016 by 34schwant Quote Link to comment Share on other sites More sharing options...
mrtn Posted April 6, 2016 Share Posted April 6, 2016 The "xy plate" system is only used in Britain. No-one else can figure out the model year from it. I have just replaced the O/S unit on my 65 plate Connect 240 LTD Quote Link to comment Share on other sites More sharing options...
103west43rd Posted April 6, 2016 Share Posted April 6, 2016 In the UK, 65 plate means a vehicle from 1 September 2015 to 29 February 2016 In the US, that would normally be a 2016. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted September 16, 2016 Share Posted September 16, 2016 Quote Link to comment Share on other sites More sharing options...
