2016 Suspension needs better support
ImTom
Does anyone know if any companies make rear air shocks or air-bags for a 2016 TC Platinum w/ LWB ??  I need to add a hitch mounted power lift (100lbs) to carry my mobility Scooter (300lbs).  I don’t want my low beams searching for squirrels in the trees at night, nor do I want the extra tail end weight to ruin my standard rear suspension?
I’d really appreciate any help you folks could offer me... I really need a solution
Thanks,
Tom
On a 2016, you will not be able to buy anything over-the-counter.  Custom fabrication will be necessary.  Maybe custom coil springs, airbags, and bump stops.
KIMG2041.thumb.JPG.c5e9b24f082298bd8294b9317708348d.JPGKIMG2042.thumb.JPG.500d00ba29f925c42eedf104a535395a.JPG
https://www.truckspring.com/
http://www.stengelbros.com/
Celebrating Roberto Clemente
About 18,600,000 results (0.41 seconds)
Search Results
Web results
 Rating: 4.7 - ‎17 reviews
Buy heavy duty coil springs at TruckSpring.com or call 1-800-358-4751 to speak to a coil springsuspension specialist. Replace your truck coil springs with ...
We offer Dayton Parts heavy duty coil springs and Tuftruck heavy duty coils. ... a snowplow or a heavy-duty bumper with winch, a Tuftruck (TTC) coil spring is an ...
You might be able to get by with some simple coil spring boosters, since your not adding a lot of weight.  They are not the best solution, but they might work for you.  I prefer the rubber ring style.  The screw in type tends to pop back out.  The bolt in type will distort the spring over time and can be tricky to install.
Rubber ring:
https://www.autozone.com/suspension-system-coil-springs-and-lift-lowering/coil-spring-booster/superior-automotive-coil-spring-booster/828156_0_0
Screw in:
https://www.autozone.com/suspension-system-coil-springs-and-lift-lowering/coil-spring-booster/superior-automotive-coil-spring-booster/540997_0_0
Bolt in:
https://www.autozone.com/suspension-system-coil-springs-and-lift-lowering/coil-spring-booster/superior-automotive-coil-spring-booster/541730_0_0
Let us know what you end up doing and how it works for you....
That may give him a lifted look, and raise the van by an inch.  But it really does not solve the problem of heavy load on his springs.
Who is selling you the power lift?  Is that company performing the installation?  Does this company configure and sell entire vehicles?  Most of the companies that build out wheelchair access vans for transport companies have schematics for installation which include workarounds for the exhaust, suspension, et cetera.  Maybe ask the company selling you the device what they recommend for suspension.  Or contact a couple of the coach builders who do custom conversions, and ask them what they do with Transit Connect conversions.
Wheelchair vans, SUV's and wheelchair lifts for vans by BraunAbility, the world leader in mobility. Call or text BraunAbility today at 800-488-0359.
Wheelchair lifts are what make wheelchair vans possible! In the past, handicap lifts were made for numerous types vehicles. Today though, wheelchair lifts are ...
VMI wheelchair lifts for vans meet a wide range of needs and budgets. The wheelchair lifts are developed for optimum strength and convenience, and meet or ...
Get more information on wheelchair van lifts and scooter lifts including BraunAbility, Bruno, Harmar, Ricon ... BraunAbility® | Wheelchair Lifts for Full Size Vans.
