BillTheCat Posted March 25, 2018 Share Posted March 25, 2018 Any way to have 3 seats in back to make it an 8-seater? Does such a thing exist? Thanks! Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted March 26, 2018 Share Posted March 26, 2018 If you are willing to fabricate your own bench seat, and you have 3 very skinny passengers, then yes. You can even go so far as to fabricate your own seat belts. But as far as being able to purchase a ready made bench seat, or 3 separate mini-seats, with seat belts, then no. Quote Link to comment Share on other sites More sharing options...
G B L Posted March 26, 2018 Share Posted March 26, 2018 Fifty 150 is correct , the maximum factory configuration is 7. Quote Link to comment Share on other sites More sharing options...
BillTheCat Posted March 27, 2018 Author Share Posted March 27, 2018 Thanks for the quick replies. Fabrication is out since I was hoping for something to just pop in. The passengers are kids so roominess is not such a concern. Just curious, why is the 3rd row 2 seats only? Is it just too narrow? Ideally I'd like to just purchase a 2nd row and install it as the 3rd. Sorry for all the newbie questions, thanks! Quote Link to comment Share on other sites More sharing options...
DonShockley Posted March 27, 2018 Share Posted March 27, 2018 16 minutes ago, BillTheCat said: ...why is the 3rd row 2 seats only? Is it just too narrow? Ideally I'd like to just purchase a 2nd row and install it as the 3rd. Sorry for all the newbie questions, thanks! Narrower clearance between the rear wheel wells is the primary reason. Also, the third row is flat mounted while the second row mounts to the recessed area with the rear edge supported on the higher portion where the 3rd row seats mount. Even if the 2nd row fit between the wheel wells, the brackets on the second row wouldn't have any support right where all the weight is when in the raised position. Quote Link to comment Share on other sites More sharing options...
BillTheCat Posted March 27, 2018 Author Share Posted March 27, 2018 Great, thanks for the detailed response! Quote Link to comment Share on other sites More sharing options...
