Paul Hauser Posted January 7, 2018 Share Posted January 7, 2018 Its been a little while since I did this install but I took photos and planned to write about it when the weather was nasty. today the weather is nasty. I have a '15 Transit connect LX cargo van with the very base package. I bought this model believing that it would be a great platform to build whatever I wanted. That's been true some of the time, but the very basic model has significant differences in the wiring harness and in fact some of the harness simply isn't there going to the cargo area. The "mechless" radio is a big difference. Mechless radios have only AM/FM, no CD player. There was no 4" screen above my radio and no steering wheel controls. Researching on the Crutchfield website said there were no radio install kits for my vehicle, I knew I could fab something, but that wasn't the only problem I would run into. Since I had no 4" screen and the install kit had no provision for not having one I decided to install a switch panel in that spot. I started with paper mach-up, then made one from Plexiglass. Why Plexiglass? I had some, and its easy to fab since you can see through it. Here's new and old next to each other. When you pull out the Mechless radio there's a big hunk of useless plastic. remove it. Now there's plenty of room. Before any of you comment, my van is filthy. It will remain filthy through out these photos and probably throughout its existence. I had to pull out the seat to run the wires for the backup camera under the floor matt, as well as pull the canter console and trim around the shifter. What a mess. The Nav and XM antennas tuck in nicely under the little visor piece. and I added a USB port that goes to USB2 on the radio for Android Auto. This is a convenient spot to plug in but very inconvenient when taking things apart, I would rethink this if I were doing it again. After getting all the wiring and hardware complete, with much excitement, I switched the power on..... and nothing happened. just a blank screen. talk about a sinking feeling. after a few phone calls that I should have made when I started this project I found that I had used the wrong wiring harness from Metra. While most of you will use the XSVI-5524-NAV CAN data interface, those of us with mechless radios need the simpler 70-5524. Even though I do have a CAN system in my van, the radio doesn't use it and the wires aren't there. The only thing that I don't have in the end is the speed signal. I think I could find it under the instrument panel, but I haven't tried so far. It works fine without it. final project working. so what do the switches do? on of them works these cargo area LED strips. I hope this has been helpful and inspires you to do your own custom install. mrtn 1 Quote Link to comment Share on other sites More sharing options...
collinjx Posted April 25, 2019 Share Posted April 25, 2019 On your Pioneer radio do notice screen wash out because of the tilt the radio has to be installed? I'm looking at a Pioneer MVH2400NEX to replace my stock radio. Just wanted to know if I should be looking for a adjustable screen for the replacement. Quote Link to comment Share on other sites More sharing options...
BBJ Posted April 25, 2019 Share Posted April 25, 2019 I just put in a Clarion VX-405 and the glare is awful. I'm looking for something to put on the screen to reduce the glare during the day. Quote Link to comment Share on other sites More sharing options...
