T0ASTERvan Posted August 3, 2016 Share Posted August 3, 2016 (edited) Edited Edited October 11, 2016 by T0ASTERvan Quote Link to comment Share on other sites More sharing options...
kidcit Posted August 3, 2016 Share Posted August 3, 2016 Negative camber means the wheels lean inward at the top.Slight positive camber is more usual and cause less tire wear, most road surfaces being crowned Quote Link to comment Share on other sites More sharing options...
G B L Posted August 3, 2016 Share Posted August 3, 2016 (edited) The way this vehicles the rear axle is designed makes the width of the wheels have zero effect on the camber . Edited August 3, 2016 by G B L Quote Link to comment Share on other sites More sharing options...
Beta Don Posted October 8, 2016 Share Posted October 8, 2016 "Negative camber means the wheels lean inward at the top.Slight positive camber is more usual and cause less tire wear, most road surfaces being crowned" Actually, for any vehicle you want to handle well, slight negative camber is desirable on all 4 wheels. The reason is as the vehicle shifts it's weight to the outer wheels in a curve that negative camber turns toward zero camber and gives the tire a better connection to the road. Slight amounts of negative camber have little effect on tire wear Here's the alignment settings for my Miata, which is one of the better handling cars an average guy can afford to drive Rear - Toe 1/32 inch IN per side. Camber - Negative 1.75 degrees each side Front - Toe 1/32 inch IN per side. Caster - 5 degrees. Camber - Negative 1.2 degrees each side No matter how hard I drive it, the tires always were evenly all across the width of the tread I had not noticed the negative camber on our TC, but if it's there, I'm happy to have it Don Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 8, 2016 Share Posted October 8, 2016 Aren't trucks and vans designed to handle best with payload? Quote Link to comment Share on other sites More sharing options...
