DapperVan Posted May 9, 2016 Share Posted May 9, 2016 I can't for the life of me find any documentation on this option. It's on the driver's display menu to the right of the average mpg. You can change it from Anticipation to Speed, but from all the research I have done it seems this is only a "display feedback" gimmick that shows green leaves on a display...however the Transit Connect does not have this display! So why does it have settings? It says to refer to the manual, but guess what? No info on it in the manual. Quote Link to comment Share on other sites More sharing options...
Slonie Posted May 9, 2016 Share Posted May 9, 2016 If you leave the display on the EcoMode screen for a while, it will give you congratulations when you drive in an economical fashion! That's really all it does. mrtn and DapperVan 2 Quote Link to comment Share on other sites More sharing options...
DapperVan Posted May 9, 2016 Author Share Posted May 9, 2016 Wow that's just silly! Quote Link to comment Share on other sites More sharing options...
mrtn Posted May 9, 2016 Share Posted May 9, 2016 A placebo tool for eco driving. Good thinking, Ford. DapperVan 1 Quote Link to comment Share on other sites More sharing options...
G B L Posted May 10, 2016 Share Posted May 10, 2016 (edited) 40 years ago JC Whitney Use to sell a Color coded Vacuum gauge that mounts on the Dash board and when you put your foot into it hard it would go to Red as the Throttle opened , Showing you that you were using more gas. When you took your foot off the gas it would return to the green zone. It was Called the Econo Meter! This is the up dated version. Nice to see that things do not change as much as you would think. It also shows that Gimmicks that make you think you are saving gas are not new and are not going away. Edited May 10, 2016 by G B L Quote Link to comment Share on other sites More sharing options...
mrtn Posted May 10, 2016 Share Posted May 10, 2016 Honda also has one that goes from mellow green to dark blue I think. Not sure if it goes red. It illuminates the outer rim of the mid mounted tach. Like a glow. Toyota has a green "eco" led in the dash that either stays on or goes off when accelerating hard or shifting manually and stay in gear for too long. Quote Link to comment Share on other sites More sharing options...
103west43rd Posted May 10, 2016 Share Posted May 10, 2016 During the 1970's Chrysler had turn signal indicators on the top of its front fenders. Under hard acceleration they would illuminate. As G B L mentioned, the idea has been around for many years. Quote Link to comment Share on other sites More sharing options...
G B L Posted May 10, 2016 Share Posted May 10, 2016 Usually the people who are interested in the Eco Mode don't need a reminder and the rest buy a fast car with a thirsty powerful motor!! Quote Link to comment Share on other sites More sharing options...
mrtn Posted May 10, 2016 Share Posted May 10, 2016 Someone called the up-shift light "fun driving" indicator. I found it hilarious. Quote Link to comment Share on other sites More sharing options...
