brueg Posted December 29, 2010 Share Posted December 29, 2010 My wife found this on the ground after I went to work. Near the drivers side door. Its about 2 inches long. Quote Link to comment Share on other sites More sharing options...
brueg Posted December 30, 2010 Author Share Posted December 30, 2010 I've sent the same pics to my dealer. I'll bet they don't know what it is. Pay no attention to the date on the pics. I hardly use my digital camera anymore. Quote Link to comment Share on other sites More sharing options...
Connect owner UK Posted December 30, 2010 Share Posted December 30, 2010 Are you the same guy who posted this in 2007 as well, http://www.automotiveforums.com/vbulletin/t764384.html Quote Link to comment Share on other sites More sharing options...
brueg Posted December 31, 2010 Author Share Posted December 31, 2010 (edited) No this just happened a couple of days ago on my 2010. Still no word from the dealership. Edited December 31, 2010 by brueg Quote Link to comment Share on other sites More sharing options...
brueg Posted December 31, 2010 Author Share Posted December 31, 2010 (edited) Called their parts dept. Its a heater plenum drain. It appears to connect externally just below where the A/C lines go thru the firewall . I wonder how many have lost theirs. If mine hadn't fell off in my driveway I would have never known. Anyway I'll let the dealership replace it after my vacation. If one of you is under your transit changing oil or something would you take a pic and post it. These pics show where I think it should be. Edited December 31, 2010 by brueg Quote Link to comment Share on other sites More sharing options...
Grey Posted January 21, 2011 Share Posted January 21, 2011 It is an 18K330. Any parts guy/gal can figure that out in seconds. Quote Link to comment Share on other sites More sharing options...
MattCook Posted March 14, 2011 Share Posted March 14, 2011 Is this piece necessary? In Alaska we have extremely rough roads and I imagine mine has fallen off somewhere in the state if you have lost yours so easily. Quote Link to comment Share on other sites More sharing options...
azdamay Posted November 2, 2011 Share Posted November 2, 2011 (edited) Anyone have a definitive answer on this? Answer as in, is it a mission-critical part or can we leave it laying in the driveway? I found this exact part laying on my driveway when I came home from work yesterday. It sure must be poorly attached, if it will fall off the vehicle while it sits motionless in a driveway. I'm holding onto it and will bring it with me to the dealer when I get an oil change, I guess. Edited November 2, 2011 by azdamay Quote Link to comment Share on other sites More sharing options...
Stan MI Posted January 21, 2012 Share Posted January 21, 2012 On 11/2/2011 at 10:53 PM, azdamay said: Anyone have a definitive answer on this? Answer as in, is it a mission-critical part or can we leave it laying in the driveway? I found this exact part laying on my driveway when I came home from work yesterday. It sure must be poorly attached, if it will fall off the vehicle while it sits motionless in a driveway. I'm holding onto it and will bring it with me to the dealer when I get an oil change, I guess. I'm all ears here !!!!! Just found mine in the driveway !!! Quote Link to comment Share on other sites More sharing options...
azdamay Posted January 21, 2012 Share Posted January 21, 2012 They just reattached it when I brought it with me. I can hope they secretly glued it and didn't tell me that... otherwise it's just falling out again. And it is some kind of drain tube. Quote Link to comment Share on other sites More sharing options...
JWWOODY Posted January 21, 2012 Share Posted January 21, 2012 (edited) On 1/21/2012 at 3:37 AM, azdamay said: They just reattached it when I brought it with me. I can hope they secretly glued it and didn't tell me that... otherwise it's just falling out again. And it is some kind of drain tube. Had a problem with condensate from the AC unit coming into the passenger side this past summer. I checked and the elbow cap was missing from covering the condenste drain tube. I solved the problem by putting s plastic elbow into the rubber tube, pointed it down, and secured it with a hose clamp. The elbow cover apparently keeps the air from blowing the condensate back into the vehicle. Edited January 21, 2012 by JWWOODY Quote Link to comment Share on other sites More sharing options...
azdamay Posted January 22, 2012 Share Posted January 22, 2012 Can you point me (and others) to the location of this part? Is it fairly easy to get to? I'd like to check on it and see if it's still there. Quote Link to comment Share on other sites More sharing options...
JWWOODY Posted January 22, 2012 Share Posted January 22, 2012 (edited) On 1/22/2012 at 12:53 AM, azdamay said: Can you point me (and others) to the location of this part? Is it fairly easy to get to? I'd like to check on it and see if it's still there. It is on the firewall, behind the engine and is tough to get to. The steering rack blocks it. It is easier to get to if the vehicle is on a lift, or if the front is up on ramps or jack stands. Edited January 22, 2012 by JWWOODY Quote Link to comment Share on other sites More sharing options...
mike56 Posted February 5, 2012 Share Posted February 5, 2012 I found my also in the driveway. I think I still have it but gluing on an elbow sounds better. thanks for the post Quote Link to comment Share on other sites More sharing options...
